{"name":"Sweet Home 3D","description":"News and tips about Sweet Home 3D","url":"https:\/\/www.sweethome3d.com","home":"https:\/\/www.sweethome3d.com\/hu\/","gmt_offset":"0","timezone_string":"","page_for_posts":387,"page_on_front":1242,"show_on_front":"page","namespaces":["oembed\/1.0","wpml\/v1","flexible-table-block\/v1","rankmath\/v1","rankmath\/v1\/setupWizard","rankmath\/v1\/an","wp-super-cache\/v1","wpml\/st\/v1","wpml\/tm\/v1","wpml\/ate\/v1","wp-smush\/v1","hub-connector\/v1","rankmath\/v1\/ai-visibility","rankmath\/v1\/ca","rankmath\/v1\/in","rankmath\/v1\/status","rankmath\/v1\/link-genius","google-site-kit\/v1","wpmudev_pcs\/v1","wpmudev_blc\/v1","regenerate-thumbnails\/v1","otgs\/installer\/v1","mcp","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/www.sweethome3d.com\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Az er\u0151forr\u00e1s URL-c\u00edme, amely r\u00e9sz\u00e9re az oEmbed adatait k\u00e9rdezz\u00fck le.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Az er\u0151forr\u00e1s URL-c\u00edme, amely r\u00e9sz\u00e9re az oEmbed adatait k\u00e9rdezz\u00fck le.","type":"string","format":"uri","required":true},"format":{"description":"Az oEmbed form\u00e1tum haszn\u00e1lata.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"A be\u00e1gyazott keret maximum sz\u00e9less\u00e9ge pixelben.","type":"integer","default":600,"required":false},"maxheight":{"description":"A be\u00e1gyazott keret maxim\u00e1lis magass\u00e1ga pixelben.","type":"integer","required":false},"discover":{"description":"K\u00fcldj\u00fcnk-e oEmbed felfedez\u00e9si lek\u00e9rdez\u00e9st nem elfogadott szolg\u00e1ltat\u00f3khoz.","type":"boolean","default":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/oembed\/1.0\/proxy"}]}},"\/wpml\/v1":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1"}]}},"\/wpml\/v1\/custom-xml-config":{"namespace":"wpml\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/custom-xml-config"}]}},"\/wpml\/v1\/custom-xml-config\/validate":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/custom-xml-config\/validate"}]}},"\/flexible-table-block\/v1":{"namespace":"flexible-table-block\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"flexible-table-block\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/flexible-table-block\/v1"}]}},"\/flexible-table-block\/v1\/options":{"namespace":"flexible-table-block\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/flexible-table-block\/v1\/options"}]}},"\/rankmath\/v1":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1"}]}},"\/rankmath\/v1\/saveModule":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"module":{"type":"string","description":"Modul slug","required":true},"state":{"type":"string","description":"Modul \u00e1llapot: bekapcsolt vagy kikapcsolt","enum":["on","off"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/saveModule"}]}},"\/rankmath\/v1\/toolsAction":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"action":{"type":"string","description":"Action to perform","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/toolsAction"}]}},"\/rankmath\/v1\/updateMode":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"mode":{"type":"string","description":"Mode to set","enum":["easy","advanced","custom"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/updateMode"}]}},"\/rankmath\/v1\/dashboardWidget":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/dashboardWidget"}]}},"\/rankmath\/v1\/updateSeoScore":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"postScores":{"type":"object","description":"Post scores","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/updateSeoScore"}]}},"\/rankmath\/v1\/updateSettings":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/updateSettings"}]}},"\/rankmath\/v1\/searchPage":{"namespace":"rankmath\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/searchPage"}]}},"\/rankmath\/v1\/disconnectSite":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"token":{"type":"string","description":"Webhely token","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/disconnectSite"}]}},"\/rankmath\/v1\/getFeaturedImageId":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"postId":{"type":"integer","description":"Bejegyz\u00e9s azonos\u00edt\u00f3ja","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/getFeaturedImageId"}]}},"\/rankmath\/v1\/updateRedirection":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"objectID":{"type":"integer","description":"Objektum egyedi azonos\u00edt\u00f3ja","required":true},"objectType":{"type":"string","default":"post","description":"Objektum T\u00edpusa, pl. bejegyz\u00e9s (post), kifejez\u00e9s (term), felhaszn\u00e1l\u00f3 (user)","required":true},"hasRedirect":{"type":"boolean","description":"Whether the object has a redirect or not","required":true},"redirectionID":{"type":"string","description":"Redirection ID","required":false},"redirectionUrl":{"type":"string","description":"Redirection URL","required":false},"redirectionType":{"type":"string","default":"301","description":"\u00c1tir\u00e1ny\u00edt\u00e1s t\u00edpusa","enum":["301","302","307","410","451"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/updateRedirection"}]}},"\/rankmath\/v1\/updateMeta":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"objectType":{"type":"string","description":"Objektum T\u00edpusa, pl. bejegyz\u00e9s (post), kifejez\u00e9s (term), felhaszn\u00e1l\u00f3 (user)","required":true},"objectID":{"type":"integer","description":"Objektum egyedi azonos\u00edt\u00f3ja","required":true},"meta":{"description":"Adat hozz\u00e1ad\u00e1s\u00e1hoz vagy friss\u00edt\u00e9s\u00e9hez sz\u00fcks\u00e9ges meta","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/updateMeta"}]}},"\/rankmath\/v1\/updateSchemas":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"objectType":{"type":"string","description":"Objektum T\u00edpusa, pl. bejegyz\u00e9s (post), kifejez\u00e9s (term), felhaszn\u00e1l\u00f3 (user)","required":true},"objectID":{"type":"integer","description":"Objektum egyedi azonos\u00edt\u00f3ja","required":true},"schemas":{"description":"schemas to add or update data.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/updateSchemas"}]}},"\/rankmath\/v1\/updateMetaBulk":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"rows":{"description":"Selected posts to update the data for.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/updateMetaBulk"}]}},"\/rankmath\/v1\/setupWizard":{"namespace":"rankmath\/v1\/setupWizard","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/setupWizard","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/setupWizard"}]}},"\/rankmath\/v1\/setupWizard\/getStepData":{"namespace":"rankmath\/v1\/setupWizard","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"step":{"type":"string","description":"Current Step","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/setupWizard\/getStepData"}]}},"\/rankmath\/v1\/setupWizard\/updateStepData":{"namespace":"rankmath\/v1\/setupWizard","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"step":{"type":"string","description":"Current Step","required":true},"value":{"type":"object","description":"Current Step Data","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/setupWizard\/updateStepData"}]}},"\/rankmath\/v1\/setupWizard\/updateTrackingOptin":{"namespace":"rankmath\/v1\/setupWizard","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"enable_tracking":{"type":"string","description":"Enable Tracking","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/setupWizard\/updateTrackingOptin"}]}},"\/rankmath\/v1\/saveTemplate":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"postId":{"type":"integer","description":"Post ID.","required":false},"schema":{"type":"object","description":"Schema data.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/saveTemplate"}]}},"\/rankmath\/v1\/getVideoData":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"objectID":{"type":"integer","description":"Object unique id","required":true},"url":{"description":"Video URL.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/getVideoData"}]}},"\/rankmath\/v1\/an":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/an","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an"}]}},"\/rankmath\/v1\/an\/getKeywordPages":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"query":{"description":"Query to search.","type":"string","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/getKeywordPages"}]}},"\/rankmath\/v1\/an\/postsOverview":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/postsOverview"}]}},"\/rankmath\/v1\/an\/getTrackedKeywords":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/getTrackedKeywords"}]}},"\/rankmath\/v1\/an\/getTrackedKeywordsRows":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Keyword to search.","type":"string","default":"","required":false},"orderby":{"default":"default","enum":["default","keyword"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/getTrackedKeywordsRows"}]}},"\/rankmath\/v1\/an\/getTrackedKeywordSummary":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/getTrackedKeywordSummary"}]}},"\/rankmath\/v1\/an\/trackedKeywordsOverview":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/trackedKeywordsOverview"}]}},"\/rankmath\/v1\/an\/addTrackKeyword":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"keyword":{"description":"Keyword to add.","type":"string","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/addTrackKeyword"}]}},"\/rankmath\/v1\/an\/autoAddFocusKeywords":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"data":{"description":"Data to add.","type":"object","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/autoAddFocusKeywords"}]}},"\/rankmath\/v1\/an\/removeTrackKeyword":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc","ASC","DESC"],"required":false},"orderby":{"description":"Sort collection by post attribute.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/removeTrackKeyword"}]}},"\/rankmath\/v1\/an\/deleteTrackedKeywords":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/deleteTrackedKeywords"}]}},"\/rankmath\/v1\/an\/getDesktopPagespeed":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"id":{"description":"Record id.","type":"integer","default":0,"required":false},"objectID":{"description":"Post id.","type":"integer","default":0,"required":false},"force":{"description":"Force update pagespeed.","type":"boolean","default":false,"required":false},"isAdminBar":{"description":"Is admin bar.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/getDesktopPagespeed"}]}},"\/rankmath\/v1\/an\/getMobilePagespeed":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"id":{"description":"Record id.","type":"integer","default":0,"required":false},"objectID":{"description":"Post id.","type":"integer","default":0,"required":false},"force":{"description":"Force update pagespeed.","type":"boolean","default":false,"required":false},"isAdminBar":{"description":"Is admin bar.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/getMobilePagespeed"}]}},"\/rankmath\/v1\/an\/getPageSEOScore":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"id":{"description":"Record id.","type":"integer","default":0,"required":false},"objectID":{"description":"Post id.","type":"integer","default":0,"required":false},"force":{"description":"Force update pagespeed.","type":"boolean","default":false,"required":false},"isAdminBar":{"description":"Is admin bar.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/getPageSEOScore"}]}},"\/rankmath\/v1\/an\/postsRows":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/postsRows"}]}},"\/rankmath\/v1\/an\/inspectionStats":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/inspectionStats"}]}},"\/rankmath\/v1\/pingSettings":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"apiKey":{"description":"API Key.","type":"string","required":true},"username":{"description":"Username.","type":"string","required":true},"plan":{"description":"Plan.","type":"string","required":true},"keywords":{"description":"Keywords.","type":"string","required":true},"settings":{"description":"Settings.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/pingSettings"}]}},"\/rankmath\/v1\/searchIntent":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyword":{"description":"The keyword used to determine the intent.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/searchIntent"}]}},"\/rankmath\/v1\/importCSV":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/importCSV"}]}},"\/rankmath\/v1\/cancelCsvImport":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/cancelCsvImport"}]}},"\/wp-super-cache\/v1":{"namespace":"wp-super-cache\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-super-cache\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-super-cache\/v1"}]}},"\/wp-super-cache\/v1\/settings":{"namespace":"wp-super-cache\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-super-cache\/v1\/settings"}]}},"\/wp-super-cache\/v1\/status":{"namespace":"wp-super-cache\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-super-cache\/v1\/status"}]}},"\/wp-super-cache\/v1\/stats":{"namespace":"wp-super-cache\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-super-cache\/v1\/stats"}]}},"\/wp-super-cache\/v1\/cache":{"namespace":"wp-super-cache\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-super-cache\/v1\/cache"}]}},"\/wp-super-cache\/v1\/preload":{"namespace":"wp-super-cache\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-super-cache\/v1\/preload"}]}},"\/wp-super-cache\/v1\/cache\/test":{"namespace":"wp-super-cache\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-super-cache\/v1\/cache\/test"}]}},"\/wp-super-cache\/v1\/plugins":{"namespace":"wp-super-cache\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-super-cache\/v1\/plugins"}]}},"\/wpml\/st\/v1":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/st\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/st\/v1"}]}},"\/wpml\/st\/v1\/strings\/settings":{"namespace":"wpml\/st\/v1","methods":["POST","GET"],"endpoints":[{"methods":["POST"],"args":{"autoregisterType":{"type":"integer","default":0,"required":false},"shouldRegisterBackendStrings":{"type":"integer","default":0,"required":false},"setNoticeThatCachePluginCanBlockAutoregisterAsDismissed":{"type":"integer","default":0,"required":false},"setDetectStringsInJS":{"type":"integer","default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/st\/v1\/strings\/settings"}]}},"\/wpml\/st\/v1\/strings\/itemscount":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"type":"integer","default":null,"required":false},"type":{"type":"string","required":false},"source":{"type":"integer","default":null,"required":false},"domain":{"type":"string","default":null,"required":false},"translationPriority":{"type":"string","default":null,"required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/st\/v1\/strings\/itemscount"}]}},"\/wpml\/st\/v1\/strings":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"type":"integer","default":null,"required":false},"type":{"type":"string","required":false},"source":{"type":"integer","default":null,"required":false},"domain":{"type":"string","default":null,"required":false},"translationPriority":{"type":"string","default":null,"required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/st\/v1\/strings"}]}},"\/wpml\/st\/v1\/strings\/filters":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/st\/v1\/strings\/filters"}]}},"\/wpml\/st\/v1\/string-packages":{"namespace":"wpml\/st\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"type":"string","required":false},"title":{"type":"string","required":false},"sourceLanguageCode":{"type":"string","required":false},"targetLanguageCode":{"type":"string","required":false},"translationStatuses":{"default":[],"required":false},"limit":{"type":"integer","default":10,"required":false},"offset":{"type":"integer","default":0,"required":false},"sorting":{"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/st\/v1\/string-packages"}]}},"\/wpml\/st\/v1\/strings\/processstringsqueue":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/st\/v1\/strings\/processstringsqueue"}]}},"\/wpml\/tm\/v1":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/tm\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/tm\/v1"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/store":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_job_id":{"type":"string","required":true},"ate_job_data":{"type":"array","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/store"}]}},"\/wpml\/tm\/v1\/xliff\/fetch\/(?P<jobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wpml\/tm\/v1\/ams\/register_manager":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/tm\/v1\/ams\/register_manager"}]}},"\/wpml\/tm\/v1\/ams\/synchronize\/translators":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/tm\/v1\/ams\/synchronize\/translators"}]}},"\/wpml\/tm\/v1\/ams\/synchronize\/managers":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/tm\/v1\/ams\/synchronize\/managers"}]}},"\/wpml\/tm\/v1\/ams\/status":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/tm\/v1\/ams\/status"}]}},"\/wpml\/tm\/v1\/ams\/console":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/tm\/v1\/ams\/console"}]}},"\/wpml\/tm\/v1\/ams\/engines":{"namespace":"wpml\/tm\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/tm\/v1\/ams\/engines"}]}},"\/wpml\/tm\/v1\/ate\/jobs":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/tm\/v1\/ate\/jobs"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/(?P<ateJobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wpml\/tm\/v1\/jobs":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"local_job_ids":{"type":"string","required":false},"scope":{"type":"string","required":false},"id":{"type":"integer","required":false},"title":{"type":"string","required":false},"source_language":{"type":"string","required":false},"target_language":{"type":"string","required":false},"status":{"type":"string","required":false},"needs_update":{"type":"string","required":false},"limit":{"type":"integer","required":false},"offset":{"type":"integer","required":false},"sorting":{"required":false},"translated_by":{"type":"string","required":false},"sent_from":{"type":"string","required":false},"sent_to":{"type":"string","required":false},"deadline_from":{"type":"string","required":false},"deadline_to":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/tm\/v1\/jobs"}]}},"\/wpml\/tm\/v1\/jobs\/assign":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"jobId":{"required":true},"type":{"required":false},"translatorId":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/tm\/v1\/jobs\/assign"}]}},"\/wpml\/tm\/v1\/jobs\/cancel":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/tm\/v1\/jobs\/cancel"}]}},"\/wpml\/tm\/v1\/tp\/xliff\/download\/(?P<job_id>\\d+)\/(?P<job_type>\\w+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"job_id":{"required":true},"job_type":{"required":true},"json":{"type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wpml\/tm\/v1\/tp\/apply-translations":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/tm\/v1\/tp\/apply-translations"}]}},"\/wpml\/tm\/v1\/tp\/batches\/sync":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"batchId":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/tm\/v1\/tp\/batches\/sync"}]}},"\/wpml\/tm\/v1\/tp\/batches\/status":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/tm\/v1\/tp\/batches\/status"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/sync":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"lockKey":{"type":"string","required":false},"ateToken":{"type":"string","required":false},"page":{"type":"int","required":false},"numberOfPages":{"type":"int","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/sync"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/download":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/download"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/retry":{"namespace":"wpml\/tm\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/tm\/v1\/ate\/jobs\/retry"}]}},"\/wpml\/tm\/v1\/ate\/jobs\/receive\/(?P<wpmlJobId>\\d+)":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpmlJobId":{"type":"int","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wpml\/tm\/v1\/ate\/jobs\/(?P<ateJobId>\\d+)\/fix":{"namespace":"wpml\/tm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wpml\/ate\/v1":{"namespace":"wpml\/ate\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpml\/ate\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/ate\/v1"}]}},"\/wpml\/ate\/v1\/ate\/proxy":{"namespace":"wpml\/ate\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/ate\/v1\/ate\/proxy"}]}},"\/wpml\/st\/v1\/import_mo_strings":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"plugins":{"type":"array","required":false},"themes":{"type":"array","required":false},"other":{"type":"array","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/st\/v1\/import_mo_strings"}]}},"\/wpml\/st\/v1\/pre_generate_mo_files":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/st\/v1\/pre_generate_mo_files"}]}},"\/wpml\/st\/v1\/settings":{"namespace":"wpml\/st\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"group":{"required":true},"key":{"required":true},"data":{"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/st\/v1\/settings"}]}},"\/wpml\/v1\/updates":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/updates"}]}},"\/wpml\/v1\/troubleshooting\/posthog":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/troubleshooting\/posthog"}]}},"\/wpml\/v1\/troubleshooting\/enable-alias-domain":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/troubleshooting\/enable-alias-domain"}]}},"\/wpml\/v1\/troubleshooting\/reset-alias-domain":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/troubleshooting\/reset-alias-domain"}]}},"\/wpml\/v1\/item-sections\/populated":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/item-sections\/populated"}]}},"\/wpml\/v1\/posts":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/posts"}]}},"\/wpml\/v1\/posts\/count":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/posts\/count"}]}},"\/wpml\/v1\/send-to-translation\/validate-translation-options":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/send-to-translation\/validate-translation-options"}]}},"\/wpml\/v1\/send-to-translation\/default-batch-name":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/send-to-translation\/default-batch-name"}]}},"\/wpml\/v1\/send-to-translation\/validate-batch-name":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/send-to-translation\/validate-batch-name"}]}},"\/wpml\/v1\/set-review-translation-option":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/set-review-translation-option"}]}},"\/wpml\/v1\/posts\/hierarchical":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/posts\/hierarchical"}]}},"\/wpml\/v1\/posts\/taxonomies":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/posts\/taxonomies"}]}},"\/wpml\/v1\/posts\/terms":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/posts\/terms"}]}},"\/wpml\/v1\/translate-everything\/enable":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/translate-everything\/enable"}]}},"\/wpml\/v1\/translate-everything\/disable":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/translate-everything\/disable"}]}},"\/wpml\/v1\/cancelallautomaticjobs":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/cancelallautomaticjobs"}]}},"\/wpml\/v1\/getuntranslatedtypescount":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/getuntranslatedtypescount"}]}},"\/wpml\/v1\/save-translator-note":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/save-translator-note"}]}},"\/wpml\/v1\/credits":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/credits"}]}},"\/wpml\/v1\/translation-proxy\/commit-batch":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/translation-proxy\/commit-batch"}]}},"\/wpml\/v1\/tranlsation-proxy\/getlastpickedup":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/tranlsation-proxy\/getlastpickedup"}]}},"\/wpml\/v1\/translation-proxy\/getRemoteJobsCount":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/translation-proxy\/getRemoteJobsCount"}]}},"\/wpml\/v1\/gettranslationstatus":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/gettranslationstatus"}]}},"\/wpml\/v1\/getlocaltranslatorbyid":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/getlocaltranslatorbyid"}]}},"\/wpml\/v1\/reloadremotetranslationservice":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/reloadremotetranslationservice"}]}},"\/wpml\/v1\/gettranslationeditortype":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/gettranslationeditortype"}]}},"\/wpml\/v1\/translate-existing-content":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/translate-existing-content"}]}},"\/wpml\/v1\/get-needs-update-count-created-in-cte":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/get-needs-update-count-created-in-cte"}]}},"\/wpml\/v1\/get-engines":{"namespace":"wpml\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/get-engines"}]}},"\/wpml\/v1\/website-contexts":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/website-contexts"}]}},"\/wpml\/v1\/has-posts-using-native-editor":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/has-posts-using-native-editor"}]}},"\/wpml\/v1\/get-credits-per-word":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/get-credits-per-word"}]}},"\/wpml\/v1\/get-words-to-translate-for-items":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/get-words-to-translate-for-items"}]}},"\/wpml\/v1\/get-words-to-translate-for-types":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/get-words-to-translate-for-types"}]}},"\/wpml\/v1\/save-automatic-translation-settings":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/save-automatic-translation-settings"}]}},"\/wpml\/v1\/getlocaltranslators":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/getlocaltranslators"}]}},"\/wpml\/v1\/account-balances":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/account-balances"}]}},"\/wpml\/v1\/glossary-count":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/glossary-count"}]}},"\/wpml\/v1\/enable-ate":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/enable-ate"}]}},"\/wpml\/v1\/get-dismissed-notices":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/get-dismissed-notices"}]}},"\/wpml\/v1\/minimum-requirements":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/minimum-requirements"}]}},"\/wpml\/v1\/rest\/status":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/rest\/status"}]}},"\/wpml\/v1\/dismiss-notice":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/dismiss-notice"}]}},"\/wpml\/v1\/dismiss-notice-per-user":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/dismiss-notice-per-user"}]}},"\/wpml\/v1\/cancel-jobs":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/cancel-jobs"}]}},"\/wpml\/v1\/unsolvable-jobs":{"namespace":"wpml\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/unsolvable-jobs"}]}},"\/wpml\/v1\/resend-unsolvable-jobs":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/resend-unsolvable-jobs"}]}},"\/wpml\/v1\/wpml\/posthog\/capture-event":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/wpml\/posthog\/capture-event"}]}},"\/wpml\/v1\/capture\/event":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/capture\/event"}]}},"\/wpml\/v1\/wpml-proxy\/status":{"namespace":"wpml\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/wpml-proxy\/status"}]}},"\/wpml\/v1\/wpml-content-stats":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/wpml-content-stats"}]}},"\/wpml\/v1\/wpml-ph-make-external-request":{"namespace":"wpml\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpml\/v1\/wpml-ph-make-external-request"}]}},"\/wp-smush\/v1":{"namespace":"wp-smush\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-smush\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-smush\/v1"}]}},"\/wp-smush\/v1\/preset_configs":{"namespace":"wp-smush\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-smush\/v1\/preset_configs"}]}},"\/hub-connector\/v1":{"namespace":"hub-connector\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"hub-connector\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/hub-connector\/v1"}]}},"\/hub-connector\/v1\/sync":{"namespace":"hub-connector\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"force":{"description":"Should do a force sync.