Total posts in this thread: 8
Previous Thread This topic has been viewed 3218 times and has 7 replies Next Thread
delaing
Need ability to input offset value in Foot/Inch/Fraction data fields
I just found out with the help of @okh that it is not possible to input a value, say +5' (five feet), as an offset value in the X-Y coordinate fields of the Modify Wall dialog if application preference is set to Foot/Inch/Fraction.
You can see the discussion here:
Draw (offset) Wall from Existing Wall?
Why would this be available for Metric and Inch/Decimal but non-functional in Foot/Inch/Fraction?
Thanks in advance,
Delain
[Nov 24, 2018, 6:40:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Need ability to input offset value in Foot/Inch/Fraction data fields
Because the metric system doesn’t need ' and " characters. If you use Inch/Decimals unit, you’ll be able to enter mathematical expressions too.
[Nov 24, 2018, 11:59:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If so, I would use (7*12)+11 to insert 7 feet 11 inches (with inch/decimala in preferences). However, that does not give me 95 as expected. Am I missing something...? ok
[Nov 25, 2018, 2:06:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hi OK
If you input this formula (7*12)+11 into the "modify wall" dialogue box, then the wall moves, for some reason, 18'8 3/8", 224.37". Whereas if you enter the formula into the "move selected item" dialogue box it does then move 95"
[Nov 25, 2018, 7:27:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Have to ask, would it not be simpler, and it seems to work, using x as its original position inputting x+95
[Nov 25, 2018, 7:40:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
224.36 = (7 x 12 x 2.54) + 11
and 2.54 cm = 1 inch
There must be a conversion bug in the parsing algorithm and this happens as soon as the unit is not the centimeter! sad
[Nov 25, 2018, 8:07:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
..would it not be simpler, and it seems to work, using x as its original position inputting x+95...
Absolutely. My experiment was just to test the math-formula and show how to enter feet/inches with a cheat. Come to think of it, the easiest would be if everyone used metric smile
..conversion bug in the parsing algorithm and this happens as soon as the unit is not the centimeter...
Oh well, I guess the math function may have to wait one release in the non-metric world. ok
[Nov 25, 2018, 8:53:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The bug was fixed in version 6.1. Thanks for your patience.
[Jan 24, 2019, 3:21:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
