Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Negative elevation » » » » Post: Re: Negative elevation |
Print at Sep 29, 2026, 3:01:04 AM |
| Posted by hansmex at Apr 2, 2011, 2:48:25 PM |
Re: Negative elevation Daniel, Maybe patience isn't your strongest point? I've imported OBJ files as large as 250 MB without problem. Coffee and fags make waiting more pleasant. Then, there's always the XMX trick to increase memory. Also, the way you organise your work can make design life easier or harder. If you install the CopyAsNewFurniture plug-in (pdf), you don't need to ex/import an OBJ file. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 29, 2026, 3:01:04 AM |