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/hub-connector\/v1\/sync"}]}},"\/hub-connector\/v1\/logout":{"namespace":"hub-connector\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/hub-connector\/v1\/logout"}]}},"\/rankmath\/v1\/ai-visibility":{"namespace":"rankmath\/v1\/ai-visibility","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/ai-visibility","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/ai-visibility"}]}},"\/rankmath\/v1\/ai-visibility\/overview":{"namespace":"rankmath\/v1\/ai-visibility","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"refresh":{"description":"Force a refresh from the AI Visibility API.","type":"boolean","default":false,"required":false},"search":{"description":"Filter brands by name or URL.","type":"string","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/ai-visibility\/overview"}]}},"\/rankmath\/v1\/ai-visibility\/brands\/(?P<id>[a-zA-Z0-9\\-]+)":{"namespace":"rankmath\/v1\/ai-visibility","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Brand UUID.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Brand UUID.","type":"string","required":true},"name":{"type":"string","required":false},"url":{"type":"string","required":false},"description":{"type":"string","required":false},"locale":{"type":"string","required":false},"language":{"type":"string","enum":["","US English","UK English","Arabic","Bulgarian","Chinese","Czech","Danish","Dutch","Estonian","Finnish","French","German","Greek","Hebrew","Hungarian","Indonesian","Italian","Japanese","Korean","Latvian","Lithuanian","Norwegian","Polish","Portuguese","Romanian","Russian","Slovak","Slovenian","Spanish","Swedish","Turkish"],"required":false},"status":{"type":"string","enum":["active","inactive"],"required":false},"interval":{"type":"string","enum":["daily","weekly","monthly"],"required":false},"platforms":{"description":"AI platforms to track for this brand. Supported values: \"chatgpt\", \"gemini\". Tracking more than one platform per brand requires the Expert plan.","type":"array","minItems":1,"items":{"type":"string","enum":["chatgpt","gemini"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/ai-visibility\/brands":{"namespace":"rankmath\/v1\/ai-visibility","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"name":{"description":"Brand name.","type":"string","required":true},"url":{"description":"Brand website URL or domain.","type":"string","required":true},"description":{"description":"Short description of the brand or product.","type":"string","required":true},"locale":{"description":"ISO 3166-1 alpha-2 country code (e.g. &quot;US&quot;, &quot;HU&quot;).","type":"string","required":false},"language":{"description":"Output language to use when analyzing\/generating content for this brand. Independent of `locale` (target country). Required; immutable after creation.","type":"string","enum":["US English","UK English","Arabic","Bulgarian","Chinese","Czech","Danish","Dutch","Estonian","Finnish","French","German","Greek","Hebrew","Hungarian","Indonesian","Italian","Japanese","Korean","Latvian","Lithuanian","Norwegian","Polish","Portuguese","Romanian","Russian","Slovak","Slovenian","Spanish","Swedish","Turkish"],"required":true},"interval":{"description":"Analysis refresh cadence. Omitted \u2192 backend applies the account plan&#039;s default.","type":"string","enum":["daily","weekly","monthly"],"required":false},"platforms":{"description":"AI platforms to track for this brand. Supported values: \"chatgpt\", \"gemini\". Tracking more than one platform per brand requires the Expert plan.","type":"array","minItems":1,"items":{"type":"string","enum":["chatgpt","gemini"]},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/ai-visibility\/brands"}]}},"\/rankmath\/v1\/ai-visibility\/brands\/(?P<id>[a-zA-Z0-9\\-]+)\/insights":{"namespace":"rankmath\/v1\/ai-visibility","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Brand UUID.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/ai-visibility\/brands\/(?P<id>[a-zA-Z0-9\\-]+)\/queries":{"namespace":"rankmath\/v1\/ai-visibility","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Brand UUID.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/ai-visibility\/brands\/(?P<id>[a-zA-Z0-9\\-]+)\/queries\/(?P<qid>[a-zA-Z0-9\\-]+)":{"namespace":"rankmath\/v1\/ai-visibility","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Brand UUID.","type":"string","required":true},"qid":{"description":"Query UUID.","type":"string","required":true},"enabled":{"description":"Whether the query is enabled for analysis.","type":"boolean","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/ai-visibility\/brands\/(?P<id>[a-zA-Z0-9\\-]+)\/generate-queries":{"namespace":"rankmath\/v1\/ai-visibility","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Brand UUID.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/ai-visibility\/trial\/activate":{"namespace":"rankmath\/v1\/ai-visibility","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/ai-visibility\/trial\/activate"}]}},"\/rankmath\/v1\/ai-visibility\/checkout-url":{"namespace":"rankmath\/v1\/ai-visibility","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/ai-visibility\/checkout-url"}]}},"\/rankmath\/v1\/ca":{"namespace":"rankmath\/v1\/ca","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/ca","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/ca"}]}},"\/rankmath\/v1\/ca\/researchKeyword":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyword":{"description":"The keyword to be researched.","type":"string","required":true},"country":{"description":"The country for which the keyword should be researched.","type":"string","required":true},"objectID":{"description":"The ID of the post initiating the keyword research request.","type":"integer","required":true},"force_update":{"description":"If true, forces a fresh research request.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/ca\/researchKeyword"}]}},"\/rankmath\/v1\/ca\/getCredits":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/ca\/getCredits"}]}},"\/rankmath\/v1\/ca\/createPost":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"content":{"description":"The content of the new post.","type":"string","required":true},"title":{"description":"The title of the new post.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/ca\/createPost"}]}},"\/rankmath\/v1\/ca\/saveOutput":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"outputs":{"description":"An array of AI-generated and existing outputs to be saved.","type":"array","required":false},"endpoint":{"description":"The API endpoint for which the output was generated.","type":"string","required":false},"isChat":{"description":"Indicates if the request was for the Chat endpoint.","type":"boolean","required":false},"attributes":{"description":"The parameters used to generate the AI output.","type":"object","required":false},"credits":{"description":"Credit usage details returned by the API.","type":"object","required":false},"usage":{"description":"Per-tool usage data returned by the API.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/ca\/saveOutput"}]}},"\/rankmath\/v1\/ca\/deleteOutput":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"isChat":{"description":"Indicates if the request to delete the output was for the Chat endpoint.","type":"boolean","required":false},"index":{"description":"The output index to delete, applicable only to the Chat endpoint.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/ca\/deleteOutput"}]}},"\/rankmath\/v1\/ca\/updateRecentPrompt":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"prompt":{"description":"The selected prompt to be updated in the recent prompts.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/ca\/updateRecentPrompt"}]}},"\/rankmath\/v1\/ca\/updatePrompt":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"prompt":{"description":"The prompt data to be saved in the database.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/ca\/updatePrompt"}]}},"\/rankmath\/v1\/ca\/savePrompts":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"prompts":{"description":"A list of prompts received from the API to be saved in the database.","type":"array","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/ca\/savePrompts"}]}},"\/rankmath\/v1\/ca\/pingContentAI":{"namespace":"rankmath\/v1\/ca","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"plan":{"description":"Rank Math AI plan to update in the Database.","type":"string","required":true},"refreshDate":{"description":"Content AI reset date to update in the Database","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/ca\/pingContentAI"}]}},"\/rankmath\/v1\/ca\/generateAlt":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"attachmentIds":{"description":"List of attachment IDs for which to generate alt text.","type":"array","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/ca\/generateAlt"}]}},"\/rankmath\/v1\/ca\/updateCredits":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"credits":{"description":"Credit usage details returned by the API.","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/ca\/updateCredits"}]}},"\/rankmath\/v1\/an\/dashboard":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/dashboard"}]}},"\/rankmath\/v1\/an\/keywordsOverview":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/keywordsOverview"}]}},"\/rankmath\/v1\/an\/postsSummary":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/postsSummary"}]}},"\/rankmath\/v1\/an\/postsRowsByObjects":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","required":false},"per_page":{"description":"Results per page.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/postsRowsByObjects"}]}},"\/rankmath\/v1\/an\/post\/(?P<id>\\d+)":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Post ID.","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/an\/keywordsSummary":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/keywordsSummary"}]}},"\/rankmath\/v1\/an\/analyticsSummary":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"postType":{"description":"Post Type.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/analyticsSummary"}]}},"\/rankmath\/v1\/an\/keywordsRows":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","required":false},"perPage":{"description":"Results per page.","type":"integer","required":false},"orderBy":{"description":"Order by.","type":"string","required":false},"order":{"description":"Order.","type":"string","required":false},"search":{"description":"Search.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/keywordsRows"}]}},"\/rankmath\/v1\/an\/userPreferences":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"preferences":{"description":"User preferences.","type":"object","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/userPreferences"}]}},"\/rankmath\/v1\/an\/inspectionResults":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","required":false},"perPage":{"description":"Results per page.","type":"integer","required":false},"orderBy":{"description":"Order by.","type":"string","required":false},"order":{"description":"Order.","type":"string","required":false},"search":{"description":"Search.","type":"string","required":false},"filter":{"description":"Filter.","type":"string","required":false},"filterType":{"description":"Filter type.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/inspectionResults"}]}},"\/rankmath\/v1\/an\/removeFrontendStats":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"toggleBar":{"description":"Toggle bar.","type":"boolean","required":false},"hide":{"description":"Hide.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/an\/removeFrontendStats"}]}},"\/rankmath\/v1\/in":{"namespace":"rankmath\/v1\/in","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/in","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/in"}]}},"\/rankmath\/v1\/in\/submitUrls":{"namespace":"rankmath\/v1\/in","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"urls":{"description":"The list of urls to submit to the Instant Indexing API.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/in\/submitUrls"}]}},"\/rankmath\/v1\/in\/getLog":{"namespace":"rankmath\/v1\/in","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"filter":{"description":"Filter log by type.","type":"string","enum":["all","manual","auto"],"default":"all","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/in\/getLog"}]}},"\/rankmath\/v1\/in\/clearLog":{"namespace":"rankmath\/v1\/in","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filter":{"description":"Clear log by type.","type":"string","enum":["all","manual","auto"],"default":"all","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/in\/clearLog"}]}},"\/rankmath\/v1\/in\/resetKey":{"namespace":"rankmath\/v1\/in","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/in\/resetKey"}]}},"\/rankmath\/v1\/links\/posts":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"required":false},"per_page":{"description":"Items per page.","type":"integer","default":50,"maximum":100,"required":false},"search":{"description":"Search in post title.","type":"string","default":"","required":false},"post_type":{"description":"Filter by post type. Supports multiple values.","type":"array","items":{"type":"string"},"default":[],"required":false},"is_orphan":{"description":"Filter by orphan status (orphan, linked).","type":"string","default":"","required":false},"seo_score_range":{"description":"Filter by SEO score range (great, good, bad, no-score).","type":"string","default":"","required":false},"post_id":{"description":"Filter by post ID.","type":"integer","default":0,"required":false},"orderby":{"description":"Order by field.","type":"string","default":"post_title","required":false},"order":{"description":"Order direction (ASC, DESC).","type":"string","default":"ASC","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/links\/posts"}]}},"\/rankmath\/v1\/links\/posts-stats":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/links\/posts-stats"}]}},"\/rankmath\/v1\/links\/links":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"required":false},"per_page":{"description":"Items per page.","type":"integer","default":50,"maximum":100,"required":false},"search":{"description":"Search in URL.","type":"string","default":"","required":false},"source_id":{"description":"Filter by source post ID.","type":"integer","default":0,"required":false},"target_post_id":{"description":"Filter by target post ID.","type":"integer","default":0,"required":false},"is_internal":{"description":"Filter by link type (1 = internal, 0 = external).","type":"string","default":"","required":false},"orderby":{"description":"Order by field.","type":"string","default":"id","required":false},"order":{"description":"Order direction (ASC, DESC).","type":"string","default":"DESC","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/links\/links"}]}},"\/rankmath\/v1\/links\/links-stats":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/links\/links-stats"}]}},"\/rankmath\/v1\/status":{"namespace":"rankmath\/v1\/status","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/status","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/status"}]}},"\/rankmath\/v1\/status\/getViewData":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/status\/getViewData"}]}},"\/rankmath\/v1\/status\/updateViewData":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/status\/updateViewData"}]}},"\/rankmath\/v1\/status\/importSettings":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/status\/importSettings"}]}},"\/rankmath\/v1\/status\/exportSettings":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/status\/exportSettings"}]}},"\/rankmath\/v1\/status\/runBackup":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/status\/runBackup"}]}},"\/rankmath\/v1\/link-genius":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/link-genius","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius"}]}},"\/rankmath\/v1\/link-genius\/links":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"required":false},"per_page":{"description":"Items per page.","type":"integer","default":50,"maximum":100,"required":false},"source_id":{"description":"Filter by source post ID.","type":"integer","default":0,"required":false},"target_post_id":{"description":"Filter by target post ID.","type":"integer","default":0,"required":false},"is_internal":{"description":"Filter by link type.","type":"string","default":"","required":false},"is_nofollow":{"description":"Filter by nofollow status.","type":"string","default":"","required":false},"anchor_type":{"description":"Filter by anchor type (HPLNK, CNCL, HLANG, IMAGE).","type":"string","default":"","required":false},"target_blank":{"description":"Filter by target blank status.","type":"string","default":"","required":false},"search":{"description":"Search in anchor text or URL.","type":"string","default":"","required":false},"orderby":{"description":"Order by field.","type":"string","default":"created_at","required":false},"order":{"description":"Order direction.","type":"string","default":"DESC","required":false},"status_code":{"description":"Filter by HTTP status code (e.g., 404). Supports multiple values.","type":"array","items":{"type":"string"},"default":[],"required":false},"status_category":{"description":"Filter by status category (2xx, 3xx, 4xx, 5xx, timeout, error).","type":"string","default":"","required":false},"is_broken":{"description":"Filter broken links (4xx, 5xx, timeout, error).","type":"boolean","default":false,"required":false},"is_success":{"description":"Filter successful links (2xx).","type":"boolean","default":false,"required":false},"is_redirect":{"description":"Filter redirect links (3xx).","type":"string","default":"","required":false},"robots_blocked":{"description":"Filter links blocked by robots.txt.","type":"string","default":"","required":false},"unchecked":{"description":"Filter unchecked links (no status data).","type":"string","default":"","required":false},"is_marked_safe":{"description":"Filter links marked as safe.","type":"string","default":"","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/links"}]}},"\/rankmath\/v1\/link-genius\/links\/(?P<id>\\d+)\/details":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Link ID.","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/delete":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"link_ids":{"description":"Link IDs to delete.","type":"array","required":false},"filters":{"description":"Filter criteria for selecting links to delete.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/delete"}]}},"\/rankmath\/v1\/link-genius\/undo-delete":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"description":"Post ID to restore.","type":"integer","required":true},"original_content":{"description":"Original post content to restore.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/undo-delete"}]}},"\/rankmath\/v1\/link-genius\/remove-nofollow":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"link_id":{"description":"Link ID to remove nofollow from.","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/remove-nofollow"}]}},"\/rankmath\/v1\/link-genius\/update":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"link_id":{"description":"Link ID to update.","type":"integer","required":true},"new_url":{"description":"New URL for the link.","type":"string","required":true},"new_anchor":{"description":"New anchor text for the link.","type":"string","required":true},"is_nofollow":{"description":"Whether the link should have nofollow attribute.","type":"integer","default":0,"required":false},"target_blank":{"description":"Whether the link should open in a new tab.","type":"integer","default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/update"}]}},"\/rankmath\/v1\/link-genius\/bulk-actions\/restore":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"batch_id":{"description":"Batch ID to restore from snapshots.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/bulk-actions\/restore"}]}},"\/rankmath\/v1\/link-genius\/link-suggestions":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"description":"Post ID.","type":"integer","required":true},"text":{"description":"Selected text used for suggestions.","type":"string","required":false},"current":{"description":"Current editor state summary.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/link-suggestions"}]}},"\/rankmath\/v1\/link-genius\/link-opportunities":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"description":"Post ID.","type":"integer","required":true},"current":{"description":"Current editor state summary.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/link-opportunities"}]}},"\/rankmath\/v1\/link-genius\/related-posts":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_id":{"description":"Post ID.","type":"integer","required":true},"current":{"description":"Current editor state summary.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/related-posts"}]}},"\/rankmath\/v1\/link-genius\/audit\/stats":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/audit\/stats"}]}},"\/rankmath\/v1\/link-genius\/audit\/start":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"filters":{"description":"Filters to apply (is_internal, unchecked_only, etc.).","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/audit\/start"}]}},"\/rankmath\/v1\/link-genius\/audit\/recheck":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"link_ids":{"description":"Array of link IDs to recheck.","type":"array","required":false},"filters":{"description":"Filter criteria for selecting links to recheck.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/audit\/recheck"}]}},"\/rankmath\/v1\/link-genius\/audit\/mark-safe":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"link_ids":{"description":"Link IDs to mark as safe.","type":"array","required":false},"reason":{"description":"Reason for marking as safe.","type":"string","required":false},"filters":{"description":"Filter criteria for selecting links to mark as safe.","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/audit\/mark-safe"}]}},"\/rankmath\/v1\/link-genius\/export":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"description":"Export type (links or posts).","type":"string","required":true},"format":{"description":"Export format (csv, json, excel).","type":"string","required":true},"filters":{"description":"Filters to apply to the export.","type":"object","required":false},"columns":{"description":"Column definitions.","type":"array","required":true},"total":{"description":"Total number of records to export.","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/export"}]}},"\/rankmath\/v1\/link-genius\/posts":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"required":false},"per_page":{"description":"Items per page.","type":"integer","default":50,"maximum":100,"required":false},"search":{"description":"Search in post title.","type":"string","default":"","required":false},"post_type":{"description":"Filter by post type. Supports multiple values.","type":"array","items":{"type":"string"},"default":[],"required":false},"is_orphan":{"description":"Filter by orphan status.","type":"string","default":"","required":false},"seo_score_range":{"description":"Filter by SEO score range.","type":"string","default":"","required":false},"orderby":{"description":"Order by field.","type":"string","default":"post_title","required":false},"order":{"description":"Order direction.","type":"string","default":"ASC","required":false},"min_incoming_links":{"description":"Minimum incoming links count filter.","type":"integer","default":0,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/posts"}]}},"\/rankmath\/v1\/link-genius\/posts-stats":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/posts-stats"}]}},"\/rankmath\/v1\/link-genius\/stats":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/stats"}]}},"\/rankmath\/v1\/link-genius\/regenerate":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/regenerate"}]}},"\/rankmath\/v1\/link-genius\/operations\/progress":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"operation":{"description":"Operation type.","type":"string","enum":["regenerate","audit","bulk_delete","bulk_mark_safe","bulk_restore","bulk_update_preview","bulk_update_apply","keyword_map_preview","keyword_map_apply","export"],"required":true},"id":{"description":"Optional operation ID (for keyword maps).