How to purge a library?
How to clean out furniture in a category/library? I thought that importing a furniture library with same name would replace and overwrite the current content? Not merge!
Re: How to purge a library?
I found a solution!
In the menu Help -> About..., chose Libraries.... Here you can move or delete imported libraries, so only valid libraries are present here. Reopen SH3D, and only furnitures in the correct library is shown.
(I had several libraries with similar names here, they were active until removed from this folder/directory.)
