Italy
Render gives only black images
Hi all, i'm using the fere version to see how to renew my home. I'm facing a strange problem:
On my PC (win 10 pro 64bit) using latest version (6.2 if i'm remembering well) every photo rendering gives black images (aerial or from view point), high or less quality.
I tried on another PC (win 10 pro 32bit, a little bit older, with less RAM and i had to use version 5.2 because newer versions can't work with G41 chipset): opening the same project renders well. I can't use this PC everytime i need because it's not at my home.
Italy
Re: Render gives only black images
Sorry, i was away and i'm reading now your answer. I've solved creating the project with the "older PC" and then opening at home. So now i can work at home "on my home". thanks anyway.
Argentina
Hi, since I installed the most recent version (6.2), I can't render again ... do you know why this is happening to me? Regards. Leandro from Argentina.
