Previous Thread This topic has been viewed 4236 times and has 2 replies Next Thread
nixcamic
A-Frame House
Is it possible to make the sloped walls/roof of an a-frame house in Sweet Home?
[Jan 13, 2020, 4:47:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: A-Frame House
You could build the roof with large and thin boxes that you will rotate around their horizontal axis.
[Jan 14, 2020, 11:02:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
coldcomfort
Re: A-Frame House
Or use the wall function to make a roof section and then export that as an object. Reorienting it inside the import object tool. An extra level can help with the precise fiddling and sizing of the wall parts, since the underlying plans are visible. That way you can also locate windows from the start, as skylights. The ridge will look neat and it handles exterior and interior textures. This works just fine for a simple A frame, but for more complicated roof structures the best option is with simple box and triangle shapes.
[Jan 21, 2020, 1:28:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
