Germany
Where are settings (textures, 3D models, etc.) saved on the Mac?
Hello,
I want to perform a clean install when I upgrade to Catalina in the fall. Where can I save the app settings and re-import them on the new installation? For example, the imported furniture, etc.
Re: Where are settings (textures, 3D models, etc.) saved on the Mac?
If you use the free version, imported stuff and preferences can be found in the folder Library/Application Support/eTeks/Sweet Home 3D of your home folder (you may use Go > Go To Folder...menu item in the Finder to go to that folder, adding the prefix ~/). If you use the Mac App Store version, imported stuff and preferences are stored in the folder Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data/Library/Application Support/eTeks/Sweet Home 3D.
See also this post.