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/operations\/progress"}]}},"\/rankmath\/v1\/link-genius\/operations\/cancel":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"operation":{"description":"Operation type to cancel.","type":"string","enum":["regenerate","audit","bulk_delete","bulk_mark_safe","bulk_restore","bulk_update_preview","bulk_update_apply","keyword_map_preview","keyword_map_apply","export"],"required":true},"id":{"description":"Optional operation ID (for keyword maps).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/operations\/cancel"}]}},"\/rankmath\/v1\/link-genius\/operations\/clear":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"operation":{"description":"Operation type to clear.","type":"string","enum":["regenerate","audit","bulk_delete","bulk_mark_safe","bulk_restore","bulk_update_preview","bulk_update_apply","keyword_map_preview","keyword_map_apply","export"],"required":true},"id":{"description":"Optional operation ID (for keyword maps).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/operations\/clear"}]}},"\/rankmath\/v1\/link-genius\/bulk-update\/preview":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"filters":{"description":"Search filters for finding links.","type":"object","required":true},"update_config":{"description":"Update configuration.","type":"object","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/bulk-update\/preview"}]}},"\/rankmath\/v1\/link-genius\/bulk-update\/preview\/results":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Number of items per page.","type":"integer","default":20,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/bulk-update\/preview\/results"}]}},"\/rankmath\/v1\/link-genius\/bulk-update\/history":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Number of items per page.","type":"integer","default":20,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/bulk-update\/history"}]}},"\/rankmath\/v1\/link-genius\/bulk-update\/history\/(?P<batch_id>[a-zA-Z0-9_]+)":{"namespace":"rankmath\/v1\/link-genius","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"batch_id":{"description":"Batch ID to delete.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/bulk-update\/apply":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"filters":{"description":"Search filters for finding links.","type":"object","required":true},"update_config":{"description":"Update configuration.","type":"object","required":true},"selected_link_ids":{"description":"Optional array of specific link IDs to update.","type":"array","items":{"type":"integer"},"required":false},"is_rollback":{"description":"Whether this is a rollback operation (prevents history creation).","type":"boolean","default":false,"required":false},"rollback_batch_id":{"description":"Batch ID being rolled back (for status update).","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/bulk-update\/apply"}]}},"\/rankmath\/v1\/link-genius\/bulk-update\/rollback":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"batch_id":{"description":"Batch ID to rollback.","type":"string","required":true},"selected_post_ids":{"description":"Optional array of specific post IDs to rollback.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/bulk-update\/rollback"}]}},"\/rankmath\/v1\/link-genius\/bulk-update\/changes\/(?P<batch_id>[a-zA-Z0-9_]+)":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"batch_id":{"description":"Batch ID.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/(?P<id>\\d+)\/preview":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/preview\/results":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Number of items per page.","type":"integer","default":20,"minimum":1,"maximum":100,"required":false},"keyword_map_id":{"description":"Keyword map ID.","type":"integer","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/keyword-maps\/preview\/results"}]}},"\/rankmath\/v1\/link-genius\/keyword-maps\/history":{"namespace":"rankmath\/v1\/link-genius","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Number of items per page.","type":"integer","default":20,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/keyword-maps\/history"}]}},"\/rankmath\/v1\/link-genius\/keyword-maps":{"namespace":"rankmath\/v1\/link-genius","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"Page number.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Number of items per page.","type":"integer","default":20,"minimum":1,"maximum":100,"required":false},"orderby":{"description":"Column to order by.","type":"string","default":"created_at","enum":["id","name","created_at","updated_at","last_executed_at","execution_count"],"required":false},"order":{"description":"Order direction.","type":"string","default":"DESC","enum":["ASC","DESC"],"required":false},"enabled":{"description":"Filter by enabled status.","type":"boolean","required":false},"search":{"description":"Search term.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"name":{"description":"Keyword map name.","type":"string","required":true},"description":{"description":"Keyword map description.","type":"string","required":false},"target_url":{"description":"Target URL.","type":"string","required":true},"is_enabled":{"description":"Whether the keyword map is enabled.","type":"boolean","default":true,"required":false},"max_links_per_post":{"description":"Maximum links per post.","type":"integer","default":3,"minimum":1,"required":false},"auto_link_on_publish":{"description":"Enable auto-linking on publish.","type":"boolean","default":false,"required":false},"case_sensitive":{"description":"Enable case-sensitive keyword matching.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/keyword-maps"}]}},"\/rankmath\/v1\/link-genius\/keyword-maps\/(?P<id>\\d+)":{"namespace":"rankmath\/v1\/link-genius","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"name":{"description":"Keyword map name.","type":"string","required":false},"description":{"description":"Keyword map description.","type":"string","required":false},"target_url":{"description":"Target URL.","type":"string","required":false},"is_enabled":{"description":"Whether the keyword map is enabled.","type":"boolean","default":true,"required":false},"max_links_per_post":{"description":"Maximum links per post.","type":"integer","default":3,"minimum":1,"required":false},"auto_link_on_publish":{"description":"Enable auto-linking on publish.","type":"boolean","default":false,"required":false},"case_sensitive":{"description":"Enable case-sensitive keyword matching.","type":"boolean","default":false,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/bulk-toggle":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"ids":{"description":"Array of keyword map IDs.","type":"array","items":{"type":"integer"},"required":true},"enabled":{"description":"New enabled status.","type":"boolean","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/keyword-maps\/bulk-toggle"}]}},"\/rankmath\/v1\/link-genius\/keyword-maps\/bulk-delete":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"ids":{"description":"Array of keyword map IDs.","type":"array","items":{"type":"integer"},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/keyword-maps\/bulk-delete"}]}},"\/rankmath\/v1\/link-genius\/keyword-maps\/(?P<id>\\d+)\/execute":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/(?P<id>\\d+)\/variations":{"namespace":"rankmath\/v1\/link-genius","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"variation":{"description":"Variation text.","type":"string","required":true},"source":{"description":"Variation source.","type":"string","default":"manual","enum":["manual","ai"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/variations\/(?P<id>\\d+)":{"namespace":"rankmath\/v1\/link-genius","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/(?P<id>\\d+)\/generate-variations":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/rankmath\/v1\/link-genius\/keyword-maps\/generate-variations":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyword":{"description":"Keyword to generate variations for.","type":"string","required":true},"context":{"description":"Optional context to help generate better variations.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/rankmath\/v1\/link-genius\/keyword-maps\/generate-variations"}]}},"\/rankmath\/v1\/link-genius\/keyword-maps\/(?P<id>\\d+)\/accept-variations":{"namespace":"rankmath\/v1\/link-genius","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"variations":{"description":"Array of variations to accept.","type":"array","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/google-site-kit\/v1":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"google-site-kit\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1"}]}},"\/google-site-kit\/v1\/core\/site\/data\/setup-tag":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/site\/data\/setup-tag"}]}},"\/google-site-kit\/v1\/core\/site\/data\/connection":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/site\/data\/connection"}]}},"\/google-site-kit\/v1\/core\/user\/data\/authentication":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/authentication"}]}},"\/google-site-kit\/v1\/core\/user\/data\/disconnect":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/disconnect"}]}},"\/google-site-kit\/v1\/core\/user\/data\/get-token":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/get-token"}]}},"\/google-site-kit\/v1\/core\/user\/data\/user-input-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"questions":{"purpose":{"type":"array","items":{"type":"string"}},"postFrequency":{"type":"array","items":{"type":"string"}},"goals":{"type":"array","items":{"type":"string"}},"includeConversionEvents":{"type":"array","items":{"type":"string"}}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/user-input-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/audience-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"configuredAudiences":{"type":"array","items":{"type":"string"}},"isAudienceSegmentationWidgetHidden":{"type":"boolean"},"didSetAudiences":{"type":"boolean"}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/audience-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/conversion-reporting-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"newEventsCalloutDismissedAt":{"type":"integer"},"lostEventsCalloutDismissedAt":{"type":"integer"}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/conversion-reporting-settings"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/list":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/list"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/activation":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/activation"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/info":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/info"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/check-access":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/check-access"}]}},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/notifications":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"data":{"type":"object","description":"Settings to set.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/data-available":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/(?P<datapoint>[a-z\\-]+)":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"datapoint":{"type":"string","description":"Module data point to address.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identifier for the module.","default":null,"required":false},"datapoint":{"type":"string","description":"Module data point to address.","default":null,"required":false},"data":{"type":"object","description":"Data to set.","default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/google-site-kit\/v1\/core\/modules\/data\/recover-modules":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/recover-modules"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/sharing-settings":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/sharing-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-items":{"namespace":"google-site-kit\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"data":{"type":"object","description":"","default":null,"minProperties":1,"additionalProperties":false,"properties":{"slugs":{"type":"array","required":true,"items":{"type":"string"}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-items"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-item":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-item"}]}},"\/google-site-kit\/v1\/core\/user\/data\/expirable-items":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/expirable-items"}]}},"\/google-site-kit\/v1\/core\/user\/data\/set-expirable-item-timers":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"array","description":"","default":null,"items":{"type":"object","additionalProperties":false,"properties":{"slug":{"type":"string","required":true},"expiration":{"type":"integer","required":true}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/set-expirable-item-timers"}]}},"\/google-site-kit\/v1\/core\/user\/data\/permissions":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/permissions"}]}},"\/google-site-kit\/v1\/core\/user\/data\/nonces":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/nonces"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-trigger":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"triggerID":{"type":"string","required":true},"ttl":{"type":"integer","minimum":0}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-trigger"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-event":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"session":{"type":"object","required":true,"properties":{"session_id":{"type":"string","required":true},"session_token":{"type":"string","required":true}}},"event":{"type":"object","required":true,"properties":{"survey_shown":{"type":"object"},"survey_closed":{"type":"object"},"question_answered":{"type":"object"},"completion_shown":{"type":"object"},"follow_up_link_clicked":{"type":"object"}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-event"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-timeouts":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-timeouts"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey"}]}},"\/google-site-kit\/v1\/core\/site\/data\/reset":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/site\/data\/reset"}]}},"\/google-site-kit\/v1\/core\/site\/data\/reset-persistent":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/site\/data\/reset-persistent"}]}},"\/google-site-kit\/v1\/core\/site\/data\/developer-plugin":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/site\/data\/developer-plugin"}]}},"\/google-site-kit\/v1\/core\/user\/data\/tracking":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"enabled":{"type":"boolean","required":true}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/tracking"}]}},"\/google-site-kit\/v1\/core\/search\/data\/entity-search":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"query":{"type":"string","description":"Text content to search for.","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/search\/data\/entity-search"}]}},"\/google-site-kit\/v1\/core\/site\/data\/admin-bar-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"enabled":{"type":"boolean","required":false}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/site\/data\/admin-bar-settings"}]}},"\/google-site-kit\/v1\/core\/site\/data\/notifications":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/site\/data\/notifications"}]}},"\/google-site-kit\/v1\/core\/site\/data\/mark-notification":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/site\/data\/mark-notification"}]}},"\/google-site-kit\/v1\/core\/site\/data\/site-health-tag-placement-test":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/site\/data\/site-health-tag-placement-test"}]}},"\/google-site-kit\/v1\/core\/site\/data\/health-checks":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/site\/data\/health-checks"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-tours":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-tours"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-tour":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-tour"}]}},"\/google-site-kit\/v1\/core\/user\/data\/key-metrics":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"properties":{"isWidgetHidden":{"type":"boolean","required":true},"widgetSlugs":{"type":"array","required":false,"maxItems":8,"items":{"type":"string"}}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/key-metrics"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-prompts":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-prompts"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-prompt":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-prompt"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-mode":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"enabled":{"type":"boolean"},"regions":{"type":"array","items":{"type":"string"}}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-mode"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-api-info":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-api-info"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-api-activate":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-api-activate"}]}},"\/google-site-kit\/v1\/core\/site\/data\/ads-measurement-status":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/site\/data\/ads-measurement-status"}]}},"\/google-site-kit\/v1\/core\/site\/data\/conversion-tracking":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"properties":{"enabled":{"type":"boolean","required":true}}}},"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/google-site-kit\/v1\/core\/site\/data\/conversion-tracking"}]}},"\/wpmudev_pcs\/v1":{"namespace":"wpmudev_pcs\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpmudev_pcs\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpmudev_pcs\/v1"}]}},"\/wpmudev_pcs\/v1\/plugincrosssell\/install_plugin":{"namespace":"wpmudev_pcs\/v1","methods":["POST","PUT","PATCH","POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"plugin_slug":{"type":"string","required":true},"current_slug":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"plugin_slug":{"type":"string","required":true},"current_slug":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpmudev_pcs\/v1\/plugincrosssell\/install_plugin"}]}},"\/wpmudev_pcs\/v1\/plugincrosssell\/activate_plugin":{"namespace":"wpmudev_pcs\/v1","methods":["POST","PUT","PATCH","POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"plugin_slug":{"type":"string","required":true},"current_slug":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"plugin_slug":{"type":"string","required":true},"current_slug":{"type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpmudev_pcs\/v1\/plugincrosssell\/activate_plugin"}]}},"\/wpmudev_blc\/v1":{"namespace":"wpmudev_blc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wpmudev_blc\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpmudev_blc\/v1"}]}},"\/wpmudev_blc\/v1\/avatars":{"namespace":"wpmudev_blc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpmudev_blc\/v1\/avatars"}]}},"\/wpmudev_blc\/v1\/scan":{"namespace":"wpmudev_blc\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpmudev_blc\/v1\/scan"}]}},"\/wpmudev_blc\/v1\/settings":{"namespace":"wpmudev_blc\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wpmudev_blc\/v1\/settings"}]}},"\/regenerate-thumbnails\/v1":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"regenerate-thumbnails\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/regenerate-thumbnails\/v1"}]}},"\/regenerate-thumbnails\/v1\/regenerate\/(?P<id>[\\d]+)":{"namespace":"regenerate-thumbnails\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"only_regenerate_missing_thumbnails":{"description":"F\u00fcggetlen\u00fcl, hogy csak a hi\u00e1nyz\u00f3 miniat\u0171r\u00f6ket gener\u00e1lja \u00fajra. Gyorsabb, ha ez enged\u00e9lyezve van.","type":"boolean","default":true,"required":false},"delete_unregistered_thumbnail_files":{"description":"F\u00fcggetlen\u00fcl, hogy t\u00f6rli b\u00e1rmely r\u00e9ig, most nem regisztr\u00e1lt miniat\u0171r f\u00e1jlt.","type":"boolean","default":false,"required":false},"update_usages_in_posts":{"description":"F\u00fcggetlen\u00fcl att\u00f3l, hogy friss\u00edti-e a k\u00e9pc\u00edmk\u00e9ket a mell\u00e9kletben szerepl\u0151 \u00f6sszes bejegyz\u00e9shez.","type":"boolean","default":true,"required":false},"update_usages_in_posts_post_type":{"description":"Friss\u00edtend\u0151 bejegyz\u00e9st\u00edpusok. Alap\u00e9rtelmez\u00e9sben az \u00f6sszes nyilv\u00e1nos bejegyz\u00e9st\u00edpus.","type":"array","default":[],"required":false},"update_usages_in_posts_post_ids":{"description":"Specifikus frisstend\u0151 bejegyz\u00e9s IDk, nem pedig a bejegyz\u00e9sek, melyek a csatolm\u00e1nyt hasnz\u00e1lj\u00e1k.","type":"array","default":[],"required":false},"update_usages_in_posts_posts_per_loop":{"description":"Bejegyz\u00e9sek sz\u00e1ma menetenk\u00e9nt. Ez ir\u00e1ny\u00edtja a mem\u00f3ria haszn\u00e1latot \u00e9s \u00e1ltal\u00e1ban nem kell m\u00f3dos\u00edtani.","type":"integer","default":10,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/regenerate-thumbnails\/v1\/attachmentinfo\/(?P<id>[\\d]+)":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/regenerate-thumbnails\/v1\/featuredimages":{"namespace":"regenerate-thumbnails\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/regenerate-thumbnails\/v1\/featuredimages"}]}},"\/otgs\/installer\/v1":{"namespace":"otgs\/installer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"otgs\/installer\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/otgs\/installer\/v1"}]}},"\/otgs\/installer\/v1\/push\/fetch-subscription":{"namespace":"otgs\/installer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/otgs\/installer\/v1\/push\/fetch-subscription"}]}},"\/mcp":{"namespace":"mcp","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"mcp","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/mcp"}]}},"\/mcp\/mcp-oauth-server":{"namespace":"mcp","methods":["POST","GET","DELETE"],"endpoints":[{"methods":["POST","GET","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/mcp\/mcp-oauth-server"}]}},"\/mcp\/mcp-adapter-default-server":{"namespace":"mcp","methods":["POST","GET","DELETE"],"endpoints":[{"methods":["POST","GET","DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/mcp\/mcp-adapter-default-server"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"after":{"description":"Hozz\u00e1sz\u00f3l\u00e1sok korl\u00e1toz\u00e1sa a megadott ISO8601 form\u00e1tum\u00fa d\u00e1tum ut\u00e1n k\u00f6zz\u00e9tett bejegyz\u00e9sek eset\u00e9n.","type":"string","format":"date-time","required":false},"modified_after":{"description":"A v\u00e1lasz korl\u00e1toz\u00e1sa a megadott ISO8601 d\u00e1tum ut\u00e1n m\u00f3dos\u00edtott posztokra.","type":"string","format":"date-time","required":false},"author":{"description":"Korl\u00e1tozzuk az eredm\u00e9nyk\u00e9szletet bizonyos szerz\u0151kh\u00f6z rendelt bejegyz\u00e9sekre.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Biztos\u00edtsuk, hogy az eredm\u00e9nyk\u00e9szletben nem szerepelnek bizonyos szerz\u0151kt\u0151l sz\u00e1rmaz\u00f3 bejegyz\u00e9sek.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Korl\u00e1tozza a v\u00e1laszt egy adott ISO8601 form\u00e1tum\u00fa d\u00e1tumot megel\u0151z\u0151en k\u00f6zz\u00e9tett bejegyz\u00e9sekre.","type":"string","format":"date-time","required":false},"modified_before":{"description":"A v\u00e1lasz korl\u00e1toz\u00e1sa a megadott ISO8601 d\u00e1tum el\u0151tt m\u00f3dos\u00edtott posztokra.","type":"string","format":"date-time","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Hogyan kell \u00e9rtelmezni a keres\u00e9si bemenetet.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Gy\u0171jtem\u00e9ny rendez\u00e9se a bejegyz\u00e9st tulajdons\u00e1g szerint.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"A keresend\u0151 oszlopnevek t\u00f6mbje.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Korl\u00e1tozza az eredm\u00e9ny k\u00e9szletet az egy vagy t\u00f6bb meghat\u00e1rozott keres\u0151bar\u00e1t n\u00e9vvel rendelkez\u0151 bejegyz\u00e9sekre.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Korl\u00e1tozza az eredm\u00e9ny k\u00e9szletet az egy vagy t\u00f6bb \u00e1llapothoz rendelt bejegyz\u00e9sekhez.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Az eredm\u00e9nyk\u00e9szlet korl\u00e1toz\u00e1sa a t\u00f6bb taxon\u00f3mi\u00e1s kapcsolatokban","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Az eredm\u00e9nyhalmaz korl\u00e1toz\u00e1sa a categories kateg\u00f3ri\u00e1hoz t\u00e1rs\u00edtott kifejez\u00e9sekkel.","type":["object","array"],"oneOf":[{"title":"Kifejez\u00e9s ID Lista","description":"Kifejez\u00e9sek egyez\u00e9se a list\u00e1ban felsorolt ID-kkel.","type":"array","items":{"type":"integer"}},{"title":"Kateg\u00f3ria azonos\u00edt\u00f3 lek\u00e9rdez\u00e9s - ID ","description":"Lek\u00e9rdez\u00e9s egy \u00f6sszetett kifejez\u00e9ssel. ","type":"object","properties":{"terms":{"description":"Kifejez\u00e9s ID-k.