Italia
Re: Sweet Home 3D 6.0
Great you like it I know that you proposed an angle for the sky texture offset, but using a percentage seems more versatile in other cases, and isn’t too difficult to convert from degrees : 180° = 50%, 90° = 25%, 45° = 12.5%,...
What about adding this as hint/popover of the slider? A lot of information are among the forum but very difficult to find or imagine in the app. And this is really important, not everyone is following the forum unfortunately
The Beta 8 just contains a quick fix I forgot in the texture choice dialog box.
1.Sky texture Do not support 16K 2.Sky texture may get stuck after multiple settings.It is recommended to add a preview graph to the texture of 4K 8K 16K, otherwise it will affect the speed very much.
3. I suggest that an 'Apply' button should be added to the XY offset set window.So that users can see changes immediately. 4.It is recommended to add the function of changing texture color(Hue) and texture transparency. Very convenient. 5.I suggest changing the image preview size of the texture settings window from 128X128 to 256X256 or 512X512. 128 is too small to see the difference
My only little problem now, is that my list of imported test textures has become ridiculous. Among a few good ones, there are many hundred totally useless, experimental images. It would be great if the texture import wizard had a check- box NOT saving an imported texture (other than in the .sh3d file) - like furniture.
..proposed an angle for the sky texture offset, but using a percentage seems more versatile in other cases...
Interesting interface issue considering some recent threads, e.g. Cec' brilliant guide in thread 8832, the Azure home, thread 8828 - and whether to use the compass to 'simulate'. People use different references for orientation and how they see the world. Whether to keep a map North up, or turn the map to align with terrain. Cec' template measures degrees from the point of view of the virtual visitor, whereas I need the compass orientation to read the 3D view.
Even if I in theory would prefer a degree angle sky texture, in practice conversion is easy and it makes no difference. And since percentage is more consistent with other textures and probably easier and more intuitive to use in normal cases, percentage is probably a better interface choice. (But if possible, I agree with ndorigatti that a hint could be a good idea.) And never mind the measure, the important thing is the function that works very well. Thanks again.
Great things are happening here! I have finally been able to test this, and I can't wait to get my hands on the final version (or a non-web-start beta version). It won't display any of my projects, but I managed to play a bit and create a small object or whatchamacallit – to utilize the sky offset spinner: With sky offset, this joint will no longer be something I have to use time on :
My first project with v6 Beta8: Horizontal_Scale.sh3d It's not perfect, but it works.
... and the new colour palette is perfect
Question: I use curved walls a lot when creating models, and I make custom textures for them. Of course I can open my calculator and calculate the length, which is what I do, but caould the math be included in the modify walls window? (And it would be great if we could curve a wall 360° )
Very good, great features.
But I have a problem with Add point to room. It just sort of stops at the context menu item, and no point is created when context menu closes. Context menu still has highlight on Add point to room when context menu is opened again.
Thanks for your feedback and reporting the issue in the Plan contextual menu. It's fixed in the Beta 9 which brings also the following two new features : - It's now possible to view the background image set at ground level in the 3D view too, by selecting the new check box Background image visible in 3D view in the 3D view modification dialog box.
- Each polyline may also be viewed in the 3D view with a new check box in its modification dialog. When the polyline uses a dash style, you can set an offset too, to shift the starting of the dash pattern.
These features are probably the last ones with user interface items that will appear in the coming version 6.0, so I can start to ask our great contributors to translate the new texts before considering a final release.
Bdfd, the compass shown in Sweet Home 3D plan doesn’t show any angle. And the X offset field of the sky texture lets the user shift that texture on the basis that the left border of the texture image will appear at the East for an offset and a compass angle both equal to 0. It could have been a better idea to consider that the left border of the sky texture is at North when its offset is equal to 0, but that would break the compatibility of previous SH3D files. I’ll see if I can add a N to indicate the North on the texture image preview to help users understand this.
