enkonyito
Re: How to generate a .h file with javah?
Thank you Emmanuel!
Based also on this documentation, I was able to generate the YafarayRenderer.h file in the plugin package.
/* DO NOT EDIT THIS FILE - it is machine generated */ #include <jni.h> /* Header for class betaTestPlugin_YafarayRenderer */
#ifndef _Included_betaTestPlugin_YafarayRenderer #define _Included_betaTestPlugin_YafarayRenderer #ifdef __cplusplus extern "C" { #endif /* * Class: betaTestPlugin_YafarayRenderer * Method: createEnvironment * Signature: (Ljava/lang/String;Ljava/lang/String;)J */ JNIEXPORT jlong JNICALL Java_betaTestPlugin_YafarayRenderer_createEnvironment (JNIEnv *, jobject, jstring, jstring);
Since I don't know JNI, generating DLLs is less obvious and I get an error in Eclipse when rendering.
It's easier with the modified YafaRay rendering plugin because I kept your packages and added the necessary files and folders.
EnkoNyito
[Nov 16, 2019, 1:51:06 AM]
[Link]