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"A gyermekkifejez\u00e9sek bet\u00f6lt\u00e9se az eredm\u00e9nynhalmazt sz\u0171r\u0151 kifejez\u00e9sekbe.","type":"boolean","default":false},"operator":{"description":"Azt, hogy az elemekhez hozz\u00e1 kell-e rendelni a megadott felt\u00e9telek mindegyik\u00e9t vagy valamelyik\u00e9t.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Korl\u00e1tozzuk az eredm\u00e9nyhalmazt az \u00f6sszes olyan elemre, amely rendelkezik categories taxon\u00f3mi\u00e1hoz t\u00e1rs\u00edtott kifejez\u00e9ssel.","type":["object","array"],"oneOf":[{"title":"Kifejez\u00e9s ID Lista","description":"Kifejez\u00e9sek egyez\u00e9se a list\u00e1ban felsorolt ID-kkel.","type":"array","items":{"type":"integer"}},{"title":"Kateg\u00f3ria azonos\u00edt\u00f3 lek\u00e9rdez\u00e9s - ID ","description":"Lek\u00e9rdez\u00e9s egy \u00f6sszetett kifejez\u00e9ssel. ","type":"object","properties":{"terms":{"description":"Kifejez\u00e9s ID-k.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"A gyermekkifejez\u00e9sek bet\u00f6lt\u00e9se az eredm\u00e9nynhalmazt sz\u0171r\u0151 kifejez\u00e9sekbe.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Az eredm\u00e9nyhalmaz korl\u00e1toz\u00e1sa a tags kateg\u00f3ri\u00e1hoz t\u00e1rs\u00edtott kifejez\u00e9sekkel.","type":["object","array"],"oneOf":[{"title":"Kifejez\u00e9s ID Lista","description":"Kifejez\u00e9sek egyez\u00e9se a list\u00e1ban felsorolt ID-kkel.","type":"array","items":{"type":"integer"}},{"title":"Kateg\u00f3ria azonos\u00edt\u00f3 lek\u00e9rdez\u00e9s - ID ","description":"Lek\u00e9rdez\u00e9s egy \u00f6sszetett kifejez\u00e9ssel. ","type":"object","properties":{"terms":{"description":"Kifejez\u00e9s ID-k.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Azt, hogy az elemekhez hozz\u00e1 kell-e rendelni a megadott felt\u00e9telek mindegyik\u00e9t vagy valamelyik\u00e9t.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Korl\u00e1tozzuk az eredm\u00e9nyhalmazt az \u00f6sszes olyan elemre, amely rendelkezik tags taxon\u00f3mi\u00e1hoz t\u00e1rs\u00edtott kifejez\u00e9ssel.","type":["object","array"],"oneOf":[{"title":"Kifejez\u00e9s ID Lista","description":"Kifejez\u00e9sek egyez\u00e9se a list\u00e1ban felsorolt ID-kkel.","type":"array","items":{"type":"integer"}},{"title":"Kateg\u00f3ria azonos\u00edt\u00f3 lek\u00e9rdez\u00e9s - ID ","description":"Lek\u00e9rdez\u00e9s egy \u00f6sszetett kifejez\u00e9ssel. ","type":"object","properties":{"terms":{"description":"Kifejez\u00e9s ID-k.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Hat\u00e1rozzuk meg a maxim\u00e1lisan megjelen\u00edtett kiemelt elemek sz\u00e1m\u00e1t.","type":"boolean","required":false},"ignore_sticky":{"description":"Hagyjuk-e figyelmen k\u00edv\u00fcl a ragad\u00f3s bejegyz\u00e9seket, vagy ne.","type":"boolean","default":true,"required":false},"format":{"description":"Az eredm\u00e9nyk\u00e9szlet korl\u00e1toz\u00e1sa az egy vagy t\u00f6bb megadott form\u00e1tumhoz rendelt elemre.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"A bejegyz\u00e9s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Az bejegyz\u00e9s publik\u00e1l\u00e1s\u00e1nak id\u0151pontja GMT szerinti.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"A bejegyz\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"status":{"description":"A bejegyz\u00e9s elnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Egy jelsz\u00f3 a tartalom \u00e9s a kivonat v\u00e9delm\u00e9hez.","type":"string","required":false},"title":{"description":"A bejegyz\u00e9s c\u00edme.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s c\u00edme, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML c\u00edme, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"A bejegyz\u00e9s tartalma.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s tartalma, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML tartalma, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"A bejegyz\u00e9s \u00e1ltal haszn\u00e1lt tartalom blokk verzi\u00f3ja.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Amennyiben a tartalom jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"A bejegyz\u00e9s szerz\u0151j\u00e9nek azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"excerpt":{"description":"A bejegyz\u00e9s kivonata.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s kivonata, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML kivonata, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Amennyiben a kivonat jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"A bejegyz\u00e9s kiemelt m\u00e9dia azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"comment_status":{"description":"A bejegyz\u00e9sen hozz\u00e1sz\u00f3l\u00e1sok enged\u00e9lyezettek legyenek-e.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"A bejegyz\u00e9s pingelhet\u0151 legyen-e.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"A bejegyz\u00e9s form\u00e1tuma.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"A bejegyz\u00e9st kiemeltk\u00e9nt legyen-e kezelve.","type":"boolean","required":false},"template":{"description":"A bejegyz\u00e9s megjelen\u00edt\u00e9s\u00e9hez haszn\u00e1lt sablon f\u00e1jl.","type":"string","required":false},"categories":{"description":"A bejegyz\u00e9shez rendelt kifejez\u00e9sek a category oszt\u00e1lyoz\u00e1sban.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"A bejegyz\u00e9shez rendelt kifejez\u00e9sek a post_tag oszt\u00e1lyoz\u00e1sban.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Az alap\u00e9rtelmezett kivonathossz fel\u00fclb\u00edr\u00e1l\u00e1sa.","type":"integer","required":false},"password":{"description":"A jelsz\u00f3 a bejegyz\u00e9shez, ha az jelsz\u00f3val v\u00e9dett.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"date":{"description":"A bejegyz\u00e9s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Az bejegyz\u00e9s publik\u00e1l\u00e1s\u00e1nak id\u0151pontja GMT szerinti.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"A bejegyz\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"status":{"description":"A bejegyz\u00e9s elnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Egy jelsz\u00f3 a tartalom \u00e9s a kivonat v\u00e9delm\u00e9hez.","type":"string","required":false},"title":{"description":"A bejegyz\u00e9s c\u00edme.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s c\u00edme, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML c\u00edme, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"A bejegyz\u00e9s tartalma.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s tartalma, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML tartalma, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"A bejegyz\u00e9s \u00e1ltal haszn\u00e1lt tartalom blokk verzi\u00f3ja.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Amennyiben a tartalom jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"A bejegyz\u00e9s szerz\u0151j\u00e9nek azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"excerpt":{"description":"A bejegyz\u00e9s kivonata.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s kivonata, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML kivonata, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Amennyiben a kivonat jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"A bejegyz\u00e9s kiemelt m\u00e9dia azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"comment_status":{"description":"A bejegyz\u00e9sen hozz\u00e1sz\u00f3l\u00e1sok enged\u00e9lyezettek legyenek-e.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"A bejegyz\u00e9s pingelhet\u0151 legyen-e.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"A bejegyz\u00e9s form\u00e1tuma.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"A bejegyz\u00e9st kiemeltk\u00e9nt legyen-e kezelve.","type":"boolean","required":false},"template":{"description":"A bejegyz\u00e9s megjelen\u00edt\u00e9s\u00e9hez haszn\u00e1lt sablon f\u00e1jl.","type":"string","required":false},"categories":{"description":"A bejegyz\u00e9shez rendelt kifejez\u00e9sek a category oszt\u00e1lyoz\u00e1sban.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"A bejegyz\u00e9shez rendelt kifejez\u00e9sek a post_tag oszt\u00e1lyoz\u00e1sban.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Hagyjuk-e ki a Lomt\u00e1rat, \u00e9s t\u00f6r\u00f6lj\u00fcnk egyb\u0151l.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"A v\u00e1ltozat sz\u00fcl\u0151j\u00e9ne az azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Gy\u0171jtem\u00e9ny rendez\u00e9se objektum tulajdons\u00e1g szerint.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"A v\u00e1ltozat sz\u00fcl\u0151j\u00e9ne az azonos\u00edt\u00f3ja.","type":"integer","required":false},"id":{"description":"A v\u00e1ltozat egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"A v\u00e1ltozat sz\u00fcl\u0151j\u00e9ne az azonos\u00edt\u00f3ja.","type":"integer","required":false},"id":{"description":"A v\u00e1ltozat egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Igaznak kell lennie, mert a v\u00e1ltozatokat nem lehet lomt\u00e1rba helyezni.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Az automatikus ment\u00e9s sz\u00fcl\u0151j\u00e9nek azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Az automatikus ment\u00e9s sz\u00fcl\u0151j\u00e9nek azonos\u00edt\u00f3ja.","type":"integer","required":false},"date":{"description":"A bejegyz\u00e9s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Az bejegyz\u00e9s publik\u00e1l\u00e1s\u00e1nak id\u0151pontja GMT szerinti.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"A bejegyz\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"status":{"description":"A bejegyz\u00e9s elnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Egy jelsz\u00f3 a tartalom \u00e9s a kivonat v\u00e9delm\u00e9hez.","type":"string","required":false},"title":{"description":"A bejegyz\u00e9s c\u00edme.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s c\u00edme, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML c\u00edme, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"A bejegyz\u00e9s tartalma.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s tartalma, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML tartalma, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"A bejegyz\u00e9s \u00e1ltal haszn\u00e1lt tartalom blokk verzi\u00f3ja.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Amennyiben a tartalom jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"A bejegyz\u00e9s szerz\u0151j\u00e9nek azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"excerpt":{"description":"A bejegyz\u00e9s kivonata.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s kivonata, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML kivonata, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Amennyiben a kivonat jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"A bejegyz\u00e9s kiemelt m\u00e9dia azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"comment_status":{"description":"A bejegyz\u00e9sen hozz\u00e1sz\u00f3l\u00e1sok enged\u00e9lyezettek legyenek-e.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"A bejegyz\u00e9s pingelhet\u0151 legyen-e.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"A bejegyz\u00e9s form\u00e1tuma.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"A bejegyz\u00e9st kiemeltk\u00e9nt legyen-e kezelve.","type":"boolean","required":false},"template":{"description":"A bejegyz\u00e9s megjelen\u00edt\u00e9s\u00e9hez haszn\u00e1lt sablon f\u00e1jl.","type":"string","required":false},"categories":{"description":"A bejegyz\u00e9shez rendelt kifejez\u00e9sek a category oszt\u00e1lyoz\u00e1sban.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"A bejegyz\u00e9shez rendelt kifejez\u00e9sek a post_tag oszt\u00e1lyoz\u00e1sban.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Az automatikus ment\u00e9s sz\u00fcl\u0151j\u00e9nek azonos\u00edt\u00f3ja.","type":"integer","required":false},"id":{"description":"Az ID  az automatikus ment\u00e9shez.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"after":{"description":"Hozz\u00e1sz\u00f3l\u00e1sok korl\u00e1toz\u00e1sa a megadott ISO8601 form\u00e1tum\u00fa d\u00e1tum ut\u00e1n k\u00f6zz\u00e9tett bejegyz\u00e9sek eset\u00e9n.","type":"string","format":"date-time","required":false},"modified_after":{"description":"A v\u00e1lasz korl\u00e1toz\u00e1sa a megadott ISO8601 d\u00e1tum ut\u00e1n m\u00f3dos\u00edtott posztokra.","type":"string","format":"date-time","required":false},"author":{"description":"Korl\u00e1tozzuk az eredm\u00e9nyk\u00e9szletet bizonyos szerz\u0151kh\u00f6z rendelt bejegyz\u00e9sekre.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Biztos\u00edtsuk, hogy az eredm\u00e9nyk\u00e9szletben nem szerepelnek bizonyos szerz\u0151kt\u0151l sz\u00e1rmaz\u00f3 bejegyz\u00e9sek.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Korl\u00e1tozza a v\u00e1laszt egy adott ISO8601 form\u00e1tum\u00fa d\u00e1tumot megel\u0151z\u0151en k\u00f6zz\u00e9tett bejegyz\u00e9sekre.","type":"string","format":"date-time","required":false},"modified_before":{"description":"A v\u00e1lasz korl\u00e1toz\u00e1sa a megadott ISO8601 d\u00e1tum el\u0151tt m\u00f3dos\u00edtott posztokra.","type":"string","format":"date-time","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Korl\u00e1tozza az eredm\u00e9nyhalmazt meghat\u00e1rozott menu_order \u00e9rt\u00e9kkel rendelkez\u0151 bejegyz\u00e9sekre.","type":"integer","required":false},"search_semantics":{"description":"Hogyan kell \u00e9rtelmezni a keres\u00e9si bemenetet.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Gy\u0171jtem\u00e9ny rendez\u00e9se a bejegyz\u00e9st tulajdons\u00e1g szerint.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Korl\u00e1tozzuk az eredm\u00e9nyk\u00e9szletet meghat\u00e1rozott sz\u00fcl\u0151kkel rendelkez\u0151 elemekre.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Korl\u00e1tozza az eredm\u00e9nyhalmazt minden elemre, kiv\u00e9ve egy adott sz\u00fcl\u0151 azonos\u00edt\u00f3hoz tartoz\u00f3 elemeket.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"A keresend\u0151 oszlopnevek t\u00f6mbje.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Korl\u00e1tozza az eredm\u00e9ny k\u00e9szletet az egy vagy t\u00f6bb meghat\u00e1rozott keres\u0151bar\u00e1t n\u00e9vvel rendelkez\u0151 bejegyz\u00e9sekre.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Korl\u00e1tozza az eredm\u00e9ny k\u00e9szletet az egy vagy t\u00f6bb \u00e1llapothoz rendelt bejegyz\u00e9sekhez.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"A bejegyz\u00e9s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Az bejegyz\u00e9s publik\u00e1l\u00e1s\u00e1nak id\u0151pontja GMT szerinti.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"A bejegyz\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"status":{"description":"A bejegyz\u00e9s elnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Egy jelsz\u00f3 a tartalom \u00e9s a kivonat v\u00e9delm\u00e9hez.","type":"string","required":false},"parent":{"description":"A sz\u00fcl\u0151-bejegyz\u00e9s azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"title":{"description":"A bejegyz\u00e9s c\u00edme.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s c\u00edme, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML c\u00edme, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"A bejegyz\u00e9s tartalma.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s tartalma, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML tartalma, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"A bejegyz\u00e9s \u00e1ltal haszn\u00e1lt tartalom blokk verzi\u00f3ja.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Amennyiben a tartalom jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"A bejegyz\u00e9s szerz\u0151j\u00e9nek azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"excerpt":{"description":"A bejegyz\u00e9s kivonata.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s kivonata, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML kivonata, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Amennyiben a kivonat jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"A bejegyz\u00e9s kiemelt m\u00e9dia azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"comment_status":{"description":"A bejegyz\u00e9sen hozz\u00e1sz\u00f3l\u00e1sok enged\u00e9lyezettek legyenek-e.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"A bejegyz\u00e9s pingelhet\u0151 legyen-e.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"A bejegyz\u00e9s sorrendje m\u00e1s bejegyz\u00e9sekhez viszony\u00edtva.","type":"integer","required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"A bejegyz\u00e9s megjelen\u00edt\u00e9s\u00e9hez haszn\u00e1lt sablon f\u00e1jl.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Az alap\u00e9rtelmezett kivonathossz fel\u00fclb\u00edr\u00e1l\u00e1sa.","type":"integer","required":false},"password":{"description":"A jelsz\u00f3 a bejegyz\u00e9shez, ha az jelsz\u00f3val v\u00e9dett.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"date":{"description":"A bejegyz\u00e9s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Az bejegyz\u00e9s publik\u00e1l\u00e1s\u00e1nak id\u0151pontja GMT szerinti.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"A bejegyz\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"status":{"description":"A bejegyz\u00e9s elnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Egy jelsz\u00f3 a tartalom \u00e9s a kivonat v\u00e9delm\u00e9hez.","type":"string","required":false},"parent":{"description":"A sz\u00fcl\u0151-bejegyz\u00e9s azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"title":{"description":"A bejegyz\u00e9s c\u00edme.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s c\u00edme, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML c\u00edme, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"A bejegyz\u00e9s tartalma.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s tartalma, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML tartalma, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"A bejegyz\u00e9s \u00e1ltal haszn\u00e1lt tartalom blokk verzi\u00f3ja.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Amennyiben a tartalom jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"A bejegyz\u00e9s szerz\u0151j\u00e9nek azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"excerpt":{"description":"A bejegyz\u00e9s kivonata.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s kivonata, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML kivonata, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Amennyiben a kivonat jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"A bejegyz\u00e9s kiemelt m\u00e9dia azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"comment_status":{"description":"A bejegyz\u00e9sen hozz\u00e1sz\u00f3l\u00e1sok enged\u00e9lyezettek legyenek-e.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"A bejegyz\u00e9s pingelhet\u0151 legyen-e.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"A bejegyz\u00e9s sorrendje m\u00e1s bejegyz\u00e9sekhez viszony\u00edtva.","type":"integer","required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"A bejegyz\u00e9s megjelen\u00edt\u00e9s\u00e9hez haszn\u00e1lt sablon f\u00e1jl.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Hagyjuk-e ki a Lomt\u00e1rat, \u00e9s t\u00f6r\u00f6lj\u00fcnk egyb\u0151l.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"A v\u00e1ltozat sz\u00fcl\u0151j\u00e9ne az azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Gy\u0171jtem\u00e9ny rendez\u00e9se objektum tulajdons\u00e1g szerint.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"A v\u00e1ltozat sz\u00fcl\u0151j\u00e9ne az azonos\u00edt\u00f3ja.","type":"integer","required":false},"id":{"description":"A v\u00e1ltozat egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"A v\u00e1ltozat sz\u00fcl\u0151j\u00e9ne az azonos\u00edt\u00f3ja.","type":"integer","required":false},"id":{"description":"A v\u00e1ltozat egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Igaznak kell lennie, mert a v\u00e1ltozatokat nem lehet lomt\u00e1rba helyezni.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Az automatikus ment\u00e9s sz\u00fcl\u0151j\u00e9nek azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"A sz\u00fcl\u0151-bejegyz\u00e9s azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"date":{"description":"A bejegyz\u00e9s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Az bejegyz\u00e9s publik\u00e1l\u00e1s\u00e1nak id\u0151pontja GMT szerinti.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"A bejegyz\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"status":{"description":"A bejegyz\u00e9s elnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Egy jelsz\u00f3 a tartalom \u00e9s a kivonat v\u00e9delm\u00e9hez.","type":"string","required":false},"title":{"description":"A bejegyz\u00e9s c\u00edme.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s c\u00edme, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML c\u00edme, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"A bejegyz\u00e9s tartalma.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s tartalma, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML tartalma, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"A bejegyz\u00e9s \u00e1ltal haszn\u00e1lt tartalom blokk verzi\u00f3ja.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Amennyiben a tartalom jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"A bejegyz\u00e9s szerz\u0151j\u00e9nek azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"excerpt":{"description":"A bejegyz\u00e9s kivonata.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s kivonata, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML kivonata, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Amennyiben a kivonat jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"A bejegyz\u00e9s kiemelt m\u00e9dia azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"comment_status":{"description":"A bejegyz\u00e9sen hozz\u00e1sz\u00f3l\u00e1sok enged\u00e9lyezettek legyenek-e.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"A bejegyz\u00e9s pingelhet\u0151 legyen-e.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"A bejegyz\u00e9s sorrendje m\u00e1s bejegyz\u00e9sekhez viszony\u00edtva.","type":"integer","required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"A bejegyz\u00e9s megjelen\u00edt\u00e9s\u00e9hez haszn\u00e1lt sablon f\u00e1jl.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Az automatikus ment\u00e9s sz\u00fcl\u0151j\u00e9nek azonos\u00edt\u00f3ja.","type":"integer","required":false},"id":{"description":"Az ID  az automatikus ment\u00e9shez.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"after":{"description":"Hozz\u00e1sz\u00f3l\u00e1sok korl\u00e1toz\u00e1sa a megadott ISO8601 form\u00e1tum\u00fa d\u00e1tum ut\u00e1n k\u00f6zz\u00e9tett bejegyz\u00e9sek eset\u00e9n.","type":"string","format":"date-time","required":false},"modified_after":{"description":"A v\u00e1lasz korl\u00e1toz\u00e1sa a megadott ISO8601 d\u00e1tum ut\u00e1n m\u00f3dos\u00edtott posztokra.","type":"string","format":"date-time","required":false},"author":{"description":"Korl\u00e1tozzuk az eredm\u00e9nyk\u00e9szletet bizonyos szerz\u0151kh\u00f6z rendelt bejegyz\u00e9sekre.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Biztos\u00edtsuk, hogy az eredm\u00e9nyk\u00e9szletben nem szerepelnek bizonyos szerz\u0151kt\u0151l sz\u00e1rmaz\u00f3 bejegyz\u00e9sek.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Korl\u00e1tozza a v\u00e1laszt egy adott ISO8601 form\u00e1tum\u00fa d\u00e1tumot megel\u0151z\u0151en k\u00f6zz\u00e9tett bejegyz\u00e9sekre.","type":"string","format":"date-time","required":false},"modified_before":{"description":"A v\u00e1lasz korl\u00e1toz\u00e1sa a megadott ISO8601 d\u00e1tum el\u0151tt m\u00f3dos\u00edtott posztokra.","type":"string","format":"date-time","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Hogyan kell \u00e9rtelmezni a keres\u00e9si bemenetet.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Gy\u0171jtem\u00e9ny rendez\u00e9se a bejegyz\u00e9st tulajdons\u00e1g szerint.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Korl\u00e1tozzuk az eredm\u00e9nyk\u00e9szletet meghat\u00e1rozott sz\u00fcl\u0151kkel rendelkez\u0151 elemekre.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Korl\u00e1tozza az eredm\u00e9nyhalmazt minden elemre, kiv\u00e9ve egy adott sz\u00fcl\u0151 azonos\u00edt\u00f3hoz tartoz\u00f3 elemeket.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"A keresend\u0151 oszlopnevek t\u00f6mbje.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Korl\u00e1tozza az eredm\u00e9ny k\u00e9szletet az egy vagy t\u00f6bb meghat\u00e1rozott keres\u0151bar\u00e1t n\u00e9vvel rendelkez\u0151 bejegyz\u00e9sekre.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Korl\u00e1tozza az eredm\u00e9ny k\u00e9szletet az egy vagy t\u00f6bb \u00e1llapothoz rendelt bejegyz\u00e9sekhez.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Limit result set to attachments of a particular media type or media types.","type":"array","items":{"type":"string","enum":["image","video","text","application","audio"]},"required":false},"mime_type":{"default":null,"description":"Limit result set to attachments of a particular MIME type or MIME types.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"date":{"description":"A bejegyz\u00e9s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Az bejegyz\u00e9s publik\u00e1l\u00e1s\u00e1nak id\u0151pontja GMT szerinti.