Skip to content
Tiny homes have become a popular solution for those that feel inspired by the concepts of minimalistic living, mobility, or simply downsizing. These kinds of homes use space and design efficiency, and at the end of the day they feel as comfortable as larger homes.
If you want to explore the idea of designing your tiny home but you’re unsure as where to start, Sweet Home 3D is the perfect tool to help bring your vision to life.
Here’s a tiny home design tutorial using Sweet Home 3D!
Step 1: Start with the Right Dimensions
The first step in designing your tiny home obviously is defining the layout’s size. Tiny homes are typically under 400 square feet, and Sweet Home 3D makes it easy to create the perfect footprint.
Open Sweet Home 3D and create a new project.
Start by drawing your walls: Keep in mind that you want to keep your space limited, but other than that you can customize everything about them from thickness to color.
Adjust the scale and assign rooms to make sure everything fits the way you envision. For a more realistic approach, think about the placement of key zones such as the living area, sleeping quarters, and kitchen.
Step 2: Create an Efficient Floor Plan
In a tiny home, every single inch matters, so it’s essential to design a functional floor plan. Here’s how to efficiently furniture your tiny spaces:
Living Area: Typically, the living space is multifunctional and should address different purposes. Consider including a foldable couch or a convertible sofa bed that can serve as both seating and a sleeping space.
Kitchen: The kitchen in a tiny home should be compact but efficient. Use space-saving appliances like an under-counter fridge, microwave, and a small two-burner stove. Think about integrating storage solutions like overhead cabinets or a pull-out pantry.
Bathroom: Tiny home bathrooms need to be designed smartly. A corner shower, a small sink, and a composting or compact toilet are common choices in tiny homes. Consider using pocket doors for the bathroom to save space.
Sleeping Area: Most tiny homes use loft spaces for sleeping areas, but if you don’t want a loft, consider using a fold-up bed, wall-mounted shelves, and maximizing storage below.
Step 3: Utilize Vertical Space
Tiny homes rely heavily on vertical space to provide storage, functionality, and a sense of openness. Sweet Home 3D allows you to play with different height levels for walls and ceilings, so you can experiment with lofts and vertical elements.
Consider adding a loft for the bed or storage. Sweet Home 3D’s “levels” feature makes it easy to create multi-level spaces. You can design a sleeping loft or storage loft and make sure there’s enough clearance for headroom.
Wall-mounted shelves or cabinets can save floor space and help keep your tiny home organized.
Use multi-functional furniture. A table that can fold into the wall or be converted into a workbench will provide both workspace and dining options.
Step 4: Maximize Natural Light
Natural light make a small space feel larger and more inviting. Sweet Home 3D allows you to adjust window sizes and placements so you can plan where light will come into the space.
Add large windows to the living area and kitchen to bring in natural light, especially if your tiny home will be mobile or surrounded by beautiful scenery.
Consider installing skylights to let in even more light, especially if you’re building a loft space.
If you’re in a more private or shaded location, think about open shelving and mirrors to reflect light and make the space feel larger.
Step 5: Focus on Multi-Use and Smart Furniture
The key to a successful tiny home design is furniture that serves multiple purposes. In Sweet Home 3D, you can easily add pieces that fit your vision, whether it’s a fold-out couch, storage benches, or hidden cabinets.
Convertible furniture is your friend in a tiny home. Look for options like a sofa that turns into a bed or a dining table that doubles as a desk.
Add built-in storage wherever possible, such as under stairs, couches, or along the walls. Sweet Home 3D lets you design custom cabinetry that can maximize your space even further.
Don’t forget about the outdoor space! Tiny homes often have decks, patios, or fold-out sections that extend the living space outside. Sweet Home 3D allows you to create exterior layouts as well.
Also, did you know that if you’re creative enough you can build new furniture designs from the ones already present in the catalog? Just combine different things together, resize them and group them. Check our video tutorials for more info on how to create new furniture and how to combine different models together, we tried to make it easy for you!
Step 6: Create the Exterior Design
Now that you’ve designed the interior, it’s time to turn your attention to the exterior.
Roof Style: Consider using a gable roof or a shed roof for simplicity and good drainage. Sweet Home 3D provides various roof shapes that you can easily integrate into your design.
Materials: You can choose exterior materials like wood, metal, or composite materials. The right material will impact the look, feel, and durability of your tiny home.
Outdoor Living Space: If you’re using your tiny home as a retreat, add a small porch, deck, or outdoor dining area. This adds more usable space without overcrowding the interior.
Step 7: Experiment and Fine-Tune Your Design
Once you’ve laid out your tiny home, make Sweet Home 3D your tiny home layout software and leverage its ability to experiment with different configurations and design features. You can test how furniture fits, make changes to the layout, and tweak the design until it feels just right.
Don’t forget to save your design at different stages so you can compare options or go back if needed. The ability to visualize changes in real time will help you ensure that your tiny home meets all your practical needs while maintaining a beautiful and inviting space.
And you’re done!
So what are you waiting for? Go start designing, and if you haven’t downloaded Sweet Home 3D yet, get it here
