Romania
Re: Rooms Information plug-in
New version 1.2.2 Bug fix (I hope) in use correct units on some languages, thanks to Aleksey Voitovich.
Also on SurceForge
---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law (Greer's Third Law) When all else fails, read the instructions.Murphy's Law
NOTE VERY IMPORTANT: If You don't use yet Plugin Manager from Daniel118, don't forget to remove manually the previous versions. This one will don't replace it automatically!
The imported csv file could be look like this sample AFTER You format it in Office.
Also on SourceForge
Fix a bug reported by Olivier when two or more levels have the same name but not all have rooms.
Probably I've made others bugs. Test it! (with care)
Also on SourceForge
Romania
While I'm not a native English (also not a programmer) what I have to understand? It worked or don't? Anyway 1. Thanks you think it works (if this is the case) 2. Knowing my self I suggest you to verify it twice before fully trust the plugin results. 3. Try to find what don't work, let me know what and (with your help) I will tray to fix it. Finally Manny thanks for your appreciations.