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"A bejegyz\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"status":{"description":"A bejegyz\u00e9s elnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"A bejegyz\u00e9s c\u00edme.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s c\u00edme, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML c\u00edme, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"A bejegyz\u00e9s szerz\u0151j\u00e9nek azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"featured_media":{"description":"A bejegyz\u00e9s kiemelt m\u00e9dia azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"comment_status":{"description":"A bejegyz\u00e9sen hozz\u00e1sz\u00f3l\u00e1sok enged\u00e9lyezettek legyenek-e.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"A bejegyz\u00e9s pingelhet\u0151 legyen-e.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"A bejegyz\u00e9s megjelen\u00edt\u00e9s\u00e9hez haszn\u00e1lt sablon f\u00e1jl.","type":"string","required":false},"smush":{"description":"Smush data.","type":"string","required":false},"alt_text":{"description":"Alternat\u00edv sz\u00f6veg mutat\u00e1sa, amikor a csatolm\u00e1ny nem l\u00e1tszik.","type":"string","required":false},"caption":{"description":"A csatolm\u00e1ny felirata.","type":"object","properties":{"raw":{"description":"A csatolm\u00e1ny felirata, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A csatolm\u00e1ny HTML felirata, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"A csatolm\u00e1ny le\u00edr\u00e1sa.","type":"object","properties":{"raw":{"description":"A csatolm\u00e1ny le\u00edr\u00e1sa, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A csatolm\u00e1ny HTML le\u00edr\u00e1sa, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"A csatolm\u00e1nyhoz kapcsol\u00f3d\u00f3 bejegyz\u00e9s azonos\u00edt\u00f3ja.","type":"integer","required":false},"generate_sub_sizes":{"type":"boolean","default":true,"description":"Whether to generate image sub sizes.","required":false},"convert_format":{"type":"boolean","default":true,"description":"Whether to convert image formats.","required":false},"url":{"type":"string","format":"uri","description":"URL of an external image to sideload into the media library, instead of uploading a file.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"date":{"description":"A bejegyz\u00e9s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Az bejegyz\u00e9s publik\u00e1l\u00e1s\u00e1nak id\u0151pontja GMT szerinti.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"A bejegyz\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"status":{"description":"A bejegyz\u00e9s elnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"A bejegyz\u00e9s c\u00edme.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s c\u00edme, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML c\u00edme, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"A bejegyz\u00e9s szerz\u0151j\u00e9nek azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"featured_media":{"description":"A bejegyz\u00e9s kiemelt m\u00e9dia azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"comment_status":{"description":"A bejegyz\u00e9sen hozz\u00e1sz\u00f3l\u00e1sok enged\u00e9lyezettek legyenek-e.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"A bejegyz\u00e9s pingelhet\u0151 legyen-e.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false}},"required":false},"template":{"description":"A bejegyz\u00e9s megjelen\u00edt\u00e9s\u00e9hez haszn\u00e1lt sablon f\u00e1jl.","type":"string","required":false},"smush":{"description":"Smush data.","type":"string","required":false},"alt_text":{"description":"Alternat\u00edv sz\u00f6veg mutat\u00e1sa, amikor a csatolm\u00e1ny nem l\u00e1tszik.","type":"string","required":false},"caption":{"description":"A csatolm\u00e1ny felirata.","type":"object","properties":{"raw":{"description":"A csatolm\u00e1ny felirata, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A csatolm\u00e1ny HTML felirata, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"A csatolm\u00e1ny le\u00edr\u00e1sa.","type":"object","properties":{"raw":{"description":"A csatolm\u00e1ny le\u00edr\u00e1sa, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A csatolm\u00e1ny HTML le\u00edr\u00e1sa, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"A csatolm\u00e1nyhoz kapcsol\u00f3d\u00f3 bejegyz\u00e9s azonos\u00edt\u00f3ja.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Hagyjuk-e ki a Lomt\u00e1rat, \u00e9s t\u00f6r\u00f6lj\u00fcnk egyb\u0151l.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Egyedi azonos\u00edt\u00f3 a csatolm\u00e1nyhoz.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"A szerkesztett k\u00e9t f\u00e1jl URL c\u00edme.","type":"string","format":"uri","required":true},"modifiers":{"description":"K\u00e9pszerkeszt\u00e9sek t\u00f6mbje.","type":"array","minItems":1,"items":{"description":"K\u00e9p szerkeszt\u00e9s.","type":"object","required":["type","args"],"oneOf":[{"title":"Flip","properties":{"type":{"description":"Flip type.","type":"string","enum":["flip"]},"args":{"description":"Flip arguments.","type":"object","required":["flip"],"properties":{"flip":{"description":"Flip direction.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"Whether to flip in the horizontal direction.","type":"boolean"},"vertical":{"description":"Whether to flip in the vertical direction.","type":"boolean"}}}}}}},{"title":"Forgat\u00e1s","properties":{"type":{"description":"Kiv\u00e1g\u00e1s t\u00edpusa.","type":"string","enum":["rotate"]},"args":{"description":"Forgat\u00e1s param\u00e9terei.","type":"object","required":["angle"],"properties":{"angle":{"description":"Jobbra forgat\u00e1s sz\u00f6ge (fok).","type":"number"}}}}},{"title":"K\u00f6rbev\u00e1g\u00e1s","properties":{"type":{"description":"Kiv\u00e1g\u00e1s t\u00edpusa.","type":"string","enum":["crop"]},"args":{"description":"Kiv\u00e1g\u00e1s param\u00e9terei.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Horizont\u00e1lis pozici\u00f3 balra a kiv\u00e1g\u00e1st\u00f3l a k\u00e9psz\u00e9less\u00e9g sz\u00e1zal\u00e9k\u00e1ban.","type":"number"},"top":{"description":"Vertik\u00e1lis poz\u00edci\u00f3 a kiv\u00e1g\u00e1s tetej\u00e9t\u0151l a k\u00e9pmagass\u00e1g sz\u00e1zal\u00e9k\u00e1ban.","type":"number"},"width":{"description":"A kiv\u00e1g\u00e1s sz\u00e9less\u00e9ge a k\u00e9psz\u00e9less\u00e9g sz\u00e1zal\u00e9k\u00e1ban.","type":"number"},"height":{"description":"A kiv\u00e1g\u00e1s magass\u00e1ga a k\u00e9pmagass\u00e1g sz\u00e1zal\u00e9k\u00e1ban. ","type":"number"}}}}}]},"required":false},"rotation":{"description":"K\u00e9pforgat\u00e1s jobbra (fok).  ELAVULT: haszn\u00e1lja ink\u00e1bb a 'm\u00f3dos\u00edt\u00e1sokat',","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"A kiv\u00e1g\u00e1s kezdet\u00e9nek pozici\u00f3ja a k\u00e9p sz\u00e1zal\u00e9k\u00e1ban. ELAVULT: Haszn\u00e1lja ink\u00e1bb a 'm\u00f3dos\u00edt\u00e1sokat'.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"A kiv\u00e1g\u00e1s y pozici\u00f3j\u00e1nak kezdete a k\u00e9p sz\u00e1zal\u00e9k\u00e1ban. ELAVULT: Haszn\u00e1lja ink\u00e1bb a 'm\u00f3dosit\u00e1sokat'!","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":" A kiv\u00e1g\u00e1s sz\u00e9less\u00e9ge a k\u00e9p sz\u00e1zal\u00e9k\u00e1ban. ELAVULT: Haszn\u00e1lja ink\u00e1bb a 'm\u00f3dos\u00edt\u00e1sokat'!","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"A kiv\u00e1g\u00e1s magass\u00e1ga a k\u00e9p sz\u00e1zal\u00e9k\u00e1ban. ELAVULT: Haszn\u00e1lja ink\u00e1bb a 'm\u00f3dos\u00edt\u00e1sokat'!","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"A csatolm\u00e1ny felirata.","type":"object","properties":{"raw":{"description":"A csatolm\u00e1ny felirata, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A csatolm\u00e1ny HTML felirata, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"A csatolm\u00e1ny le\u00edr\u00e1sa.","type":"object","properties":{"raw":{"description":"A csatolm\u00e1ny le\u00edr\u00e1sa, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A csatolm\u00e1ny HTML le\u00edr\u00e1sa, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"A bejegyz\u00e9s c\u00edme.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s c\u00edme, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML c\u00edme, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"A csatolm\u00e1nyhoz kapcsol\u00f3d\u00f3 bejegyz\u00e9s azonos\u00edt\u00f3ja.","type":"integer","required":false},"alt_text":{"description":"Alternat\u00edv sz\u00f6veg mutat\u00e1sa, amikor a csatolm\u00e1ny nem l\u00e1tszik.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/sideload":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Egyedi azonos\u00edt\u00f3 a csatolm\u00e1nyhoz.","type":"integer","required":false},"image_size":{"description":"Image size. Can be a single size name or an array of size names to register the same file under multiple sizes.","type":["string","array"],"items":{"type":"string","minLength":1},"minItems":1,"minLength":1,"required":true},"convert_format":{"type":"boolean","default":true,"description":"Whether to convert image formats.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/finalize":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Egyedi azonos\u00edt\u00f3 a csatolm\u00e1nyhoz.","type":"integer","required":false},"sub_sizes":{"description":"Array of sub-size metadata collected from sideload responses.","type":"array","default":[],"maxItems":100,"items":{"type":"object","properties":{"image_size":{"description":"Size name, or an array of size names when a single file is registered under multiple sizes with matching dimensions.","type":["string","array"],"items":{"type":"string","minLength":1},"minItems":1,"minLength":1,"required":true},"width":{"type":"integer","minimum":1},"height":{"type":"integer","minimum":1},"file":{"type":"string","minLength":1},"mime_type":{"type":"string","pattern":"^image\/.*"},"filesize":{"type":"integer","minimum":1},"original_image":{"type":"string","minLength":1}}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"after":{"description":"Hozz\u00e1sz\u00f3l\u00e1sok korl\u00e1toz\u00e1sa a megadott ISO8601 form\u00e1tum\u00fa d\u00e1tum ut\u00e1n k\u00f6zz\u00e9tett bejegyz\u00e9sek eset\u00e9n.","type":"string","format":"date-time","required":false},"modified_after":{"description":"A v\u00e1lasz korl\u00e1toz\u00e1sa a megadott ISO8601 d\u00e1tum ut\u00e1n m\u00f3dos\u00edtott posztokra.","type":"string","format":"date-time","required":false},"before":{"description":"Korl\u00e1tozza a v\u00e1laszt egy adott ISO8601 form\u00e1tum\u00fa d\u00e1tumot megel\u0151z\u0151en k\u00f6zz\u00e9tett bejegyz\u00e9sekre.","type":"string","format":"date-time","required":false},"modified_before":{"description":"A v\u00e1lasz korl\u00e1toz\u00e1sa a megadott ISO8601 d\u00e1tum el\u0151tt m\u00f3dos\u00edtott posztokra.","type":"string","format":"date-time","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Hogyan kell \u00e9rtelmezni a keres\u00e9si bemenetet.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Gy\u0171jtem\u00e9ny rendez\u00e9se objektum tulajdons\u00e1g szerint.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"A keresend\u0151 oszlopnevek t\u00f6mbje.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Korl\u00e1tozza az eredm\u00e9ny k\u00e9szletet az egy vagy t\u00f6bb meghat\u00e1rozott keres\u0151bar\u00e1t n\u00e9vvel rendelkez\u0151 bejegyz\u00e9sekre.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Korl\u00e1tozza az eredm\u00e9ny k\u00e9szletet az egy vagy t\u00f6bb \u00e1llapothoz rendelt bejegyz\u00e9sekhez.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Az eredm\u00e9nyk\u00e9szlet korl\u00e1toz\u00e1sa a t\u00f6bb taxon\u00f3mi\u00e1s kapcsolatokban","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Az eredm\u00e9nyhalmaz korl\u00e1toz\u00e1sa a menus kateg\u00f3ri\u00e1hoz t\u00e1rs\u00edtott kifejez\u00e9sekkel.","type":["object","array"],"oneOf":[{"title":"Kifejez\u00e9s ID Lista","description":"Kifejez\u00e9sek egyez\u00e9se a list\u00e1ban felsorolt ID-kkel.","type":"array","items":{"type":"integer"}},{"title":"Kateg\u00f3ria azonos\u00edt\u00f3 lek\u00e9rdez\u00e9s - ID ","description":"Lek\u00e9rdez\u00e9s egy \u00f6sszetett kifejez\u00e9ssel. ","type":"object","properties":{"terms":{"description":"Kifejez\u00e9s ID-k.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Azt, hogy az elemekhez hozz\u00e1 kell-e rendelni a megadott felt\u00e9telek mindegyik\u00e9t vagy valamelyik\u00e9t.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Korl\u00e1tozzuk az eredm\u00e9nyhalmazt az \u00f6sszes olyan elemre, amely rendelkezik menus taxon\u00f3mi\u00e1hoz t\u00e1rs\u00edtott kifejez\u00e9ssel.","type":["object","array"],"oneOf":[{"title":"Kifejez\u00e9s ID Lista","description":"Kifejez\u00e9sek egyez\u00e9se a list\u00e1ban felsorolt ID-kkel.","type":"array","items":{"type":"integer"}},{"title":"Kateg\u00f3ria azonos\u00edt\u00f3 lek\u00e9rdez\u00e9s - ID ","description":"Lek\u00e9rdez\u00e9s egy \u00f6sszetett kifejez\u00e9ssel. ","type":"object","properties":{"terms":{"description":"Kifejez\u00e9s ID-k.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Korl\u00e1tozza az eredm\u00e9nyhalmazt meghat\u00e1rozott menu_order \u00e9rt\u00e9kkel rendelkez\u0151 bejegyz\u00e9sekre.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"Az objektum c\u00edme.","type":["string","object"],"properties":{"raw":{"description":"Az objektum c\u00edme, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"Az objektum HTML c\u00edme, \u00e1talak\u00edtva a megjelen\u00edt\u00e9shez.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"Az eredetileg \u00e1br\u00e1zolt objektumok csal\u00e1dja, p\u00e9ld\u00e1ul \"post_type\" vagy \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Az objektum megnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"default":0,"description":"Az objektum sz\u00fcl\u0151j\u00e9nek azonos\u00edt\u00f3ja.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Sz\u00f6veg az ehhez a men\u00fcponthoz tartoz\u00f3 hivatkoz\u00e1s-elem c\u00edm attrib\u00fatum\u00e1hoz.","type":"string","required":false},"classes":{"description":"Oszt\u00e1lynevek ennek a men\u00fcpontnak a hivatkoz\u00e1si elem\u00e9hez.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Ennek a men\u00fcpontnak a le\u00edr\u00e1sa.","type":"string","required":false},"menu_order":{"default":1,"description":"A nav_menu_item DB azonos\u00edt\u00f3ja, amely az elem men\u00fc sz\u00fcl\u0151je, ha van, egy\u00e9bk\u00e9nt 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Az eredetileg \u00e1br\u00e1zolt objektum t\u00edpusa, p\u00e9ld\u00e1ul \"kateg\u00f3ria\", \"bejegyz\u00e9s\" vagy \"csatolm\u00e1ny\".","type":"string","required":false},"object_id":{"default":0,"description":"Az eredeti objektum adatb\u00e1zis-azonos\u00edt\u00f3ja, amelyet ez a men\u00fcpont k\u00e9pvisel, p\u00e9ld\u00e1ul a bejegyz\u00e9sek azonos\u00edt\u00f3ja vagy a kateg\u00f3ri\u00e1k eset\u00e9ben a term_id.","type":"integer","minimum":0,"required":false},"target":{"description":"A hivatkoz\u00e1selem c\u00e9lattrib\u00fatuma ehhez a men\u00fcponthoz.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Az URL, amelyre ez a men\u00fcpont mutat.","type":"string","format":"uri","required":false},"xfn":{"description":"Ennek a men\u00fcpontnak a hivatkoz\u00e1s\u00e1ban kifejezett XFN kapcsolat.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Az objektumhoz rendelt kifejez\u00e9sek a nav_menu taxon\u00f3mi\u00e1ban.","type":"integer","required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"title":{"description":"Az objektum c\u00edme.","type":["string","object"],"properties":{"raw":{"description":"Az objektum c\u00edme, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"Az objektum HTML c\u00edme, \u00e1talak\u00edtva a megjelen\u00edt\u00e9shez.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Az eredetileg \u00e1br\u00e1zolt objektumok csal\u00e1dja, p\u00e9ld\u00e1ul \"post_type\" vagy \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Az objektum megnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"description":"Az objektum sz\u00fcl\u0151j\u00e9nek azonos\u00edt\u00f3ja.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Sz\u00f6veg az ehhez a men\u00fcponthoz tartoz\u00f3 hivatkoz\u00e1s-elem c\u00edm attrib\u00fatum\u00e1hoz.","type":"string","required":false},"classes":{"description":"Oszt\u00e1lynevek ennek a men\u00fcpontnak a hivatkoz\u00e1si elem\u00e9hez.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Ennek a men\u00fcpontnak a le\u00edr\u00e1sa.","type":"string","required":false},"menu_order":{"description":"A nav_menu_item DB azonos\u00edt\u00f3ja, amely az elem men\u00fc sz\u00fcl\u0151je, ha van, egy\u00e9bk\u00e9nt 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Az eredetileg \u00e1br\u00e1zolt objektum t\u00edpusa, p\u00e9ld\u00e1ul \"kateg\u00f3ria\", \"bejegyz\u00e9s\" vagy \"csatolm\u00e1ny\".","type":"string","required":false},"object_id":{"description":"Az eredeti objektum adatb\u00e1zis-azonos\u00edt\u00f3ja, amelyet ez a men\u00fcpont k\u00e9pvisel, p\u00e9ld\u00e1ul a bejegyz\u00e9sek azonos\u00edt\u00f3ja vagy a kateg\u00f3ri\u00e1k eset\u00e9ben a term_id.","type":"integer","minimum":0,"required":false},"target":{"description":"A hivatkoz\u00e1selem c\u00e9lattrib\u00fatuma ehhez a men\u00fcponthoz.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Az URL, amelyre ez a men\u00fcpont mutat.","type":"string","format":"uri","required":false},"xfn":{"description":"Ennek a men\u00fcpontnak a hivatkoz\u00e1s\u00e1ban kifejezett XFN kapcsolat.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Az objektumhoz rendelt kifejez\u00e9sek a nav_menu taxon\u00f3mi\u00e1ban.","type":"integer","required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Hagyjuk-e ki a Lomt\u00e1rat, \u00e9s t\u00f6r\u00f6lj\u00fcnk egyb\u0151l.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Az automatikus ment\u00e9s sz\u00fcl\u0151j\u00e9nek azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Az objektum sz\u00fcl\u0151j\u00e9nek azonos\u00edt\u00f3ja.","type":"integer","minimum":0,"required":false},"title":{"description":"Az objektum c\u00edme.","type":["string","object"],"properties":{"raw":{"description":"Az objektum c\u00edme, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"Az objektum HTML c\u00edme, \u00e1talak\u00edtva a megjelen\u00edt\u00e9shez.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Az eredetileg \u00e1br\u00e1zolt objektumok csal\u00e1dja, p\u00e9ld\u00e1ul \"post_type\" vagy \"taxonomy\".","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Az objektum megnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"attr_title":{"description":"Sz\u00f6veg az ehhez a men\u00fcponthoz tartoz\u00f3 hivatkoz\u00e1s-elem c\u00edm attrib\u00fatum\u00e1hoz.","type":"string","required":false},"classes":{"description":"Oszt\u00e1lynevek ennek a men\u00fcpontnak a hivatkoz\u00e1si elem\u00e9hez.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Ennek a men\u00fcpontnak a le\u00edr\u00e1sa.","type":"string","required":false},"menu_order":{"description":"A nav_menu_item DB azonos\u00edt\u00f3ja, amely az elem men\u00fc sz\u00fcl\u0151je, ha van, egy\u00e9bk\u00e9nt 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Az eredetileg \u00e1br\u00e1zolt objektum t\u00edpusa, p\u00e9ld\u00e1ul \"kateg\u00f3ria\", \"bejegyz\u00e9s\" vagy \"csatolm\u00e1ny\".","type":"string","required":false},"object_id":{"description":"Az eredeti objektum adatb\u00e1zis-azonos\u00edt\u00f3ja, amelyet ez a men\u00fcpont k\u00e9pvisel, p\u00e9ld\u00e1ul a bejegyz\u00e9sek azonos\u00edt\u00f3ja vagy a kateg\u00f3ri\u00e1k eset\u00e9ben a term_id.","type":"integer","minimum":0,"required":false},"target":{"description":"A hivatkoz\u00e1selem c\u00e9lattrib\u00fatuma ehhez a men\u00fcponthoz.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Az URL, amelyre ez a men\u00fcpont mutat.","type":"string","format":"uri","required":false},"xfn":{"description":"Ennek a men\u00fcpontnak a hivatkoz\u00e1s\u00e1ban kifejezett XFN kapcsolat.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Az objektumhoz rendelt kifejez\u00e9sek a nav_menu taxon\u00f3mi\u00e1ban.","type":"integer","required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Az automatikus ment\u00e9s sz\u00fcl\u0151j\u00e9nek azonos\u00edt\u00f3ja.","type":"integer","required":false},"id":{"description":"Az ID  az automatikus ment\u00e9shez.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"after":{"description":"Hozz\u00e1sz\u00f3l\u00e1sok korl\u00e1toz\u00e1sa a megadott ISO8601 form\u00e1tum\u00fa d\u00e1tum ut\u00e1n k\u00f6zz\u00e9tett bejegyz\u00e9sek eset\u00e9n.","type":"string","format":"date-time","required":false},"modified_after":{"description":"A v\u00e1lasz korl\u00e1toz\u00e1sa a megadott ISO8601 d\u00e1tum ut\u00e1n m\u00f3dos\u00edtott posztokra.","type":"string","format":"date-time","required":false},"before":{"description":"Korl\u00e1tozza a v\u00e1laszt egy adott ISO8601 form\u00e1tum\u00fa d\u00e1tumot megel\u0151z\u0151en k\u00f6zz\u00e9tett bejegyz\u00e9sekre.","type":"string","format":"date-time","required":false},"modified_before":{"description":"A v\u00e1lasz korl\u00e1toz\u00e1sa a megadott ISO8601 d\u00e1tum el\u0151tt m\u00f3dos\u00edtott posztokra.","type":"string","format":"date-time","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Hogyan kell \u00e9rtelmezni a keres\u00e9si bemenetet.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Gy\u0171jtem\u00e9ny rendez\u00e9se a bejegyz\u00e9st tulajdons\u00e1g szerint.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"A keresend\u0151 oszlopnevek t\u00f6mbje.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Korl\u00e1tozza az eredm\u00e9ny k\u00e9szletet az egy vagy t\u00f6bb meghat\u00e1rozott keres\u0151bar\u00e1t n\u00e9vvel rendelkez\u0151 bejegyz\u00e9sekre.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Korl\u00e1tozza az eredm\u00e9ny k\u00e9szletet az egy vagy t\u00f6bb \u00e1llapothoz rendelt bejegyz\u00e9sekhez.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Az eredm\u00e9nyk\u00e9szlet korl\u00e1toz\u00e1sa a t\u00f6bb taxon\u00f3mi\u00e1s kapcsolatokban","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Az eredm\u00e9nyhalmaz korl\u00e1toz\u00e1sa a wp_pattern_category kateg\u00f3ri\u00e1hoz t\u00e1rs\u00edtott kifejez\u00e9sekkel.","type":["object","array"],"oneOf":[{"title":"Kifejez\u00e9s ID Lista","description":"Kifejez\u00e9sek egyez\u00e9se a list\u00e1ban felsorolt ID-kkel.","type":"array","items":{"type":"integer"}},{"title":"Kateg\u00f3ria azonos\u00edt\u00f3 lek\u00e9rdez\u00e9s - ID ","description":"Lek\u00e9rdez\u00e9s egy \u00f6sszetett kifejez\u00e9ssel. ","type":"object","properties":{"terms":{"description":"Kifejez\u00e9s ID-k.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Azt, hogy az elemekhez hozz\u00e1 kell-e rendelni a megadott felt\u00e9telek mindegyik\u00e9t vagy valamelyik\u00e9t.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Korl\u00e1tozzuk az eredm\u00e9nyhalmazt az \u00f6sszes olyan elemre, amely rendelkezik wp_pattern_category taxon\u00f3mi\u00e1hoz t\u00e1rs\u00edtott kifejez\u00e9ssel.","type":["object","array"],"oneOf":[{"title":"Kifejez\u00e9s ID Lista","description":"Kifejez\u00e9sek egyez\u00e9se a list\u00e1ban felsorolt ID-kkel.","type":"array","items":{"type":"integer"}},{"title":"Kateg\u00f3ria azonos\u00edt\u00f3 lek\u00e9rdez\u00e9s - ID ","description":"Lek\u00e9rdez\u00e9s egy \u00f6sszetett kifejez\u00e9ssel. ","type":"object","properties":{"terms":{"description":"Kifejez\u00e9s ID-k.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"A bejegyz\u00e9s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Az bejegyz\u00e9s publik\u00e1l\u00e1s\u00e1nak id\u0151pontja GMT szerinti.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"A bejegyz\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"status":{"description":"A bejegyz\u00e9s elnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Egy jelsz\u00f3 a tartalom \u00e9s a kivonat v\u00e9delm\u00e9hez.","type":"string","required":false},"title":{"description":"A bejegyz\u00e9s c\u00edme.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s c\u00edme, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"A bejegyz\u00e9s tartalma.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s tartalma, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["view","edit"]},"block_version":{"description":"A bejegyz\u00e9s \u00e1ltal haszn\u00e1lt tartalom blokk verzi\u00f3ja.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Amennyiben a tartalom jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"A bejegyz\u00e9s kivonata.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s kivonata, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML kivonata, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Amennyiben a kivonat jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"A bejegyz\u00e9s megjelen\u00edt\u00e9s\u00e9hez haszn\u00e1lt sablon f\u00e1jl.","type":"string","required":false},"wp_pattern_category":{"description":"A bejegyz\u00e9shez rendelt kifejez\u00e9sek a wp_pattern_category oszt\u00e1lyoz\u00e1sban.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Az alap\u00e9rtelmezett kivonathossz fel\u00fclb\u00edr\u00e1l\u00e1sa.","type":"integer","required":false},"password":{"description":"A jelsz\u00f3 a bejegyz\u00e9shez, ha az jelsz\u00f3val v\u00e9dett.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"date":{"description":"A bejegyz\u00e9s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Az bejegyz\u00e9s publik\u00e1l\u00e1s\u00e1nak id\u0151pontja GMT szerinti.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"A bejegyz\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"status":{"description":"A bejegyz\u00e9s elnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Egy jelsz\u00f3 a tartalom \u00e9s a kivonat v\u00e9delm\u00e9hez.","type":"string","required":false},"title":{"description":"A bejegyz\u00e9s c\u00edme.