Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: how to restrict user to create walls at 90 degrees only, not greater and less than 90 degree, only at 90 degrees » » » » Post: Re: how to restrict user to create walls at 90 degrees only, not greater and less than 90 degree, only at 90 degrees |
Print at Aug 5, 2026, 6:09:54 PM |
| Posted by Puybaret at Mar 22, 2011, 3:07:16 PM |
Re: how to restrict user to create walls at 90 degrees only, not greater and less than 90 degree, only at 90 degrees I would be happy to help you further but first, I would like to be sure that you understand the spirit of open source projects: Are you aware (or your client if you do some consulting service) that if you build a software derived from a GNU GPL project like Sweet Home 3D and want to distribute it, you will be obliged to redistribute it under the same license, making the source code of the modification publicly available? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 5, 2026, 6:09:54 PM |
