Features
Previous Thread This topic has been viewed 807 times and has 2 replies Next Thread
AdeleAlli
Italy
Preteen twins bedroom
Hi everyone,
I tried to realize a small bedroom for twins; the main objective was to try to play with the external lights.
In order to do this I added two white light sources outside the windows but I do not like very much the result (you can see the images down in the post).
The lights are set to dimension 20x20x20, elevation 230cm and power light 80%. Does anyone have suggestions in order to improve the results and to obtain more natural lights?
Maybe I should put the light sources higher to have a better shadow coming from the windows... but I am not sure it is only an issue about the position of the light sources.
Thank you all
Twin brothers room
Twin sisters room
[Jul 19, 2018 6:53:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
rontant
Singapore
Re: Preteen twins bedroom
Have you tried modifying the compass to make the window facing east or west and adjust the time of the day in the photo rendering tab? If you make the window face the west, then you can try setting the time to around 16:00 to 18:00.
[Jul 21, 2018 3:48:16 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
AdeleAlli
Italy
Hi rontant,
thank you very much for your suggestions!
Here is the result I obtained following your advice:
Now the shadows are pretty much as I desired, thanks again.
[Jul 21, 2018 7:11:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2019 eTeks - All rights reserved