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s c\u00edme, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"A bejegyz\u00e9s tartalma.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s tartalma, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["view","edit"]},"block_version":{"description":"A bejegyz\u00e9s \u00e1ltal haszn\u00e1lt tartalom blokk verzi\u00f3ja.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Amennyiben a tartalom jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"A bejegyz\u00e9s kivonata.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s kivonata, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML kivonata, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Amennyiben a kivonat jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"A bejegyz\u00e9s megjelen\u00edt\u00e9s\u00e9hez haszn\u00e1lt sablon f\u00e1jl.","type":"string","required":false},"wp_pattern_category":{"description":"A bejegyz\u00e9shez rendelt kifejez\u00e9sek a wp_pattern_category oszt\u00e1lyoz\u00e1sban.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Hagyjuk-e ki a Lomt\u00e1rat, \u00e9s t\u00f6r\u00f6lj\u00fcnk egyb\u0151l.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"A v\u00e1ltozat sz\u00fcl\u0151j\u00e9ne az azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Gy\u0171jtem\u00e9ny rendez\u00e9se objektum tulajdons\u00e1g szerint.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"A v\u00e1ltozat sz\u00fcl\u0151j\u00e9ne az azonos\u00edt\u00f3ja.","type":"integer","required":false},"id":{"description":"A v\u00e1ltozat egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"A v\u00e1ltozat sz\u00fcl\u0151j\u00e9ne az azonos\u00edt\u00f3ja.","type":"integer","required":false},"id":{"description":"A v\u00e1ltozat egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Igaznak kell lennie, mert a v\u00e1ltozatokat nem lehet lomt\u00e1rba helyezni.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Az automatikus ment\u00e9s sz\u00fcl\u0151j\u00e9nek azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Az automatikus ment\u00e9s sz\u00fcl\u0151j\u00e9nek azonos\u00edt\u00f3ja.","type":"integer","required":false},"date":{"description":"A bejegyz\u00e9s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Az bejegyz\u00e9s publik\u00e1l\u00e1s\u00e1nak id\u0151pontja GMT szerinti.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"A bejegyz\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"status":{"description":"A bejegyz\u00e9s elnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Egy jelsz\u00f3 a tartalom \u00e9s a kivonat v\u00e9delm\u00e9hez.","type":"string","required":false},"title":{"description":"A bejegyz\u00e9s c\u00edme.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s c\u00edme, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"A bejegyz\u00e9s tartalma.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s tartalma, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["view","edit"]},"block_version":{"description":"A bejegyz\u00e9s \u00e1ltal haszn\u00e1lt tartalom blokk verzi\u00f3ja.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Amennyiben a tartalom jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"A bejegyz\u00e9s kivonata.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s kivonata, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML kivonata, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Amennyiben a kivonat jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":{"inline_featured_image":{"type":"boolean","title":"","description":"","default":false},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"A bejegyz\u00e9s megjelen\u00edt\u00e9s\u00e9hez haszn\u00e1lt sablon f\u00e1jl.","type":"string","required":false},"wp_pattern_category":{"description":"A bejegyz\u00e9shez rendelt kifejez\u00e9sek a wp_pattern_category oszt\u00e1lyoz\u00e1sban.","type":"array","items":{"type":"integer"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Az automatikus ment\u00e9s sz\u00fcl\u0151j\u00e9nek azonos\u00edt\u00f3ja.","type":"integer","required":false},"id":{"description":"Az ID  az automatikus ment\u00e9shez.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"A mintasablon azonos\u00edt\u00f3ja","type":"string","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Gy\u0171jtem\u00e9ny rendez\u00e9se objektum tulajdons\u00e1g szerint.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"A mintasablon azonos\u00edt\u00f3ja","type":"string","required":false},"id":{"description":"A v\u00e1ltozat egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"A mintasablon azonos\u00edt\u00f3ja","type":"string","required":false},"id":{"description":"A v\u00e1ltozat egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Igaznak kell lennie, mert a v\u00e1ltozatokat nem lehet lomt\u00e1rba helyezni.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"A mintasablon azonos\u00edt\u00f3ja","type":"string","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"id":{"description":"A mintasablon azonos\u00edt\u00f3ja","type":"string","required":false},"slug":{"description":"Egyedi keres\u0151bar\u00e1t kifezez\u00e9s a sablonminta azonos\u00edt\u00e1s\u00e1hoz.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Sablon azonos\u00edt\u00f3 a sablonmint\u00e1hoz.","type":"string","required":false},"type":{"description":"Sablonr\u00e9sz t\u00edpusa.","type":"string","required":false},"content":{"description":"Mintasablon tartalma.","type":["object","string"],"properties":{"raw":{"description":"A sablon tartalma, ahogy az az adatb\u00e1zisban l\u00e9tezik.","type":"string","context":["view","edit"]},"block_version":{"description":"A sablon \u00e1ltal haszn\u00e1lt tartalomblokk-form\u00e1tum verzi\u00f3ja.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Mintasablon c\u00edme.","type":["object","string"],"properties":{"raw":{"description":"C\u00edm a sablonhoz, ahogy az az adatb\u00e1zisban van.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"A sablon HTML c\u00edme, megjelen\u00edt\u00e9sre \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Mintasablon le\u00edr\u00e1sa.","type":"string","required":false},"status":{"description":"Mintasablon \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"A sablonr\u00e9sz szerz\u0151j\u00e9nek azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"A mintasablon azonos\u00edt\u00f3ja","type":"string","required":false},"id":{"description":"Az ID  az automatikus ment\u00e9shez.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Csak a megadott bejegyz\u00e9shez.","type":"integer","required":false},"area":{"description":"Korl\u00e1tozzuk a megadott sablonr\u00e9sz ter\u00fclet\u00e9re.","type":"string","required":false},"post_type":{"description":"A bejegyz\u00e9s t\u00edpusa, amihez a sablonr\u00e9szeket lek\u00e9rj\u00fck.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Egyedi keres\u0151bar\u00e1t kifezez\u00e9s a sablonminta azonos\u00edt\u00e1s\u00e1hoz.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Sablon azonos\u00edt\u00f3 a sablonmint\u00e1hoz.","type":"string","required":false},"type":{"description":"Sablonr\u00e9sz t\u00edpusa.","type":"string","required":false},"content":{"default":"","description":"Mintasablon tartalma.","type":["object","string"],"properties":{"raw":{"description":"A sablon tartalma, ahogy az az adatb\u00e1zisban l\u00e9tezik.","type":"string","context":["view","edit"]},"block_version":{"description":"A sablon \u00e1ltal haszn\u00e1lt tartalomblokk-form\u00e1tum verzi\u00f3ja.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Mintasablon c\u00edme.","type":["object","string"],"properties":{"raw":{"description":"C\u00edm a sablonhoz, ahogy az az adatb\u00e1zisban van.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"A sablon HTML c\u00edme, megjelen\u00edt\u00e9sre \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Mintasablon le\u00edr\u00e1sa.","type":"string","required":false},"status":{"default":"publish","description":"Mintasablon \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"A sablonr\u00e9sz szerz\u0151j\u00e9nek azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"A sablon csig\u00e1ja, amelyhez a tartal\u00e9kot kapja","type":"string","required":true},"is_custom":{"description":"Azt jelzi, hogy egy sablon egy\u00e9ni vagy a sablonhierarchia r\u00e9sze","type":"boolean","required":false},"template_prefix":{"description":"A l\u00e9trehozott sablon sablon el\u0151tagja. Ez a f\u0151 sablont\u00edpus kinyer\u00e9s\u00e9re szolg\u00e1l, pl. a \"taxon\u00f3mia-k\u00f6nyvekben\" kivonatolja a \"taxon\u00f3mi\u00e1t\".","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"A mintasablon azonos\u00edt\u00f3ja","type":"string","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"A mintasablon azonos\u00edt\u00f3ja","type":"string","required":false},"slug":{"description":"Egyedi keres\u0151bar\u00e1t kifezez\u00e9s a sablonminta azonos\u00edt\u00e1s\u00e1hoz.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Sablon azonos\u00edt\u00f3 a sablonmint\u00e1hoz.","type":"string","required":false},"type":{"description":"Sablonr\u00e9sz t\u00edpusa.","type":"string","required":false},"content":{"description":"Mintasablon tartalma.","type":["object","string"],"properties":{"raw":{"description":"A sablon tartalma, ahogy az az adatb\u00e1zisban l\u00e9tezik.","type":"string","context":["view","edit"]},"block_version":{"description":"A sablon \u00e1ltal haszn\u00e1lt tartalomblokk-form\u00e1tum verzi\u00f3ja.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Mintasablon c\u00edme.","type":["object","string"],"properties":{"raw":{"description":"C\u00edm a sablonhoz, ahogy az az adatb\u00e1zisban van.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"A sablon HTML c\u00edme, megjelen\u00edt\u00e9sre \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Mintasablon le\u00edr\u00e1sa.","type":"string","required":false},"status":{"description":"Mintasablon \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"A sablonr\u00e9sz szerz\u0151j\u00e9nek azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"A mintasablon azonos\u00edt\u00f3ja","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Hagyjuk-e ki a Lomt\u00e1rat, \u00e9s t\u00f6r\u00f6lj\u00fcnk egyb\u0151l.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"A mintasablon azonos\u00edt\u00f3ja","type":"string","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Gy\u0171jtem\u00e9ny rendez\u00e9se objektum tulajdons\u00e1g szerint.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"A mintasablon azonos\u00edt\u00f3ja","type":"string","required":false},"id":{"description":"A v\u00e1ltozat egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"A mintasablon azonos\u00edt\u00f3ja","type":"string","required":false},"id":{"description":"A v\u00e1ltozat egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Igaznak kell lennie, mert a v\u00e1ltozatokat nem lehet lomt\u00e1rba helyezni.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"A mintasablon azonos\u00edt\u00f3ja","type":"string","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"id":{"description":"A mintasablon azonos\u00edt\u00f3ja","type":"string","required":false},"slug":{"description":"Egyedi keres\u0151bar\u00e1t kifezez\u00e9s a sablonminta azonos\u00edt\u00e1s\u00e1hoz.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Sablon azonos\u00edt\u00f3 a sablonmint\u00e1hoz.","type":"string","required":false},"type":{"description":"Sablonr\u00e9sz t\u00edpusa.","type":"string","required":false},"content":{"description":"Mintasablon tartalma.","type":["object","string"],"properties":{"raw":{"description":"A sablon tartalma, ahogy az az adatb\u00e1zisban l\u00e9tezik.","type":"string","context":["view","edit"]},"block_version":{"description":"A sablon \u00e1ltal haszn\u00e1lt tartalomblokk-form\u00e1tum verzi\u00f3ja.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Mintasablon c\u00edme.","type":["object","string"],"properties":{"raw":{"description":"C\u00edm a sablonhoz, ahogy az az adatb\u00e1zisban van.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"A sablon HTML c\u00edme, megjelen\u00edt\u00e9sre \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Mintasablon le\u00edr\u00e1sa.","type":"string","required":false},"status":{"description":"Mintasablon \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"A sablonr\u00e9sz szerz\u0151j\u00e9nek azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"area":{"description":"Ahol a sablon r\u00e9szt sz\u00e1nj\u00e1k (fejl\u00e9c, l\u00e1bl\u00e9c stb.)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"A mintasablon azonos\u00edt\u00f3ja","type":"string","required":false},"id":{"description":"Az ID  az automatikus ment\u00e9shez.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Csak a megadott bejegyz\u00e9shez.","type":"integer","required":false},"area":{"description":"Korl\u00e1tozzuk a megadott sablonr\u00e9sz ter\u00fclet\u00e9re.","type":"string","required":false},"post_type":{"description":"A bejegyz\u00e9s t\u00edpusa, amihez a sablonr\u00e9szeket lek\u00e9rj\u00fck.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Egyedi keres\u0151bar\u00e1t kifezez\u00e9s a sablonminta azonos\u00edt\u00e1s\u00e1hoz.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Sablon azonos\u00edt\u00f3 a sablonmint\u00e1hoz.","type":"string","required":false},"type":{"description":"Sablonr\u00e9sz t\u00edpusa.","type":"string","required":false},"content":{"default":"","description":"Mintasablon tartalma.","type":["object","string"],"properties":{"raw":{"description":"A sablon tartalma, ahogy az az adatb\u00e1zisban l\u00e9tezik.","type":"string","context":["view","edit"]},"block_version":{"description":"A sablon \u00e1ltal haszn\u00e1lt tartalomblokk-form\u00e1tum verzi\u00f3ja.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Mintasablon c\u00edme.","type":["object","string"],"properties":{"raw":{"description":"C\u00edm a sablonhoz, ahogy az az adatb\u00e1zisban van.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"A sablon HTML c\u00edme, megjelen\u00edt\u00e9sre \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Mintasablon le\u00edr\u00e1sa.","type":"string","required":false},"status":{"default":"publish","description":"Mintasablon \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"A sablonr\u00e9sz szerz\u0151j\u00e9nek azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"area":{"description":"Ahol a sablon r\u00e9szt sz\u00e1nj\u00e1k (fejl\u00e9c, l\u00e1bl\u00e9c stb.)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"A sablon csig\u00e1ja, amelyhez a tartal\u00e9kot kapja","type":"string","required":true},"is_custom":{"description":"Azt jelzi, hogy egy sablon egy\u00e9ni vagy a sablonhierarchia r\u00e9sze","type":"boolean","required":false},"template_prefix":{"description":"A l\u00e9trehozott sablon sablon el\u0151tagja. Ez a f\u0151 sablont\u00edpus kinyer\u00e9s\u00e9re szolg\u00e1l, pl. a \"taxon\u00f3mia-k\u00f6nyvekben\" kivonatolja a \"taxon\u00f3mi\u00e1t\".","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"A mintasablon azonos\u00edt\u00f3ja","type":"string","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"A mintasablon azonos\u00edt\u00f3ja","type":"string","required":false},"slug":{"description":"Egyedi keres\u0151bar\u00e1t kifezez\u00e9s a sablonminta azonos\u00edt\u00e1s\u00e1hoz.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Sablon azonos\u00edt\u00f3 a sablonmint\u00e1hoz.","type":"string","required":false},"type":{"description":"Sablonr\u00e9sz t\u00edpusa.","type":"string","required":false},"content":{"description":"Mintasablon tartalma.","type":["object","string"],"properties":{"raw":{"description":"A sablon tartalma, ahogy az az adatb\u00e1zisban l\u00e9tezik.","type":"string","context":["view","edit"]},"block_version":{"description":"A sablon \u00e1ltal haszn\u00e1lt tartalomblokk-form\u00e1tum verzi\u00f3ja.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Mintasablon c\u00edme.","type":["object","string"],"properties":{"raw":{"description":"C\u00edm a sablonhoz, ahogy az az adatb\u00e1zisban van.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"A sablon HTML c\u00edme, megjelen\u00edt\u00e9sre \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Mintasablon le\u00edr\u00e1sa.","type":"string","required":false},"status":{"description":"Mintasablon \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"A sablonr\u00e9sz szerz\u0151j\u00e9nek azonos\u00edt\u00f3ja (ID).","type":"integer","required":false},"area":{"description":"Ahol a sablon r\u00e9szt sz\u00e1nj\u00e1k (fejl\u00e9c, l\u00e1bl\u00e9c stb.)","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"A mintasablon azonos\u00edt\u00f3ja","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Hagyjuk-e ki a Lomt\u00e1rat, \u00e9s t\u00f6r\u00f6lj\u00fcnk egyb\u0151l.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"A v\u00e1ltozat sz\u00fcl\u0151j\u00e9ne az azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"A glob\u00e1lis st\u00edlus v\u00e1ltozat sz\u00fcl\u0151j\u00e9nek azonos\u00edt\u00f3ja.","type":"integer","required":false},"id":{"description":"A glob\u00e1lis st\u00edlus v\u00e1ltozat egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Sablon azonos\u00edt\u00f3","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Sablon azonos\u00edt\u00f3","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"A glob\u00e1lis st\u00edlusok konfigur\u00e1ci\u00f3j\u00e1nak azonos\u00edt\u00f3ja.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Glob\u00e1lis st\u00edlusok.","type":["object"],"required":false},"settings":{"description":"Glob\u00e1lis be\u00e1ll\u00edt\u00e1sok.","type":["object"],"required":false},"title":{"description":"A glob\u00e1lis st\u00edlusv\u00e1ltozat c\u00edme.","type":["object","string"],"properties":{"raw":{"description":"A glob\u00e1lis st\u00edlusv\u00e1ltozat c\u00edme, ahogy az az adatb\u00e1zisban l\u00e9tezik.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"A bejegyz\u00e9s HTML c\u00edme, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"after":{"description":"Hozz\u00e1sz\u00f3l\u00e1sok korl\u00e1toz\u00e1sa a megadott ISO8601 form\u00e1tum\u00fa d\u00e1tum ut\u00e1n k\u00f6zz\u00e9tett bejegyz\u00e9sek eset\u00e9n.","type":"string","format":"date-time","required":false},"modified_after":{"description":"A v\u00e1lasz korl\u00e1toz\u00e1sa a megadott ISO8601 d\u00e1tum ut\u00e1n m\u00f3dos\u00edtott posztokra.","type":"string","format":"date-time","required":false},"before":{"description":"Korl\u00e1tozza a v\u00e1laszt egy adott ISO8601 form\u00e1tum\u00fa d\u00e1tumot megel\u0151z\u0151en k\u00f6zz\u00e9tett bejegyz\u00e9sekre.","type":"string","format":"date-time","required":false},"modified_before":{"description":"A v\u00e1lasz korl\u00e1toz\u00e1sa a megadott ISO8601 d\u00e1tum el\u0151tt m\u00f3dos\u00edtott posztokra.","type":"string","format":"date-time","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Hogyan kell \u00e9rtelmezni a keres\u00e9si bemenetet.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Gy\u0171jtem\u00e9ny rendez\u00e9se a bejegyz\u00e9st tulajdons\u00e1g szerint.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"A keresend\u0151 oszlopnevek t\u00f6mbje.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Korl\u00e1tozza az eredm\u00e9ny k\u00e9szletet az egy vagy t\u00f6bb meghat\u00e1rozott keres\u0151bar\u00e1t n\u00e9vvel rendelkez\u0151 bejegyz\u00e9sekre.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Korl\u00e1tozza az eredm\u00e9ny k\u00e9szletet az egy vagy t\u00f6bb \u00e1llapothoz rendelt bejegyz\u00e9sekhez.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"A bejegyz\u00e9s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Az bejegyz\u00e9s publik\u00e1l\u00e1s\u00e1nak id\u0151pontja GMT szerinti.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"A bejegyz\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"status":{"description":"A bejegyz\u00e9s elnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Egy jelsz\u00f3 a tartalom \u00e9s a kivonat v\u00e9delm\u00e9hez.","type":"string","required":false},"title":{"description":"A bejegyz\u00e9s c\u00edme.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s c\u00edme, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit","embed"]},"rendered":{"description":"A bejegyz\u00e9s HTML c\u00edme, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"A bejegyz\u00e9s tartalma.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s tartalma, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit","embed"]},"rendered":{"description":"A bejegyz\u00e9s HTML tartalma, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"A bejegyz\u00e9s \u00e1ltal haszn\u00e1lt tartalom blokk verzi\u00f3ja.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Amennyiben a tartalom jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"A bejegyz\u00e9s megjelen\u00edt\u00e9s\u00e9hez haszn\u00e1lt sablon f\u00e1jl.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"A jelsz\u00f3 a bejegyz\u00e9shez, ha az jelsz\u00f3val v\u00e9dett.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"date":{"description":"A bejegyz\u00e9s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Az bejegyz\u00e9s publik\u00e1l\u00e1s\u00e1nak id\u0151pontja GMT szerinti.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"A bejegyz\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"status":{"description":"A bejegyz\u00e9s elnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Egy jelsz\u00f3 a tartalom \u00e9s a kivonat v\u00e9delm\u00e9hez.","type":"string","required":false},"title":{"description":"A bejegyz\u00e9s c\u00edme.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s c\u00edme, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit","embed"]},"rendered":{"description":"A bejegyz\u00e9s HTML c\u00edme, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"A bejegyz\u00e9s tartalma.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s tartalma, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit","embed"]},"rendered":{"description":"A bejegyz\u00e9s HTML tartalma, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"A bejegyz\u00e9s \u00e1ltal haszn\u00e1lt tartalom blokk verzi\u00f3ja.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Amennyiben a tartalom jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"A bejegyz\u00e9s megjelen\u00edt\u00e9s\u00e9hez haszn\u00e1lt sablon f\u00e1jl.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Hagyjuk-e ki a Lomt\u00e1rat, \u00e9s t\u00f6r\u00f6lj\u00fcnk egyb\u0151l.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"A v\u00e1ltozat sz\u00fcl\u0151j\u00e9ne az azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Gy\u0171jtem\u00e9ny rendez\u00e9se objektum tulajdons\u00e1g szerint.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"A v\u00e1ltozat sz\u00fcl\u0151j\u00e9ne az azonos\u00edt\u00f3ja.","type":"integer","required":false},"id":{"description":"A v\u00e1ltozat egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"A v\u00e1ltozat sz\u00fcl\u0151j\u00e9ne az azonos\u00edt\u00f3ja.","type":"integer","required":false},"id":{"description":"A v\u00e1ltozat egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Igaznak kell lennie, mert a v\u00e1ltozatokat nem lehet lomt\u00e1rba helyezni.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Az automatikus ment\u00e9s sz\u00fcl\u0151j\u00e9nek azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Az automatikus ment\u00e9s sz\u00fcl\u0151j\u00e9nek azonos\u00edt\u00f3ja.","type":"integer","required":false},"date":{"description":"A bejegyz\u00e9s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Az bejegyz\u00e9s publik\u00e1l\u00e1s\u00e1nak id\u0151pontja GMT szerinti.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"A bejegyz\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"status":{"description":"A bejegyz\u00e9s elnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Egy jelsz\u00f3 a tartalom \u00e9s a kivonat v\u00e9delm\u00e9hez.","type":"string","required":false},"title":{"description":"A bejegyz\u00e9s c\u00edme.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s c\u00edme, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit","embed"]},"rendered":{"description":"A bejegyz\u00e9s HTML c\u00edme, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"A bejegyz\u00e9s tartalma.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s tartalma, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit","embed"]},"rendered":{"description":"A bejegyz\u00e9s HTML tartalma, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"A bejegyz\u00e9s \u00e1ltal haszn\u00e1lt tartalom blokk verzi\u00f3ja.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Amennyiben a tartalom jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"A bejegyz\u00e9s megjelen\u00edt\u00e9s\u00e9hez haszn\u00e1lt sablon f\u00e1jl.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Az automatikus ment\u00e9s sz\u00fcl\u0151j\u00e9nek azonos\u00edt\u00f3ja.","type":"integer","required":false},"id":{"description":"Az ID  az automatikus ment\u00e9shez.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Hogyan kell \u00e9rtelmezni a keres\u00e9si bemenetet.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Gy\u0171jtem\u00e9ny rendez\u00e9se a bejegyz\u00e9st tulajdons\u00e1g szerint.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Korl\u00e1tozza az eredm\u00e9ny k\u00e9szletet az egy vagy t\u00f6bb meghat\u00e1rozott keres\u0151bar\u00e1t n\u00e9vvel rendelkez\u0151 bejegyz\u00e9sekre.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"A tipogr\u00e1fiai be\u00e1ll\u00edt\u00e1sokhoz haszn\u00e1lt theme.json s\u00e9ma verzi\u00f3ja.