Re: Water pipes and electric wires
Water pipes and electric wires ...
Good idea !
In France, all electric network is in the ceiling. It's easier to access and it avoids flooding … .
Re: Woods and grass
If you don’t have a random distribution system, it takes a lot of time to do this kind of map. If you can randomly distribute the specified multiple objects, including Random location within range Random size within range Random direction or both directions Range random machine height Well, doing this is very fast.
Re: Woods and grass
My thoughts on Pre-segmented dynamic object system's custom user interface
Allow advanced user defined material library
It also provides ordinary users to define him in software.
This will be a great pleasure for software. I hope users can create some interesting things when using software. So there is no need for too many restrictions.
The whole process is reflected in a Script form. The software executes some items on the table down.
If set correctly, those cases in my front post will be reached.
After execution, a new object is generated in the object bar. Drag and modify this new object to automatically create complex objects.
Script form
Type is the most important column.Determines the function of this script.Other columns are his parameters.
left Middle (simple) Pattern 1 Pattern 2 Pattern 3 Right corner Inner corner Outer corner Random placement (square) Random layout (circle) Several choices 1 (Book) Intermittent repetition blank
Re: Woods and grass
Thank you very much, YGYL, for these models that I may use in a “Haussmanian” flat. Could you confirm that the 3D models listed on this page are available under Free Art Licence or CC-BY Licence? Thanks in advance
