Posts: 44   Pages: 5   [ 1 2 3 4 5 | Next Page ]
Previous Thread This topic has been viewed 12746 times and has 43 replies Next Thread
stef.salmon
Re: Background Pixelation
Why am I getting areas of pixelation on my floor layout background?
https://www.dropbox.com/s/a9d8hsiib5lm578/KWS_1stFloor5.png?dl=0
Thanks.
[Oct 23, 2018, 10:26:16 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
stef.salmon
I'm guessing the pixelation is due to some sort of shadow being cast?
I've tried changing coordinates on the compass but nothing seems to get rid of the shadows.
Any help would be greatly appreciated.
Thanks.
[Oct 25, 2018, 9:20:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
stef.salmon
If the shadows have to be there then so be it, but why aren't they a solid colour instead of pixelated? This is so frustrating!
I can't really use these rendered images on a customers site when they look like this.
https://www.dropbox.com/s/uqlkqrkbtx7c7r9/KWS_1stFloor%20-%20Copy.png?dl=0
It would be so much easier if there was a way of just selecting no shadows instead of messing around with coordinates and time of day.
[Oct 26, 2018, 8:18:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
confused Re: Background Pixelation
Generally, it happens with renderings in quality 3.
Did you try in quality 4 ?
biggrin
SH3D 7.0 and nothing else - W11 64b
Core i9-9900KF (4.0 GHz), RAM 32 Go DDR4 3 Ghz, MSI GeForce RTX 2080 8Go
[Oct 26, 2018, 8:57:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
alaX
Poland
Looks like the same issue (with solution):
http://www.sweethome3d.com/support/forum/viewthread_thread,8958
[Oct 26, 2018, 11:24:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
stef.salmon
I tried setting the elevation to 1cm and also 2000cm but it makes no difference. I think it's the shadows full stop that are causing the problem.
See link.
https://www.dropbox.com/s/08xlggkpvh0vuza/KWS_1stFloor%20-%20Copy3.png?dl=0
Is it not easier, to just have no shadows?
Thanks.
[Oct 26, 2018, 12:52:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
What is the light source creating your shadows?
Have you tried IBL-lighting – applying a white texture to the sky and render with enhance external brightness checked and the time of day set to midnight?
cec
[Oct 26, 2018, 2:38:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
stef.salmon
What is IBL lighting and where do you get it?
[Oct 26, 2018, 2:48:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
stef.salmon
I think it's more of a problem with the rendering tool. There's no reason why the pixelation should be there...it's not even part of the shadow.
[Oct 26, 2018, 5:09:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Stef.salmon, you should read this thread by EnkoNyito and many others by Ceciliabr who nicely gives to the forum many tips about lighting.
[Oct 26, 2018, 6:38:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2022 eTeks - All rights reserved
