Posts: 173   Pages: 18   [ Previous Page | 9 10 11 12 13 14 15 16 17 18 | Next Page ]
Previous Thread This topic has been viewed 418471 times and has 172 replies Next Thread
son87a
Re: YafaRay rendering plug-in
@Puybaret I want to build a cloud render for SweetHome3DJS. Is it possible ? Do you have any suggest for that ?
[Oct 31, 2021, 10:43:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
That would be nice and surely possible smile
[Oct 31, 2021, 1:08:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Poffu
Finland
Do you have ideas on how to get gray wall renderings to represent the true color it would have? I'm trying to see whether I'd like to have the lighter gray on my walls or the darker one, but the darker shades of gray get rendered way too light (if you ask me biggrin ).
Here are the walls pre-rendered:
Color L500 (RGB #A8AFB5):
and color S500 (RGB #757B81):
and their corresponding renderings:
L500:
S500:
[Dec 29, 2021, 12:10:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Try using textures of the desired colours instead of the colours themselves.
[Dec 29, 2021, 1:55:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Agree with Hansmex.
I used a site like this https://www.magasindepeinture.ch/en/ncs-color-chart-online.html to find the right color combo for my studio.
I sampled the color images, named them with the NCS code, applied them to my walls and made renderings. Having found the right ones, I gave the NCS code to the painters.
Perfect result.
[Dec 29, 2021, 2:38:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
narensankar0529
Plugin seems to crash on both macOS Intel and macOS M1 with 6.6. Home renders correctly with SunFlow but no matter what dimensions I use it starts rendering but then crashes. Anyone else seeing this issue?
Path: /Applications/Sweet Home 3D.app/Contents/MacOS/SweetHome3D
Identifier: com.eteks.sweethome3d.SweetHome3D
Version: 6.6 (6600)
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2022-01-19 23:24:15.9346 +0800
OS Version: macOS 12.0.1 (21A559)
Report Version: 12
Bridge OS Version: 6.0 (19P549)
Anonymous UUID: 061D21FF-1D40-DCCA-7BA1-0F5EC4683531
Time Awake Since Boot: 2500000 seconds
System Integrity Protection: enabled
Crashed Thread: 152
Exception Type: EXC_BAD_ACCESS (SIGABRT)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000000000000c
Exception Codes: 0x0000000000000001, 0x000000000000000c
Exception Note: EXC_CORPSE_NOTIFY
VM Region Info: 0xc is not in any region. Bytes before following region: 4505481204
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 10c8c3000-10c8d6000 [ 76K] r-x/rwx SM=COW ...S/SweetHome3D
Application Specific Information:
abort() called
[Jan 19, 2022, 3:25:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mickut
Finland
On Win10 my project has started to consistently crash Yafaray as well on memory access violation. The fault offset is constant.
Faulting application name: javaw.exe, version: 11.45.0.27, time stamp: 0x5fece988
Faulting module name: libyafaray_v3_core.dll, version: 0.0.0.0, time stamp: 0x60467f34
Exception code: 0xc0000005
Fault offset: 0x0000000000030261
Faulting process ID: 0x435c
Faulting application start time: 0x01d8122ab1faf429
Faulting application path: C:\Program Files\Sweet Home 3D\runtime\bin\javaw.exe
Faulting module path: C:\Users\xXxXxX\AppData\Local\Temp\dll567123420114771161tmp\libyafaray_v3_core.dll
Report ID: 9535d0e7-05fb-4e48-800f-197f25be59f9
Faulting package full name:
Faulting package-relative application ID:
Happens with both installer version and downloaded JAR on JDK-11 (not suprising, as it's the yafaray dll).
[Jan 25, 2022, 9:41:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
Does this happen even with a very simple home (i.e. just 4 walls and floor), or is it specific to this file?
In the second case can you upload the file somewhere and share the link?
[Jan 26, 2022, 9:19:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mickut
Finland
A minimal project renders fine, and even some close-ups in the failing model. I'll try to isolate the feature, then either create a sample or share the actual model.
[Jan 27, 2022, 5:12:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mickut
Finland
Found the issue. A seemingly innocent looking model of a Denon LP player downloaded as Collada file:
https://3dwarehouse.sketchup.com/model/146e08...6a3/Denon-SL-7D-Turntable
Works almost OK with SunFlow, crashes YafaRay instantly. When I change "edge_color*" invisible in materials, it works.
The resulting non-crashing render does have some texture or surface clipping issues (and I've noticed it on many other models from 3dWareHouse as well).
[Jan 27, 2022, 8:10:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
