Automatic lights
I do not know if this request has already been made.
Is it possible to automatically turn on the lights according to the time of day ?
Example in the préférences : the external street lights (or interiors) light at x% (set in the object) or go off at 0% in daylight.
Bright idea, right ?
[Edit 1 times,
last edit by Puybaret at Aug 15, 2018, 6:42:09 PM]
Re: Automatic lights
Simple answer: Yes. I created a light panel whose apparent power varies according to the position of the sun. It turns off automatically when it is dark and comes back gradually when it is day. I think the opposite, off the day and on at night, is feasible.
Complicated answer: But .. For this to work, you must add a keyword to the name of the light object so that it is taken into account by the PhotoRenderer file so it will not work with the default lights. As this file has been modified for version 6.0 of Sweet Home 3D, I must first make the photo plug-in compatible with the improvements made by Emmanuel Puybaret. After, I could include a new automatic light sphere (unviewable) responding to the request.
EnkoNyito
I have tested and it works (lighting off by day and on when the sun is below the horizon). Using the keyword in the property file, it will be possible to create or modify a light object to turn on and off automatically. It only remains to wait for the next version of Sweet Home 3D.
EnkoNyito
With the new version of the photo/video plug-in , there are 2 ways to have an automatic light. - Use the automatic light sphere available in the libraries provided - Use the automatic and SphereLight keywords in the description property of the light you create
Just enter the light power and the light source manager will do the rest when you change the time.
EnkoNyito
... to have an automatic light. - Use the automatic light sphere available in the libraries provided - Use the automatic and SphereLight keywords in the description property of the light you create Just enter the light power and the light source manager will do the rest when you change the time.
Hi enko,
PVR 1.6 with automatic lights work fine on my PC for pictures. .
