Re: arch shape roofings
anybody can help for creating a arch shape roofing
Like ?
A little real picture would be welcomed… .
SH3D 6.5 and nothing else - W10 64b Asus TUF Z390 , Intel Core i9-9900KF (4.0 GHz) , Chipset Z390 Exp, RAM 32 Go DDR4 3 Ghz, SSD M.2 512 Go + HDD 3 To, MSI GeForce RTX 2080 8Go
I suggest you can build your arch with walls in a new file, then import the arch as an objet with "Export to OBJ format" menu item. Take care to import only the walls.
You can’t bend a floor. And without a picture, it will be difficult to help you more, as alrealdy suggested.
Canada
There's no way to turn a wall from vertical to horizontal in SH3d .... the same as there's no way to bend a wall nor a roof to build a arch surface. If you know a better way to achieve such task, let us know since I'm not the only one asking that question.
Billmart, walls are vertical and can’t be leaned in Sweet Home 3D. By the way, please stop polluting other threads with similar questions. That won’t make appear this feature.
