Total posts in this thread: 36
Posts: 36   Pages: 4   [ 1 2 3 4 | Next Page ]
Previous Thread This topic has been viewed 45898 times and has 35 replies Next Thread
AdeleAlli
Italy
Mini Cottage
Hi, I am working on a small cottage...
Here is the back:
Here is the front:
I will post the renderings of the interiors when I have them.
[Aug 9, 2018, 12:06:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
AdeleAlli
Italy
Re: Mini Cottage
Here is the fireplace:
Sleep area:
Garage:
Mini bathroom:
Staircase to go to the second floor:
View from the dining area:
First floor plan:
Second floor plan:
[Aug 9, 2018, 10:00:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
AdeleAlli
Italy
Re: Mini Cottage
I decided to change the Arbor with the BBQ with a Pergola and a bbq separated from it.
Here a view of the back of the cottage with the new pergola:
And here a view from the inside of the pergola:
I will like some suggestions if someone has some, in order to improve the cottage and to make it more realistic. :)
Thanks
[Aug 11, 2018, 7:53:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
Re: Mini Cottage
Some suggestions:
- move the staircase 50-100 cms to the left; you get more space for dining & bedroom
- replace stairs with open staircase, maybe a hanging one like these
- move fireplace to the end of the wall and replace with something more open, maybe like these
[Aug 11, 2018, 10:51:29 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Mini Cottage
I really like your design, so there is very little to say. What I would have changed, probably for a different climate, is to move the fireplace downstairs. It looks a bit heavy which could complicate the floor construction. But also, if you use it, all the heat will stay under the ceiling upstairs - and it could get very worm in a small room. If you move it downstairs, heat will also rise to upper floor. ok
[Aug 11, 2018, 12:45:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
AdeleAlli
Italy
Re: Mini Cottage
Some suggestions:
Good suggestion, thank you.
This is the result at the first floor (or ground floor):
Night lights
Day lights
The top view of the plan, now the space for dining room is more
Thank you for this suggestion, I will try to apply it and will post the results later.
[Aug 11, 2018, 2:44:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
AdeleAlli
Italy
Re: Mini Cottage
Thank you okh. I think that this suggestion is harder to apply because I should think a way to change the plan of the first floor without messing up completely its design.
I will try to find a good way to apply it but if you have some suggestions I will certainly accept them :).
[Aug 11, 2018, 2:47:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
AdeleAlli
Italy
Re: Mini Cottage
This is the bedroom upstairs, I modified it.
And this is the top view of the second floor:
I did not like very much the handrails of the stair because they are not following the handrails that I put on the second floor, but I think there is no way to eliminate this imperfection, or is it? Maybe someone already encountered a similar problem. Maybe I should look for a 3d model of stairs that has shorter handrails or I should use one without handrails (but I think it is not the best solution).
[Aug 11, 2018, 5:01:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Mini Cottage
What a sweet little place! Congratulazioni AdeleAlli! Soon in real?
[Aug 11, 2018, 5:45:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Mini Cottage
..this suggestion is harder to apply because I should think a way to change the plan of the first floor without messing up completely its design
Quite, I see your point. My suggestion was primarily made from a location where -20°C is quite common in the winter. But you can also look at a smaller fireplace. We had a modern one installed a couple years ago, < 70 cm wide and builds only 40 cm from the wall (chimney) - and it still delivers 5kW - more than enough for your nice little house. ok
[Aug 11, 2018, 7:06:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
