Member(s) browsing this thread: Danmari
Posts: 173   Pages: 18   [ Previous Page | 9 10 11 12 13 14 15 16 17 18 ]
Previous Thread This topic has been viewed 418399 times and has 172 replies Next Thread
SeppoV12
Finland
Re: YafaRay rendering plug-in
The resulting non-crashing render does have some texture or surface clipping issues (and I've noticed it on many other models from 3dWareHouse as well).
Probably you have already noticed that making 'material' (just above material 0 in Model materials list of Denon), material 12 and material 13 invisible will remove most of that surface clipping.
Reason for clipping seems to be that model has different color/material on inner surface and outer (visible) surface.
At some angle the phenomenon appears as the inner color leaks through.
[Feb 18, 2022, 5:33:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The version 1.4.5 fixes crashes that may happen with DAE models specifying only transparent color for some of its effect / material (generally edges like reported by mickut).
[Feb 25, 2022, 3:18:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
For your information, YafaRay renderer is now available in Sweet Home 3D 7.0 making this plug-in useful only if you use an older of Sweet Home 3D.
[Jul 18, 2022, 9:21:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