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"font-family deklar\u00e1ci\u00f3 theme.json form\u00e1tumban, karakterl\u00e1nck\u00e9nt k\u00f3dolva.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"theme_json_version":{"description":"A tipogr\u00e1fiai be\u00e1ll\u00edt\u00e1sokhoz haszn\u00e1lt theme.json s\u00e9ma verzi\u00f3ja.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"font-family deklar\u00e1ci\u00f3 theme.json form\u00e1tumban, karakterl\u00e1nck\u00e9nt k\u00f3dolva.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Hagyjuk-e ki a Lomt\u00e1rat, \u00e9s t\u00f6r\u00f6lj\u00fcnk egyb\u0151l.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"A bet\u0171t\u00edpus sz\u00fcl\u0151bet\u0171t\u00edpus-csal\u00e1dj\u00e1nak azonos\u00edt\u00f3ja.","type":"integer","required":true},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Hogyan kell \u00e9rtelmezni a keres\u00e9si bemenetet.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Gy\u0171jtem\u00e9ny rendez\u00e9se a bejegyz\u00e9st tulajdons\u00e1g szerint.","type":"string","default":"id","enum":["id","include"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"A bet\u0171t\u00edpus sz\u00fcl\u0151bet\u0171t\u00edpus-csal\u00e1dj\u00e1nak azonos\u00edt\u00f3ja.","type":"integer","required":true},"theme_json_version":{"description":"A tipogr\u00e1fiai be\u00e1ll\u00edt\u00e1sokhoz haszn\u00e1lt theme.json s\u00e9ma verzi\u00f3ja.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"font-face deklar\u00e1ci\u00f3 theme.json form\u00e1tumban, karakterl\u00e1nck\u00e9nt k\u00f3dolva.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"A bet\u0171t\u00edpus sz\u00fcl\u0151bet\u0171t\u00edpus-csal\u00e1dj\u00e1nak azonos\u00edt\u00f3ja.","type":"integer","required":true},"id":{"description":"A bet\u0171t\u00edpus egyedi azonos\u00edt\u00f3ja.","type":"integer","required":true},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"A bet\u0171t\u00edpus sz\u00fcl\u0151bet\u0171t\u00edpus-csal\u00e1dj\u00e1nak azonos\u00edt\u00f3ja.","type":"integer","required":true},"id":{"description":"A bet\u0171t\u00edpus egyedi azonos\u00edt\u00f3ja.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Hagyjuk-e ki a Lomt\u00e1rat, \u00e9s t\u00f6r\u00f6lj\u00fcnk egyb\u0151l.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/rm_content_editor":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"after":{"description":"Hozz\u00e1sz\u00f3l\u00e1sok korl\u00e1toz\u00e1sa a megadott ISO8601 form\u00e1tum\u00fa d\u00e1tum ut\u00e1n k\u00f6zz\u00e9tett bejegyz\u00e9sek eset\u00e9n.","type":"string","format":"date-time","required":false},"modified_after":{"description":"A v\u00e1lasz korl\u00e1toz\u00e1sa a megadott ISO8601 d\u00e1tum ut\u00e1n m\u00f3dos\u00edtott posztokra.","type":"string","format":"date-time","required":false},"before":{"description":"Korl\u00e1tozza a v\u00e1laszt egy adott ISO8601 form\u00e1tum\u00fa d\u00e1tumot megel\u0151z\u0151en k\u00f6zz\u00e9tett bejegyz\u00e9sekre.","type":"string","format":"date-time","required":false},"modified_before":{"description":"A v\u00e1lasz korl\u00e1toz\u00e1sa a megadott ISO8601 d\u00e1tum el\u0151tt m\u00f3dos\u00edtott posztokra.","type":"string","format":"date-time","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Hogyan kell \u00e9rtelmezni a keres\u00e9si bemenetet.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Gy\u0171jtem\u00e9ny rendez\u00e9se a bejegyz\u00e9st tulajdons\u00e1g szerint.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"A keresend\u0151 oszlopnevek t\u00f6mbje.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Korl\u00e1tozza az eredm\u00e9ny k\u00e9szletet az egy vagy t\u00f6bb meghat\u00e1rozott keres\u0151bar\u00e1t n\u00e9vvel rendelkez\u0151 bejegyz\u00e9sekre.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Korl\u00e1tozza az eredm\u00e9ny k\u00e9szletet az egy vagy t\u00f6bb \u00e1llapothoz rendelt bejegyz\u00e9sekhez.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"A bejegyz\u00e9s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Az bejegyz\u00e9s publik\u00e1l\u00e1s\u00e1nak id\u0151pontja GMT szerinti.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"A bejegyz\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"status":{"description":"A bejegyz\u00e9s elnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Egy jelsz\u00f3 a tartalom \u00e9s a kivonat v\u00e9delm\u00e9hez.","type":"string","required":false},"content":{"description":"A bejegyz\u00e9s tartalma.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s tartalma, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML tartalma, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"A bejegyz\u00e9s \u00e1ltal haszn\u00e1lt tartalom blokk verzi\u00f3ja.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Amennyiben a tartalom jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"A bejegyz\u00e9s megjelen\u00edt\u00e9s\u00e9hez haszn\u00e1lt sablon f\u00e1jl.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/rm_content_editor"}]}},"\/wp\/v2\/rm_content_editor\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"A jelsz\u00f3 a bejegyz\u00e9shez, ha az jelsz\u00f3val v\u00e9dett.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"date":{"description":"A bejegyz\u00e9s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Az bejegyz\u00e9s publik\u00e1l\u00e1s\u00e1nak id\u0151pontja GMT szerinti.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"A bejegyz\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"status":{"description":"A bejegyz\u00e9s elnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Egy jelsz\u00f3 a tartalom \u00e9s a kivonat v\u00e9delm\u00e9hez.","type":"string","required":false},"content":{"description":"A bejegyz\u00e9s tartalma.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s tartalma, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML tartalma, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"A bejegyz\u00e9s \u00e1ltal haszn\u00e1lt tartalom blokk verzi\u00f3ja.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Amennyiben a tartalom jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"A bejegyz\u00e9s megjelen\u00edt\u00e9s\u00e9hez haszn\u00e1lt sablon f\u00e1jl.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Hagyjuk-e ki a Lomt\u00e1rat, \u00e9s t\u00f6r\u00f6lj\u00fcnk egyb\u0151l.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/rm_content_editor\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Az automatikus ment\u00e9s sz\u00fcl\u0151j\u00e9nek azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Az automatikus ment\u00e9s sz\u00fcl\u0151j\u00e9nek azonos\u00edt\u00f3ja.","type":"integer","required":false},"date":{"description":"A bejegyz\u00e9s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Az bejegyz\u00e9s publik\u00e1l\u00e1s\u00e1nak id\u0151pontja GMT szerinti.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"A bejegyz\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"status":{"description":"A bejegyz\u00e9s elnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Egy jelsz\u00f3 a tartalom \u00e9s a kivonat v\u00e9delm\u00e9hez.","type":"string","required":false},"content":{"description":"A bejegyz\u00e9s tartalma.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s tartalma, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML tartalma, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"A bejegyz\u00e9s \u00e1ltal haszn\u00e1lt tartalom blokk verzi\u00f3ja.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Amennyiben a tartalom jelsz\u00f3val v\u00e9dett.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"A bejegyz\u00e9s megjelen\u00edt\u00e9s\u00e9hez haszn\u00e1lt sablon f\u00e1jl.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/rm_content_editor\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Az automatikus ment\u00e9s sz\u00fcl\u0151j\u00e9nek azonos\u00edt\u00f3ja.","type":"integer","required":false},"id":{"description":"Az ID  az automatikus ment\u00e9shez.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/rank_math_schema":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"after":{"description":"Hozz\u00e1sz\u00f3l\u00e1sok korl\u00e1toz\u00e1sa a megadott ISO8601 form\u00e1tum\u00fa d\u00e1tum ut\u00e1n k\u00f6zz\u00e9tett bejegyz\u00e9sek eset\u00e9n.","type":"string","format":"date-time","required":false},"modified_after":{"description":"A v\u00e1lasz korl\u00e1toz\u00e1sa a megadott ISO8601 d\u00e1tum ut\u00e1n m\u00f3dos\u00edtott posztokra.","type":"string","format":"date-time","required":false},"before":{"description":"Korl\u00e1tozza a v\u00e1laszt egy adott ISO8601 form\u00e1tum\u00fa d\u00e1tumot megel\u0151z\u0151en k\u00f6zz\u00e9tett bejegyz\u00e9sekre.","type":"string","format":"date-time","required":false},"modified_before":{"description":"A v\u00e1lasz korl\u00e1toz\u00e1sa a megadott ISO8601 d\u00e1tum el\u0151tt m\u00f3dos\u00edtott posztokra.","type":"string","format":"date-time","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Hogyan kell \u00e9rtelmezni a keres\u00e9si bemenetet.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Gy\u0171jtem\u00e9ny rendez\u00e9se a bejegyz\u00e9st tulajdons\u00e1g szerint.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"A keresend\u0151 oszlopnevek t\u00f6mbje.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Korl\u00e1tozza az eredm\u00e9ny k\u00e9szletet az egy vagy t\u00f6bb meghat\u00e1rozott keres\u0151bar\u00e1t n\u00e9vvel rendelkez\u0151 bejegyz\u00e9sekre.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Korl\u00e1tozza az eredm\u00e9ny k\u00e9szletet az egy vagy t\u00f6bb \u00e1llapothoz rendelt bejegyz\u00e9sekhez.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"A bejegyz\u00e9s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Az bejegyz\u00e9s publik\u00e1l\u00e1s\u00e1nak id\u0151pontja GMT szerinti.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"A bejegyz\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"status":{"description":"A bejegyz\u00e9s elnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Egy jelsz\u00f3 a tartalom \u00e9s a kivonat v\u00e9delm\u00e9hez.","type":"string","required":false},"title":{"description":"A bejegyz\u00e9s c\u00edme.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s c\u00edme, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML c\u00edme, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"A bejegyz\u00e9s megjelen\u00edt\u00e9s\u00e9hez haszn\u00e1lt sablon f\u00e1jl.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/rank_math_schema"}]}},"\/wp\/v2\/rank_math_schema\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"A jelsz\u00f3 a bejegyz\u00e9shez, ha az jelsz\u00f3val v\u00e9dett.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"date":{"description":"A bejegyz\u00e9s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Az bejegyz\u00e9s publik\u00e1l\u00e1s\u00e1nak id\u0151pontja GMT szerinti.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"A bejegyz\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"status":{"description":"A bejegyz\u00e9s elnevezett \u00e1llapota.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Egy jelsz\u00f3 a tartalom \u00e9s a kivonat v\u00e9delm\u00e9hez.","type":"string","required":false},"title":{"description":"A bejegyz\u00e9s c\u00edme.","type":"object","properties":{"raw":{"description":"A bejegyz\u00e9s c\u00edme, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A bejegyz\u00e9s HTML c\u00edme, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"A bejegyz\u00e9s megjelen\u00edt\u00e9s\u00e9hez haszn\u00e1lt sablon f\u00e1jl.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"A bejegyz\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Hagyjuk-e ki a Lomt\u00e1rat, \u00e9s t\u00f6r\u00f6lj\u00fcnk egyb\u0151l.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"A bejegyz\u00e9s t\u00edpus bet\u0171kb\u0151l \u00e9s sz\u00e1mokb\u00f3l \u00e1ll\u00f3 azonos\u00edt\u00f3ja.","type":"string","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Az \u00e1llapot bet\u0171kb\u0151l \u00e9s sz\u00e1mokb\u00f3l \u00e1ll\u00f3 azonos\u00edt\u00f3ja.","type":"string","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Korl\u00e1tozzuk az eredm\u00e9nyhalmazt egy meghat\u00e1rozott bejegyz\u00e9s t\u00edpushoz t\u00e1rs\u00edtott oszt\u00e1lyoz\u00e1shoz.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Az oszt\u00e1lyoz\u00e1s bet\u0171kb\u0151l \u00e9s sz\u00e1mokb\u00f3l \u00e1ll\u00f3 azonos\u00edt\u00f3ja.","type":"string","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u00d6ssze\u00e1ll\u00edt\u00e1s rendez\u00e9se kifejez\u00e9s tulajdons\u00e1g szerint.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Rejts\u00fcnk-e el olyan kifejez\u00e9seket, amelyek nincsenek bejegyz\u00e9sekhez rendelve.","type":"boolean","default":false,"required":false},"parent":{"description":"Korl\u00e1tozza az eredm\u00e9nyhalmazt az adott sz\u00fcl\u0151h\u00f6z rendelt felt\u00e9telekhez.","type":"integer","required":false},"post":{"description":"Eredm\u00e9nyek korl\u00e1toz\u00e1sa az adott kifejez\u00e9sekhez t\u00e1rs\u00edtott bejegyz\u00e9sekre.","type":"integer","default":null,"required":false},"slug":{"description":"Korl\u00e1tozzuk az eredm\u00e9nyk\u00e9szletet olyan kifejez\u00e9sekre, amelyek egy vagy t\u00f6bb meghat\u00e1rozott keres\u0151bar\u00e1t n\u00e9vvel rendelkeznek.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML le\u00edr\u00e1s a kifejez\u00e9shez.","type":"string","required":false},"name":{"description":"A kifejez\u00e9s HTML-ben form\u00e1zott c\u00edme.","type":"string","required":true},"slug":{"description":"A kifejez\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"parent":{"description":"A sz\u00fcl\u0151 kifejez\u00e9s azonos\u00edt\u00f3ja.","type":"integer","required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"A kifejez\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"A kifejez\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"description":{"description":"HTML le\u00edr\u00e1s a kifejez\u00e9shez.","type":"string","required":false},"name":{"description":"A kifejez\u00e9s HTML-ben form\u00e1zott c\u00edme.","type":"string","required":false},"slug":{"description":"A kifejez\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"parent":{"description":"A sz\u00fcl\u0151 kifejez\u00e9s azonos\u00edt\u00f3ja.","type":"integer","required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"A kifejez\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Igaznak (true) kell lennie, mert a kifejez\u00e9seket nem lehet lomt\u00e1rba helyezni.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u00d6ssze\u00e1ll\u00edt\u00e1s rendez\u00e9se kifejez\u00e9s tulajdons\u00e1g szerint.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Rejts\u00fcnk-e el olyan kifejez\u00e9seket, amelyek nincsenek bejegyz\u00e9sekhez rendelve.","type":"boolean","default":false,"required":false},"post":{"description":"Eredm\u00e9nyek korl\u00e1toz\u00e1sa az adott kifejez\u00e9sekhez t\u00e1rs\u00edtott bejegyz\u00e9sekre.","type":"integer","default":null,"required":false},"slug":{"description":"Korl\u00e1tozzuk az eredm\u00e9nyk\u00e9szletet olyan kifejez\u00e9sekre, amelyek egy vagy t\u00f6bb meghat\u00e1rozott keres\u0151bar\u00e1t n\u00e9vvel rendelkeznek.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML le\u00edr\u00e1s a kifejez\u00e9shez.","type":"string","required":false},"name":{"description":"A kifejez\u00e9s HTML-ben form\u00e1zott c\u00edme.","type":"string","required":true},"slug":{"description":"A kifejez\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"A kifejez\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"A kifejez\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"description":{"description":"HTML le\u00edr\u00e1s a kifejez\u00e9shez.","type":"string","required":false},"name":{"description":"A kifejez\u00e9s HTML-ben form\u00e1zott c\u00edme.","type":"string","required":false},"slug":{"description":"A kifejez\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"A kifejez\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Igaznak (true) kell lennie, mert a kifejez\u00e9seket nem lehet lomt\u00e1rba helyezni.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u00d6ssze\u00e1ll\u00edt\u00e1s rendez\u00e9se kifejez\u00e9s tulajdons\u00e1g szerint.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Rejts\u00fcnk-e el olyan kifejez\u00e9seket, amelyek nincsenek bejegyz\u00e9sekhez rendelve.","type":"boolean","default":false,"required":false},"post":{"description":"Eredm\u00e9nyek korl\u00e1toz\u00e1sa az adott kifejez\u00e9sekhez t\u00e1rs\u00edtott bejegyz\u00e9sekre.","type":"integer","default":null,"required":false},"slug":{"description":"Korl\u00e1tozzuk az eredm\u00e9nyk\u00e9szletet olyan kifejez\u00e9sekre, amelyek egy vagy t\u00f6bb meghat\u00e1rozott keres\u0151bar\u00e1t n\u00e9vvel rendelkeznek.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML le\u00edr\u00e1s a kifejez\u00e9shez.","type":"string","required":false},"name":{"description":"A kifejez\u00e9s HTML-ben form\u00e1zott c\u00edme.","type":"string","required":true},"slug":{"description":"A kifejez\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":[],"required":false},"locations":{"description":"A men\u00fch\u00f6z rendelt helyek.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"A legfels\u0151 szint\u0171 oldalak automatikus hozz\u00e1ad\u00e1sa ehhez a men\u00fch\u00f6z.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"A kifejez\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"A kifejez\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"description":{"description":"HTML le\u00edr\u00e1s a kifejez\u00e9shez.","type":"string","required":false},"name":{"description":"A kifejez\u00e9s HTML-ben form\u00e1zott c\u00edme.","type":"string","required":false},"slug":{"description":"A kifejez\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":[],"required":false},"locations":{"description":"A men\u00fch\u00f6z rendelt helyek.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"A legfels\u0151 szint\u0171 oldalak automatikus hozz\u00e1ad\u00e1sa ehhez a men\u00fch\u00f6z.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"A kifejez\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Igaznak (true) kell lennie, mert a kifejez\u00e9seket nem lehet lomt\u00e1rba helyezni.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u00d6ssze\u00e1ll\u00edt\u00e1s rendez\u00e9se kifejez\u00e9s tulajdons\u00e1g szerint.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Rejts\u00fcnk-e el olyan kifejez\u00e9seket, amelyek nincsenek bejegyz\u00e9sekhez rendelve.","type":"boolean","default":false,"required":false},"post":{"description":"Eredm\u00e9nyek korl\u00e1toz\u00e1sa az adott kifejez\u00e9sekhez t\u00e1rs\u00edtott bejegyz\u00e9sekre.","type":"integer","default":null,"required":false},"slug":{"description":"Korl\u00e1tozzuk az eredm\u00e9nyk\u00e9szletet olyan kifejez\u00e9sekre, amelyek egy vagy t\u00f6bb meghat\u00e1rozott keres\u0151bar\u00e1t n\u00e9vvel rendelkeznek.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML le\u00edr\u00e1s a kifejez\u00e9shez.","type":"string","required":false},"name":{"description":"A kifejez\u00e9s HTML-ben form\u00e1zott c\u00edme.","type":"string","required":true},"slug":{"description":"A kifejez\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"A kifejez\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"A kifejez\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"description":{"description":"HTML le\u00edr\u00e1s a kifejez\u00e9shez.","type":"string","required":false},"name":{"description":"A kifejez\u00e9s HTML-ben form\u00e1zott c\u00edme.","type":"string","required":false},"slug":{"description":"A kifejez\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"A kifejez\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Igaznak (true) kell lennie, mert a kifejez\u00e9seket nem lehet lomt\u00e1rba helyezni.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/rank_math_redirection_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"\u00d6ssze\u00e1ll\u00edt\u00e1s rendez\u00e9se kifejez\u00e9s tulajdons\u00e1g szerint.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Rejts\u00fcnk-e el olyan kifejez\u00e9seket, amelyek nincsenek bejegyz\u00e9sekhez rendelve.","type":"boolean","default":false,"required":false},"parent":{"description":"Korl\u00e1tozza az eredm\u00e9nyhalmazt az adott sz\u00fcl\u0151h\u00f6z rendelt felt\u00e9telekhez.","type":"integer","required":false},"post":{"description":"Eredm\u00e9nyek korl\u00e1toz\u00e1sa az adott kifejez\u00e9sekhez t\u00e1rs\u00edtott bejegyz\u00e9sekre.","type":"integer","default":null,"required":false},"slug":{"description":"Korl\u00e1tozzuk az eredm\u00e9nyk\u00e9szletet olyan kifejez\u00e9sekre, amelyek egy vagy t\u00f6bb meghat\u00e1rozott keres\u0151bar\u00e1t n\u00e9vvel rendelkeznek.","type":"array","items":{"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML le\u00edr\u00e1s a kifejez\u00e9shez.","type":"string","required":false},"name":{"description":"A kifejez\u00e9s HTML-ben form\u00e1zott c\u00edme.","type":"string","required":true},"slug":{"description":"A kifejez\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"parent":{"description":"A sz\u00fcl\u0151 kifejez\u00e9s azonos\u00edt\u00f3ja.","type":"integer","required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/rank_math_redirection_category"}]}},"\/wp\/v2\/rank_math_redirection_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"A kifejez\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"A kifejez\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"description":{"description":"HTML le\u00edr\u00e1s a kifejez\u00e9shez.","type":"string","required":false},"name":{"description":"A kifejez\u00e9s HTML-ben form\u00e1zott c\u00edme.","type":"string","required":false},"slug":{"description":"A kifejez\u00e9s alfanumerikus azonos\u00edt\u00f3ja, amely a t\u00edpus\u00e1ra n\u00e9zve egyedi.","type":"string","required":false},"parent":{"description":"A sz\u00fcl\u0151 kifejez\u00e9s azonos\u00edt\u00f3ja.","type":"integer","required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"A kifejez\u00e9s egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Igaznak (true) kell lennie, mert a kifejez\u00e9seket nem lehet lomt\u00e1rba helyezni.","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"default":"asc","description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Gy\u0171jtem\u00e9ny rendez\u00e9se felhaszn\u00e1l\u00f3i attrib\u00fatum szerint.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Korl\u00e1tozzuk az eredm\u00e9nyt felhaszn\u00e1l\u00f3kra egy vagy t\u00f6bb meghat\u00e1rozott keres\u0151bar\u00e1t n\u00e9vvel.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Korl\u00e1tozza az eredm\u00e9nyhalmazt a legal\u00e1bb egy meghat\u00e1rozott szerepk\u00f6rh\u00f6z tartoz\u00f3 felhaszn\u00e1l\u00f3kra. CSV list\u00e1t vagy egyetlen szerepet fogad el.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Korl\u00e1tozza az eredm\u00e9nyk\u00e9szletet azokra a felhaszn\u00e1l\u00f3kra, akik megfelelnek legal\u00e1bb egy adott adott k\u00e9pess\u00e9gnek. Elfogadja a csv list\u00e1t vagy egyetlen k\u00e9pess\u00e9get.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Az eredm\u00e9nyek sz\u0171k\u00edt\u00e9se olyan felhaszn\u00e1l\u00f3kra akik szerz\u0151k.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Az eredm\u00e9ny korl\u00e1toz\u00e1sa azokra a felhaszn\u00e1l\u00f3kra, akiknek vannak k\u00f6zz\u00e9tett a bejegyz\u00e9seik.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","rm_content_editor":"rm_content_editor","rank_math_schema":"rank_math_schema"}},"required":false},"search_columns":{"default":[],"description":"A keresend\u0151 oszlopnevek t\u00f6mbje.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Felhaszn\u00e1l\u00f3 bel\u00e9p\u00e9si neve.","type":"string","required":true},"name":{"description":"Felhaszn\u00e1l\u00f3 nev\u00e9nek megjelen\u00edt\u00e9se.","type":"string","required":false},"first_name":{"description":"A felhaszn\u00e1l\u00f3 kereszt neve.","type":"string","required":false},"last_name":{"description":"A felhaszn\u00e1l\u00f3 vezet\u00e9k neve.","type":"string","required":false},"email":{"description":"Felhaszn\u00e1l\u00f3 e-mail c\u00edme.","type":"string","format":"email","required":true},"url":{"description":"A felhaszn\u00e1l\u00f3 URL c\u00edme.","type":"string","format":"uri","required":false},"description":{"description":"A felhaszn\u00e1l\u00f3 bemutatkoz\u00e1sa.","type":"string","required":false},"locale":{"description":"A felhaszn\u00e1l\u00f3 nyelve.","type":"string","enum":["","en_US","bg_BG","cs_CZ","de_DE","el","es_ES","fr_FR","hu_HU","it_IT","ja","nl_NL","pl_PL","pt_BR","pt_PT","ru_RU","sk_SK","sl_SI","sv_SE","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"A felhaszn\u00e1l\u00f3 beceneve.","type":"string","required":false},"slug":{"description":"Egy alfanumerikus azonos\u00edt\u00f3 a felhaszn\u00e1l\u00f3 sz\u00e1m\u00e1ra.","type":"string","required":false},"roles":{"description":"A felhaszn\u00e1l\u00f3 szerepk\u00f6rei.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Jelsz\u00f3 a felhaszn\u00e1l\u00f3nak (sosem tartalmazza).","type":"string","required":true},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"A be\u00e1ll\u00edt\u00e1sok friss\u00edt\u00e9s\u00e9nek d\u00e1tuma \u00e9s id\u0151pontja.