Spain
Re: Photo-rendering failed
After some PM with Hans, and checking Installing/Uninstalling some times Java and Sweethome3d, we determine, the problem is my computer.
I made a fresh install in a laptop and works fine. (Even modifying .ini file to adjust max memory), but my computer (I7 with W10 /16GB RAM/4GB graphic card) doesn't change, offering me maximum 0.4GB.
so maybe some software installed in my computer makes SH3H having incompatibility.
I will continue trying options in my computer, and until i find a solution, i will edit with my computer, and i will render with the laptop (Less powerful)
Spain
Hello all. SOLVED.
Finally using this video (https://www.youtube.com/watch?v=R3Hj83J0ekk), and Changing the value in the first step (I modify it with -XMX8g not delete) and now i start SH3D and i see:
Java version 1.8.0_202 - 64 bit - 0.1 / 7.1 GB
So finally it's working.
thanks a lot to all of us hwo helped me here or with Private Message.
so the problem was, my system was blocking any change of memory in JAVA restricting to 512MB.
