Previous Thread This topic has been viewed 1130 times and has 2 replies Next Thread
deco0224
Ireland
Issue with groupings and levels
Hi there,
I have modeled my 3 story house seperated on 3 levels.
Each level looks perfect with its own furniture etc.
But then when group the furniture I have problems. I am grouping all the furniture on the same level together, eg all level 0 furniture is in a group called 'Level 0 Furniture and the same with the other floors. I have also grouped all the level 0 electrical together into groups etc.
The problem I am facing is some of the furniture from level 0 appears on level 1. When I ungroup the furniture, it displays fine again.
I have selected each piece of furniture and checked to make sure it is on the correct level. I have set up the right levels with the correct elevations and none of the furniture on level 0 is taller than the ceiling height. I have set each room up using the Add room feature and each room has a ceiling and a floor.
I would greatly appreciate any help on this - thank you.
[Dec 15, 2019, 7:40:09 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Issue with groupings and levels
Check you have not included stairs in your groups, they are on 2 levels. Light fittings can also be an issue if the elevation + depth takes them above the ceiling.
[Dec 15, 2019, 6:20:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Gildaniel
Russia
Try before grouping elevate your level extrimely high (10m) then, group objects and lift back
High furniture can be seen and selectable through levels
[Dec 17, 2019, 6:09:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
