enkonyito
Re: YafaRay rendering plug-in
Some suggestions for the next version (1.0 Beta 4): - use a YafarayRenderer.properties file to modify rendering parameters such as for SunflowRender.properties - include an example xml scene using arealights or visible spherelights because their implementation is problematic - make tile borders visible to see the number of rendering threads Enko Feedback on the light panels.
* When I choose,
params.put("type", "arealight"); // Uses the YafaRay coordinate system (X-right, Y-back, Z-up) // vertex0 = (0% lightWidth, 0% lightDepth, 0% lightHeight) // vertex1 = (100% lightWidth, 0% lightDepth, 0% lightHeight) // vertex2 = (100% lightWidth, 0% lightDepth, 100% lightHeight) // vertex3 = (0% lightWidth, 0% lightDepth, 100% lightHeight) Point3f vertex0Location = new Point3f(0.0f - 0.5f, 0.0f - 0.5f, 0.5f - 0.0f); Point3f vertex1Location = new Point3f(1.0f - 0.5f, 0.0f - 0.5f, 0.5f - 0.0f); Point3f vertex3Location = new Point3f(0.0f - 0.5f, 0.0f - 0.5f, 0.5f - 1.0f); lightTransform.transform(vertex0Location); lightTransform.transform(vertex1Location); lightTransform.transform(vertex3Location); Point3f corner = new Point3f(vertex0Location.getX(), -vertex0Location.getZ(), vertex0Location.getY()); Point3f point1 = new Point3f(vertex1Location.getX(), -vertex1Location.getZ(), vertex1Location.getY()); Point3f point2 = new Point3f(vertex3Location.getX(), -vertex3Location.getZ(), vertex3Location.getY()); params.put("corner", corner); params.put("point1", point1); params.put("point2", point2); params.put("color", new float [] { ((lightColor >> 16) & 0xFF) * ((this.homeLightColor >> 16) & 0xFF), ((lightColor >> 8) & 0xFF) * ((this.homeLightColor >> 8) & 0xFF), (lightColor & 0xFF) * (this.homeLightColor & 0xFF), 1}); params.put("power", power * 100); params.put("samples", 4); createLight(UUID.randomUUID().toString(), params); no light is emitted.
* When I choose,
params.put("type", "meshlight"); params.put("double_sided", false); params.put("light_enabled", true); params.put("color", new float [] { ((lightColor >> 16) & 0xFF) * ((this.homeLightColor >> 16) & 0xFF), ((lightColor >> 8) & 0xFF) * ((this.homeLightColor >> 8) & 0xFF), (lightColor & 0xFF) * (this.homeLightColor & 0xFF), 1}); params.put("power", power * 100); params.put("samples", 4); createLight(UUID.randomUUID().toString(), params); Sweet Home 3D automatically closes every time without an error message in Eclipse.
EnkoNyito
[Jan 1, 2020, 8:51:21 PM]
[Link]
