Total posts in this thread: 166
Posts: 166   Pages: 17   [ Previous Page | 8 9 10 11 12 13 14 15 16 17 | Next Page ]
Previous Thread This topic has been viewed 250549 times and has 165 replies Next Thread
Re: YafaRay rendering plug-in
The version 1.4.3 fixes an issue reported here by gregoryx about light rays that could appear at ceiling borders.
We experienced a similar issue in the scene used for Sweet Home 3D 6.3 where without some tricks, the scene let appear some unwanted clear lines at the ceiling like in the following image.
(larger image)
Thanks to the help of David Bluecame, the developer of YafaRay, I could adjust the renderer parameters to avoid this issue.
(larger image)
You'll see that this adjustment gives an image with a little more contrast (see the cactus at bottom right for example).
Note that this adjustment is still not perfect, and you might still get some lighted pixels.
For example, the issue which appeared like in the following image with the version 1.4.2 of the plug-in:
will now appear like this at the 3rd quality level:
and like this at the highest quality level:
I hope you'll still agree it's much better and workable now.
[Jan 17, 2021, 1:17:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
As the YafaRay site is inaccessible, have you been given any information about the adv_auto_shadow_bias_enabled parameter?
When its value is false, it causes black outlines on the walls.
standby before shutdown
[Jan 24, 2021, 4:36:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
To fix the bug described in my previous message, David Bluecame recommended to try setting adv_auto_min_raydist_enabled or adv_auto_shadow_bias_enabled parameters to true and play with the values of adv_min_raydist_value and adv_shadow_bias_value.
Changing adv_min_raydist_value didn't have some effect but adv_shadow_bias_value did, the reason why I published the version 1.4.3 (there was only little feedback about it and I'm not sure it's the perfect solution).
Try to set adv_shadow_bias_value with a float or double value, not a boolean value. The fastest way to try some YafaRay parameters and get their type is to look at a XML YafaRay example like this one: bval is for boolean values, fval for float or double values, ival for integer values, sval for strings.
[Edit 1 times, last edit by Puybaret at Jan 25, 2021, 9:38:39 AM]
[Jan 25, 2021, 9:18:39 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
By following this method I got the same results as you and I found that the shadow_bias parameter takes precedence over min_raydist.
There may be another parameter that comes into account because for the same values, the rendering is different when the auto mode is enabled for shadow_bias.
[Jan 26, 2021, 6:04:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GhyslainB
I've been using Yafaray since last summer, and overall I've had a good experience. However, I have three lingering issues, and I wondered if I'm just clueless on using the software properly (quite possible), or if they are the result of bugs.
Note: I typically use Yafaray at Level 4, with Photon, Lanczos and Shinydiffusemat, but I have seen the same issues with every setting I've tried.
1) First, I use some mantle clock furniture objects, and somehow whenever I render them with Yafaray, the clock face is missing, like this:
For reference, with SunFlow, they render properly, like this:
2) Secondly, the lamps (from SH3D default furniture set) are lighting incorrectly; the light "shines through," even when the lighting is set at a low percentage intensity. Like in the following example (lamp set at 7%):
3) Finaly, when using the Multiple photo rendering (v.2.1) plug-in, there seems to be some kind of memory management issue. The memory used by SH3D keeps getting larger with each render, usually leading to a crash when it goes above 200 GB or so, which is about 4-5 renders on a .sh3d file of about 1.75 GB. I can live with restarting the app every 4 renders, it's not a big deal, but I thought maybe it could be useful to report the problem here.
Thanks in advance for the help!
[Jan 31, 2021, 7:50:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@GhyslainB
Could you provide the link where to download this clock?
This usually happens during indirect rendering (path tracing, photon mapping or sppm) with the YafaRay engine.
It seems that the light source diffuses through the object making the faces of the mesh visible.
If your memory problem when rendering is similar to this one, you can create a bugs or feature requests ticket.
[Feb 2, 2021, 2:14:37 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GhyslainB
@enkonyito
Thank you for answering my post. For the clock, I've uploaded the model here: https://www.mediafire.com/file/t58xto0buct46e1/Mantle_Clock.zip/file
I'll look into writing a ticket for the memory bug.
Many thanks again!
[Feb 4, 2021, 11:38:41 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I downloaded and installed SH3D 6.5 under W10.
Using the Simple Photo Rendering v2.0a all results with Sunflow are VERY dark.
Should I no longer use this plugin?
[Feb 4, 2021, 2:16:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Emmanuel,
GhyslainB's Mantle Clock is made up of 51 materials (2 colors and 49 textures).
Even by making the ForegroundColor and FrontColorNoCulling materials invisible, the problem persists.
Here is a comparative rendering without changing the source code.
Enko
[Feb 5, 2021, 6:11:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Could you provide more precision here?
[Feb 5, 2021, 6:19:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2022 eTeks - All rights reserved