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"A felhaszn\u00e1l\u00f3 egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"A felhaszn\u00e1l\u00f3 egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"username":{"description":"Felhaszn\u00e1l\u00f3 bel\u00e9p\u00e9si neve.","type":"string","required":false},"name":{"description":"Felhaszn\u00e1l\u00f3 nev\u00e9nek megjelen\u00edt\u00e9se.","type":"string","required":false},"first_name":{"description":"A felhaszn\u00e1l\u00f3 kereszt neve.","type":"string","required":false},"last_name":{"description":"A felhaszn\u00e1l\u00f3 vezet\u00e9k neve.","type":"string","required":false},"email":{"description":"Felhaszn\u00e1l\u00f3 e-mail c\u00edme.","type":"string","format":"email","required":false},"url":{"description":"A felhaszn\u00e1l\u00f3 URL c\u00edme.","type":"string","format":"uri","required":false},"description":{"description":"A felhaszn\u00e1l\u00f3 bemutatkoz\u00e1sa.","type":"string","required":false},"locale":{"description":"A felhaszn\u00e1l\u00f3 nyelve.","type":"string","enum":["","en_US","bg_BG","cs_CZ","de_DE","el","es_ES","fr_FR","hu_HU","it_IT","ja","nl_NL","pl_PL","pt_BR","pt_PT","ru_RU","sk_SK","sl_SI","sv_SE","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"A felhaszn\u00e1l\u00f3 beceneve.","type":"string","required":false},"slug":{"description":"Egy alfanumerikus azonos\u00edt\u00f3 a felhaszn\u00e1l\u00f3 sz\u00e1m\u00e1ra.","type":"string","required":false},"roles":{"description":"A felhaszn\u00e1l\u00f3 szerepk\u00f6rei.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Jelsz\u00f3 a felhaszn\u00e1l\u00f3nak (sosem tartalmazza).","type":"string","required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"A be\u00e1ll\u00edt\u00e1sok friss\u00edt\u00e9s\u00e9nek d\u00e1tuma \u00e9s id\u0151pontja.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"A felhaszn\u00e1l\u00f3 egyedi azonos\u00edt\u00f3ja.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"True \u00e9rt\u00e9knek kell lennie, mert a felhaszn\u00e1l\u00f3kat nem lehet Lomt\u00e1rba helyezni.","required":false},"reassign":{"type":"integer","description":"Hozz\u00e1rendelj\u00fck a t\u00f6r\u00f6lt felhaszn\u00e1l\u00f3 hivatkoz\u00e1sait \u00e9s bejegyz\u00e9seit az al\u00e1bbi felhaszn\u00e1l\u00f3hoz.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Felhaszn\u00e1l\u00f3 bel\u00e9p\u00e9si neve.","type":"string","required":false},"name":{"description":"Felhaszn\u00e1l\u00f3 nev\u00e9nek megjelen\u00edt\u00e9se.","type":"string","required":false},"first_name":{"description":"A felhaszn\u00e1l\u00f3 kereszt neve.","type":"string","required":false},"last_name":{"description":"A felhaszn\u00e1l\u00f3 vezet\u00e9k neve.","type":"string","required":false},"email":{"description":"Felhaszn\u00e1l\u00f3 e-mail c\u00edme.","type":"string","format":"email","required":false},"url":{"description":"A felhaszn\u00e1l\u00f3 URL c\u00edme.","type":"string","format":"uri","required":false},"description":{"description":"A felhaszn\u00e1l\u00f3 bemutatkoz\u00e1sa.","type":"string","required":false},"locale":{"description":"A felhaszn\u00e1l\u00f3 nyelve.","type":"string","enum":["","en_US","bg_BG","cs_CZ","de_DE","el","es_ES","fr_FR","hu_HU","it_IT","ja","nl_NL","pl_PL","pt_BR","pt_PT","ru_RU","sk_SK","sl_SI","sv_SE","vi","zh_CN","zh_TW"],"required":false},"nickname":{"description":"A felhaszn\u00e1l\u00f3 beceneve.","type":"string","required":false},"slug":{"description":"Egy alfanumerikus azonos\u00edt\u00f3 a felhaszn\u00e1l\u00f3 sz\u00e1m\u00e1ra.","type":"string","required":false},"roles":{"description":"A felhaszn\u00e1l\u00f3 szerepk\u00f6rei.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Jelsz\u00f3 a felhaszn\u00e1l\u00f3nak (sosem tartalmazza).","type":"string","required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"A be\u00e1ll\u00edt\u00e1sok friss\u00edt\u00e9s\u00e9nek d\u00e1tuma \u00e9s id\u0151pontja.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"True \u00e9rt\u00e9knek kell lennie, mert a felhaszn\u00e1l\u00f3kat nem lehet Lomt\u00e1rba helyezni.","required":false},"reassign":{"type":"integer","description":"Hozz\u00e1rendelj\u00fck a t\u00f6r\u00f6lt felhaszn\u00e1l\u00f3 hivatkoz\u00e1sait \u00e9s bejegyz\u00e9seit az al\u00e1bbi felhaszn\u00e1l\u00f3hoz.","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"Az alkalmaz\u00e1s \u00e1ltal megadott UUID, hogy egyedileg azonos\u00edtsuk. Az UUID v5 haszn\u00e1lata javasolt URL-el, vagy DNS n\u00e9vt\u00e9rrel. ","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Az alkalmaz\u00e1s jelsz\u00f3 neve.","type":"string","minLength":1,"pattern":".*\\S.*","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"Az alkalmaz\u00e1s \u00e1ltal megadott UUID, hogy egyedileg azonos\u00edtsuk. Az UUID v5 haszn\u00e1lata javasolt URL-el, vagy DNS n\u00e9vt\u00e9rrel. ","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Az alkalmaz\u00e1s jelsz\u00f3 neve.","type":"string","minLength":1,"pattern":".*\\S.*","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"after":{"description":"A k\u00f6zz\u00e9tett hozz\u00e1sz\u00f3l\u00e1sok v\u00e1laszainak korl\u00e1toz\u00e1sa, miut\u00e1n ISO8601-nak megfelel\u0151 d\u00e1tumot kapott.","type":"string","format":"date-time","required":false},"author":{"description":"Korl\u00e1tozza az eredm\u00e9nyhalmazt az egyes felhaszn\u00e1l\u00f3i azonos\u00edt\u00f3khoz rendelt megjegyz\u00e9sekre. Bejelentkez\u00e9st ig\u00e9nyel.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Gy\u0151z\u0151dj\u00f6n meg arr\u00f3l, hogy az eredm\u00e9nyhalmaz nem tartalmazz konkr\u00e9t felhaszn\u00e1l\u00f3i azonos\u00edt\u00f3hoz rendelt megjegyz\u00e9seket. Bejelentkez\u00e9st ig\u00e9nyel.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Korl\u00e1tozza az eredm\u00e9nyhalmazt egy adott szerz\u0151i e-mail c\u00edmre. Bejelentkez\u00e9st ig\u00e9nyel.","format":"email","type":"string","required":false},"before":{"description":"A k\u00f6zz\u00e9tett hozz\u00e1sz\u00f3l\u00e1sok v\u00e1laszainak korl\u00e1toz\u00e1sa, miel\u0151tt ISO8601-nak megfelel\u0151 d\u00e1tumot kapna.","type":"string","format":"date-time","required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Gy\u0171jtem\u00e9ny rendez\u00e9se a hozz\u00e1sz\u00f3l\u00e1s tulajdons\u00e1g szerint.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Korl\u00e1tozza az eredm\u00e9nyhalmazt konkr\u00e9t sz\u00fcl\u0151 azonos\u00edt\u00f3khoz tartoz\u00f3 megjegyz\u00e9sekre.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Biztos\u00edtsuk, hogy az eredm\u00e9nyk\u00e9szletben nem szerepelnek bizonyos sz\u00fcl\u0151 azonos\u00edt\u00f3k.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Korl\u00e1tozza az eredm\u00e9nyhalmazt konkr\u00e9t bejegyz\u00e9s azonos\u00edt\u00f3khoz rendelt megjegyz\u00e9sekre.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Korl\u00e1tozzuk az eredm\u00e9nyhalmazt a megadott \u00e1llapothoz tartoz\u00f3 hozz\u00e1sz\u00f3l\u00e1sokra. Bejelentkez\u00e9st ig\u00e9nyel.","type":"string","required":false},"type":{"default":"comment","description":"Korl\u00e1tozza az eredm\u00e9nyhalmazt az adott t\u00edpushoz rendelt megjegyz\u00e9sekre. Bejelentkez\u00e9st ig\u00e9nyel.","type":"string","required":false},"password":{"description":"A jelsz\u00f3 a bejegyz\u00e9shez, ha az jelsz\u00f3val v\u00e9dett.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"author":{"description":"A felhaszn\u00e1l\u00f3i objektum azonos\u00edt\u00f3ja, ha a szerz\u0151 egy felhaszn\u00e1l\u00f3.","type":"integer","required":false},"author_email":{"description":"A hozz\u00e1sz\u00f3l\u00e1s szerz\u0151j\u00e9nek e-mail c\u00edme.","type":"string","format":"email","required":false},"author_ip":{"description":"A hozz\u00e1sz\u00f3l\u00e1s szerz\u0151j\u00e9nek IP c\u00edme.","type":"string","format":"ip","required":false},"author_name":{"description":"A hozz\u00e1sz\u00f3l\u00e1s szerz\u0151j\u00e9nek megjelen\u00edtett neve.","type":"string","required":false},"author_url":{"description":"A hozz\u00e1sz\u00f3l\u00e1s szerz\u0151j\u00e9nek URL-je.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"A hozz\u00e1sz\u00f3l\u00e1s szerz\u0151j\u00e9nek User agent mez\u0151je.","type":"string","required":false},"content":{"description":"A hozz\u00e1sz\u00f3l\u00e1s tartalma.","type":"object","properties":{"raw":{"description":"A hozz\u00e1sz\u00f3l\u00e1s tartalma, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A hozz\u00e1sz\u00f3l\u00e1s HTML tartalma, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"A hozz\u00e1sz\u00f3l\u00e1s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"A hozz\u00e1sz\u00f3l\u00e1s k\u00f6zz\u00e9t\u00e9tel\u00e9nek id\u0151pontja, GMT szerint.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"A sz\u00fcl\u0151 hozz\u00e1sz\u00f3l\u00e1s azonos\u00edt\u00f3ja ID.","type":"integer","required":false},"post":{"default":0,"description":"A bejegyz\u00e9s objektumhoz t\u00e1rs\u00edtott azonos\u00edt\u00f3 (ID).","type":"integer","required":false},"status":{"description":"A hozz\u00e1sz\u00f3l\u00e1s \u00e1llapota.","type":"string","required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Jegyzet megold\u00e1si st\u00e1tusza","default":"","enum":["resolved","reopen"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Egyedi azonos\u00edt\u00f3 a hozz\u00e1sz\u00f3l\u00e1shoz.","type":"integer","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"A hozz\u00e1sz\u00f3l\u00e1s sz\u00fcl\u0151 bejegyz\u00e9s\u00e9nek a jelszava (ha a bejegyz\u00e9s jelsz\u00f3val v\u00e9dett).","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Egyedi azonos\u00edt\u00f3 a hozz\u00e1sz\u00f3l\u00e1shoz.","type":"integer","required":false},"author":{"description":"A felhaszn\u00e1l\u00f3i objektum azonos\u00edt\u00f3ja, ha a szerz\u0151 egy felhaszn\u00e1l\u00f3.","type":"integer","required":false},"author_email":{"description":"A hozz\u00e1sz\u00f3l\u00e1s szerz\u0151j\u00e9nek e-mail c\u00edme.","type":"string","format":"email","required":false},"author_ip":{"description":"A hozz\u00e1sz\u00f3l\u00e1s szerz\u0151j\u00e9nek IP c\u00edme.","type":"string","format":"ip","required":false},"author_name":{"description":"A hozz\u00e1sz\u00f3l\u00e1s szerz\u0151j\u00e9nek megjelen\u00edtett neve.","type":"string","required":false},"author_url":{"description":"A hozz\u00e1sz\u00f3l\u00e1s szerz\u0151j\u00e9nek URL-je.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"A hozz\u00e1sz\u00f3l\u00e1s szerz\u0151j\u00e9nek User agent mez\u0151je.","type":"string","required":false},"content":{"description":"A hozz\u00e1sz\u00f3l\u00e1s tartalma.","type":"object","properties":{"raw":{"description":"A hozz\u00e1sz\u00f3l\u00e1s tartalma, ahogyan az adatb\u00e1zisban szerepel.","type":"string","context":["edit"]},"rendered":{"description":"A hozz\u00e1sz\u00f3l\u00e1s HTML tartalma, megjelen\u00edt\u00e9shez \u00e1talak\u00edtva.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"A hozz\u00e1sz\u00f3l\u00e1s k\u00f6zz\u00e9t\u00e9tel\u00e9nek d\u00e1tuma, a webhely id\u0151z\u00f3n\u00e1j\u00e1ban.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"A hozz\u00e1sz\u00f3l\u00e1s k\u00f6zz\u00e9t\u00e9tel\u00e9nek id\u0151pontja, GMT szerint.","type":"string","format":"date-time","required":false},"parent":{"description":"A sz\u00fcl\u0151 hozz\u00e1sz\u00f3l\u00e1s azonos\u00edt\u00f3ja ID.","type":"integer","required":false},"post":{"description":"A bejegyz\u00e9s objektumhoz t\u00e1rs\u00edtott azonos\u00edt\u00f3 (ID).","type":"integer","required":false},"status":{"description":"A hozz\u00e1sz\u00f3l\u00e1s \u00e1llapota.","type":"string","required":false},"meta":{"description":"Meta mez\u0151k.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Jegyzet megold\u00e1si st\u00e1tusza","default":"","enum":["resolved","reopen"]}},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Egyedi azonos\u00edt\u00f3 a hozz\u00e1sz\u00f3l\u00e1shoz.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Hagyjuk-e ki a Lomt\u00e1rat, \u00e9s t\u00f6r\u00f6lj\u00fcnk egyb\u0151l.","required":false},"password":{"description":"A hozz\u00e1sz\u00f3l\u00e1s sz\u00fcl\u0151 bejegyz\u00e9s\u00e9nek a jelszava (ha a bejegyz\u00e9s jelsz\u00f3val v\u00e9dett).","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"type":{"default":"post","description":"Az eredm\u00e9nyek limit\u00e1l\u00e1sa egy objektum t\u00edpus\u00e1n\u00e1l.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Az eredm\u00e9ny meghat\u00e1roz\u00e1sa egy vagy t\u00f6bb objektum alt\u00edpus eset\u00e9n.","type":"array","items":{"enum":["post","page","category","post_tag","any"],"type":"string"},"required":false},"exclude":{"description":"Biztos\u00edtsa, hogy az eredm\u00e9nyhalmaz kiz\u00e1r konkr\u00e9t egyedi azonos\u00edt\u00f3kat.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Eredm\u00e9nyek sz\u0171r\u00e9se speci\u00e1lis azonos\u00edt\u00f3kkal (ID).","type":"array","items":{"type":"integer"},"default":[],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Egyedi regisztr\u00e1lt n\u00e9v a blokknak.","type":"string","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Blokk tulajdons\u00e1gai.","type":"object","default":[],"required":false},"post_id":{"description":"A bejegyz\u00e9s kontextus azonos\u00edt\u00f3ja.","type":"integer","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Blokk n\u00e9vt\u00e9r.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Blokk n\u00e9vt\u00e9r.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Blokk neve.","type":"string","required":false},"namespace":{"description":"Blokk n\u00e9vt\u00e9r.","type":"string","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"title":{"title":"C\u00edm","description":"Honlap c\u00edmsor.","type":"string","required":false},"description":{"title":"Honlap egysoros le\u00edr\u00e1sa","description":"Honlap egysoros le\u00edr\u00e1sa.","type":"string","required":false},"url":{"title":"","description":"Honlap URL c\u00edme.","type":"string","format":"uri","required":false},"email":{"title":"","description":"Ez a c\u00edm adminisztr\u00e1ci\u00f3s c\u00e9lt szolg\u00e1l, hasonl\u00f3an, mint pl. a felhaszn\u00e1l\u00f3i \u00e9rtes\u00edt\u00e9sek.","type":"string","format":"email","required":false},"timezone":{"title":"","description":"Egy telep\u00fcl\u00e9s ami a saj\u00e1t id\u0151z\u00f3n\u00e1nkkal azonos helyen van.","type":"string","required":false},"date_format":{"title":"","description":"D\u00e1tumform\u00e1tum az \u00f6sszes d\u00e1tumhoz.","type":"string","required":false},"time_format":{"title":"","description":"Id\u0151form\u00e1tum az \u00f6sszes id\u0151h\u00f6z.","type":"string","required":false},"start_of_week":{"title":"","description":"A h\u00e9t kezd\u0151napja.","type":"integer","required":false},"language":{"title":"","description":"WordPress nyelves\u00edt\u00e9s k\u00f3dja.","type":"string","required":false},"use_smilies":{"title":"","description":"Konvert\u00e1ljuk a hangulatjeleket, mint pl. a :-), \u00e9s :-P grafikus megjelen\u00edt\u00e9s\u0171v\u00e9.","type":"boolean","required":false},"default_category":{"title":"","description":"Alap\u00e9rtelmezett bejegyz\u00e9s kateg\u00f3ria.","type":"integer","required":false},"default_post_format":{"title":"","description":"Alap\u00e9rtelmezett bejegyz\u00e9s form\u00e1tum.","type":"string","required":false},"posts_per_page":{"title":"A bejegyz\u00e9sek maxim\u00e1lis sz\u00e1ma oldalank\u00e9nt","description":"Legfeljebb ennyi blog oldal megjelen\u00edt\u00e9se.","type":"integer","required":false},"show_on_front":{"title":"Megjelen\u00e9s el\u0151l","description":"Mi jelenjen meg az kezd\u0151lapon?","type":"string","required":false},"page_on_front":{"title":"F\u0151oldal","description":"Az oldal azonos\u00edt\u00f3ja (ID), amelyet a c\u00edmlapon meg kell jelen\u00edteni","type":"integer","required":false},"page_for_posts":{"title":"","description":"Annak az oldalnak az azonos\u00edt\u00f3ja (ID), amelyen a legfrissebb bejegyz\u00e9seket kell megjelen\u00edteni","type":"integer","required":false},"default_ping_status":{"title":"","description":"A linkek enged\u00e9lyez\u00e9se m\u00e1sik blognak \u00faj bejegyz\u00e9s eset\u00e9n (pingbacks and trackback)","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Hozz\u00e1sz\u00f3l\u00e1sok enged\u00e9lyez\u00e9se az \u00faj bejegyz\u00e9seken","description":"Enged\u00e9lyezz\u00fck az embereknek, hogy hozz\u00e1sz\u00f3ljanak az \u00faj bejegyz\u00e9sekhez.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Log\u00f3","description":"Honlap log\u00f3.","type":"integer","required":false},"site_icon":{"title":"Ikon","description":"Webhely ikon.","type":"integer","required":false},"aab_settings_defaults":{"title":"","description":"","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Az eredm\u00e9ny meghat\u00e1roz\u00e1sa egy vagy t\u00f6bb kijel\u00f6lt st\u00e1tusz eset\u00e9n.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"A sablon st\u00edluslapja. Ez a sablon egyedi azonos\u00edt\u00f3ja.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"status":{"description":"Sz\u0171k\u00edts\u00fck le a keres\u00e9si eredm\u00e9nyeket a megadott \u00e1llapot szerint.","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"WordPress.org b\u0151v\u00edtm\u00e9ny mappa keres\u0151bar\u00e1t neve.","pattern":"[\\w\\-]+","required":true},"status":{"description":"A b\u0151v\u00edtm\u00e9ny aktiv\u00e1l\u00e1si \u00e1llapota.","type":"string","enum":["inactive","active"],"default":"inactive","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"A b\u0151v\u00edtm\u00e9ny aktiv\u00e1l\u00e1si \u00e1llapota.","type":"string","enum":["inactive","active"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"A regisztr\u00e1lt oldals\u00e1v azonos\u00edt\u00f3ja","type":"string","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Egym\u00e1sba \u00e1gyazott widgetek.","type":"array","items":{"type":["object","string"]},"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"A widget t\u00edpus azonos\u00edt\u00f3ja.","type":"string","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"A widget t\u00edpus azonos\u00edt\u00f3ja.","type":"string","required":true},"instance":{"description":"A jelenlegi p\u00e9ld\u00e1ny widget be\u00e1ll\u00edt\u00e1sai","type":"object","required":false},"form_data":{"description":"Soros\u00edtott widget \u0171rlapadatok a p\u00e9ld\u00e1nybe\u00e1ll\u00edt\u00e1sokba k\u00f3doland\u00f3.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"A widget t\u00edpus azonos\u00edt\u00f3ja.","type":"string","required":true},"instance":{"description":"A jelenlegi p\u00e9ld\u00e1ny widget be\u00e1ll\u00edt\u00e1sai","type":"object","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"Az oldals\u00e1v a widgetek visszak\u00fcld\u00e9s\u00e9hez.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Widget egyedi azonos\u00edt\u00f3ja.","type":"string","required":false},"id_base":{"description":"A widget t\u00edpusa. Megfelel a widget t\u00edpus\u00fa v\u00e9gponton az azonos\u00edt\u00f3nak.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"Az oldals\u00e1v, amelyhez a widget tartozik.","type":"string","required":true},"instance":{"description":"Widget be\u00e1ll\u00edt\u00e1sok, ha t\u00e1mogatott.","type":"object","properties":{"encoded":{"description":"A p\u00e9ld\u00e1ny be\u00e1ll\u00edt\u00e1sok base64 form\u00e1ban k\u00f3dolt megjelen\u00e9se.","type":"string","context":["edit"]},"hash":{"description":"A p\u00e9ld\u00e1ny be\u00e1ll\u00edt\u00e1sok titkos\u00edtott lenyomata.","type":"string","context":["edit"]},"raw":{"description":"K\u00f3dolatlan p\u00e9ld\u00e1nybe\u00e1ll\u00edt\u00e1sok, ha t\u00e1mogatott.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-k\u00f3dolt \u0171rlapadatok a widget adminisztr\u00e1tori \u0171rlapj\u00e1r\u00f3l. Olyan widget friss\u00edt\u00e9s\u00e9re szolg\u00e1l, amely nem t\u00e1mogatja a p\u00e9ld\u00e1nyt. Csak \u00edrjon.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Widget egyedi azonos\u00edt\u00f3ja.","type":"string","required":false},"id_base":{"description":"A widget t\u00edpusa. Megfelel a widget t\u00edpus\u00fa v\u00e9gponton az azonos\u00edt\u00f3nak.","type":"string","required":false},"sidebar":{"description":"Az oldals\u00e1v, amelyhez a widget tartozik.","type":"string","required":false},"instance":{"description":"Widget be\u00e1ll\u00edt\u00e1sok, ha t\u00e1mogatott.","type":"object","properties":{"encoded":{"description":"A p\u00e9ld\u00e1ny be\u00e1ll\u00edt\u00e1sok base64 form\u00e1ban k\u00f3dolt megjelen\u00e9se.","type":"string","context":["edit"]},"hash":{"description":"A p\u00e9ld\u00e1ny be\u00e1ll\u00edt\u00e1sok titkos\u00edtott lenyomata.","type":"string","context":["edit"]},"raw":{"description":"K\u00f3dolatlan p\u00e9ld\u00e1nybe\u00e1ll\u00edt\u00e1sok, ha t\u00e1mogatott.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-k\u00f3dolt \u0171rlapadatok a widget adminisztr\u00e1tori \u0171rlapj\u00e1r\u00f3l. Olyan widget friss\u00edt\u00e9s\u00e9re szolg\u00e1l, amely nem t\u00e1mogatja a p\u00e9ld\u00e1nyt. Csak \u00edrjon.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"A widget elt\u00e1vol\u00edt\u00e1s\u00e1nak k\u00e9nyszer\u00edt\u00e9se, vagy \u00e1thelyez\u00e9se az inakt\u00edv oldals\u00e1vra.","type":"boolean","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"A keres\u0151 kifejez\u00e9ssel egyez\u0151 blokkok eredm\u00e9ny list\u00e1j\u00e1nak limit\u00e1l\u00e1sa.","type":"string","minLength":1,"required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","minLength":1,"required":false},"category":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se kateg\u00f3ria azonos\u00edt\u00f3 szerint.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se kulcssz\u00f3 azonos\u00edt\u00f3 szerint.","type":"integer","minimum":1,"required":false},"slug":{"description":"Korl\u00e1tozza az eredm\u00e9nyeket azokra, amelyek megfelelnek egy mint\u00e1nak (lass\u00fa).","type":"array","required":false},"offset":{"description":"Az eredm\u00e9ny eltol\u00e1sa egy megadott sz\u00e1m\u00fa elemmel.","type":"integer","required":false},"order":{"description":"Rendezd a tulajdons\u00e1gokat cs\u00f6kken\u0151 vagy n\u00f6vekv\u0151 sorrendbe.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Gy\u0171jtem\u00e9ny rendez\u00e9se a bejegyz\u00e9st tulajdons\u00e1g szerint.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Feldolgozand\u00f3 URL.","type":"string","format":"uri","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"A men\u00fc hely\u00e9nek alfanumerikus azonos\u00edt\u00f3ja.","type":"string","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"A k\u00e9pess\u00e9g kateg\u00f3ria egyedi azonos\u00edt\u00f3ja.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"A k\u00e9pess\u00e9g egyedi azonos\u00edt\u00f3ja.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"A k\u00e9pess\u00e9g v\u00e9grehajt\u00e1s\u00e1hoz sz\u00fcks\u00e9ges bemeneti param\u00e9terek.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Korl\u00e1tozzuk az eredm\u00e9nyeket az adott k\u00e9pess\u00e9gkateg\u00f3ri\u00e1ba tartoz\u00f3 k\u00e9pess\u00e9gekre.","type":"string","required":false},"namespace":{"description":"Limit results to abilities in a specific namespace.","type":"string","required":false},"meta":{"description":"Limit results to abilities matching all of the given meta fields.","type":"object","properties":{"annotations":{"description":"Limit results to abilities matching the given behavioral annotations.","type":"object","properties":{"readonly":{"description":"Whether the ability does not modify its environment.","type":["boolean","null"]},"destructive":{"description":"Whether the ability may perform destructive updates to its environment.","type":["boolean","null"]},"idempotent":{"description":"Whether repeated calls with the same arguments have no additional effect.","type":["boolean","null"]}},"additionalProperties":true}},"additionalProperties":true,"required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"A k\u00e9pess\u00e9g egyedi azonos\u00edt\u00f3ja.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/icons":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"collection":{"description":"Limit results to icons belonging to the given collection slug.","type":"string","pattern":"^[a-z0-9]([a-z0-9_-]*[a-z0-9])?$","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/icons"}]}},"\/wp\/v2\/icons\/(?P<collection>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"collection":{"description":"Limit results to icons belonging to the given collection slug.","type":"string","pattern":"^[a-z0-9]([a-z0-9_-]*[a-z0-9])?$","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/icons\/(?P<name>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?\/[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Ikon neve.","type":"string","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/icon-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"A gy\u0171jtem\u00e9ny aktu\u00e1lis oldala.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximum t\u00e9telek sz\u00e1ma az eredm\u00e9nyn\u00e9l.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Eredm\u00e9nyek sz\u0171k\u00edt\u00e9se a karakterl\u00e1ncot tartalmaz\u00f3kra.","type":"string","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/icon-collections"}]}},"\/wp\/v2\/icon-collections\/(?P<slug>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Icon collection slug.","type":"string","required":false},"context":{"description":"A terjedelem amelyre az elk\u00fcld\u00f6tt k\u00e9r\u00e9s vonatkozik; a v\u00e1laszban k\u00fcld\u00f6tt mez\u0151ket hat\u00e1rozza meg.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}]},"\/wp\/v2\/view-config":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"description":"Entity kind.","type":"string","required":true},"name":{"description":"Entity name.","type":"string","required":true},"wpml_language":{"type":"string","description":"WPML's language code","enum":["bg","zh-hans","zh-hant","cs","nl","en","fr","de","el","hu","it","ja","pl","pt-br","ru","sl","es","sv","vi"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/wp\/v2\/view-config"}]}}},"site_logo":0,"site_icon":87,"site_icon_url":"","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_icon","href":"https:\/\/www.sweethome3d.com\/hu\/wp-json\/"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
