DE
Problem with OpenGL
Hello everyone,
after some time I have installed Sweet Home 3D again. Now I get when I start the program the error that I need to update the driver of the graficcard. My problem is now, that I have updated the driver and I get the error also.
This is my system: Windows 10 Education 64-bit CPU: Intel i7-4790K RAM: 16GB GPU: Nvidia GTX-970 Driver Verison: 417.35 JRE and JDK Version: 1.8.0_191
I have also tryed older versions of Sweet Home 3D, there I got the same error. Moreover I have tryed the executable jar version. If I run this from the commandline I get the following error:
javax.media.j3d.IllegalRenderingStateException: Java 3D ERROR : OpenGL 1.2 or better is required (GL_VERSION=1.1) at javax.media.j3d.JoglPipeline.setupCanvasProperties(JoglPipeline.java:8090) at javax.media.j3d.JoglPipeline.createNewContext(JoglPipeline.java:6439) at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:4612) at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:2386) at javax.media.j3d.Renderer.doWork(Renderer.java:881) at javax.media.j3d.J3dThread.run(J3dThread.java:271) Error in Java 3D : 3 Renderer: Error creating Canvas3D graphics context
I have also reinstalled java (jre and jdk), the driver of the graficcard and all nvidia software, which I have found on my system. I don't know which more software I need to reinstall.
I have no problems with minecraft which is also running with java and OpenGL.
Does anyone have an idea, who I can fix the probleme without an windows reinstallation?
Re: Problem with OpenGL
Did you try both 32 bit and 64 bit versions, selecting either Architecture options in the installation folder screen of Sweet Home 3D installer?
Svizzera
I have the same problem too
This is my system: Windows 10 Home 64-bit CPU: Intel i7-6700K RAM: 32GB GPU: Nvidia GeForce 1080 Driver Version: 417.17 JRE and JDK Version: java version "1.8.0_201" Java(TM) SE Runtime Environment (build 1.8.0_201-b09) Java HotSpot(TM) 64-Bit Server VM (build 25.201-b09, mixed mode)
try with 32/64 bit: in task manager Java Platform SE Binary appears and disappears in a moment tryed the executable jar version: the same problem as SporSeba97 Java 3D ERROR : OpenGL 1.2 or better is required (GL_VERSION=1.1) some idea?
