Re: Sweet Home 3D 6.0
The Beta 4 brings some more expected features than articulated mannequins and opening doors - First, objects placed at an underground level now individually dig the ground when they belong to a group (see Holes in the ground thread).
- It's possible to select more than a material in the list shown in materials modification pane to change faster a group of materials that should look the same. Multi selection can be done with the shift key for a single interval, and with ctrl / shift ctrl keys to select/unselect an individual material (cmd / shift cmd keys under macOS).
- All spinners showing numbers are able to compute the math formula you'll enter, except for lengths using foot/inch/fraction notation.
If the value can't be computed, the text of the spinner will be displayed in red. The result of the formula replaces the entered text as soon as the focus is transferred to an other field. The syntax of the formulas supports the operators + - * / ^ (power) and the functions LN, LOG, EXP, SQR, SQRT, COS, SIN, TAN, ARCCOS, ARCSIN, ARCTAN. It isn't case sensitive and functions may be followed directly by a number without any brackets (except of course if you want to change the priority of a part of the calculus). This feature was programmed with a simplified version of JeksParser, a library I programmed a long time ago.
- Prices can now be entered in the furniture modification pane
once you chose a currency with a new drop down list available in the preferences pane
As the previous images show, it's also possible to activate VAT management (or more generally any tax percentage that should apply to the price), if you want or need to show the difference between price without tax and price with tax included. When this option is selected, the furniture modification proposes a default 20% VAT value as soon as you enter a price. You may change this percentage, and the new % value will be reused for next price change.
Total price, and Total VAT with Total VAT included values appears at the bottom of the furniture list, as soon as a currency is selected in the preferences pane (only Total price appears if the Use VAT preference is unselected). The furniture list may also display the price, the VAT %, the VAT and the price VAT included of each piece, if you request to display the matching columns with Furniture > Display column menu.
These columns and the Price / VAT % fields of the furniture modification pane are available only when a currency is selected in the preferences pane. If you don't want to use prices, simply choose the option Ignore price in the preferences pane (or leave it unchanged).
Each time the price of a piece of furniture is set or changed, its associated currency is set from the currency currently selected in the preferences pane. This allows to use different currencies in the same project (in which case the totals below the furniture list are blank), and more likely, to distribute a SH3D file to other people without worrying about the currency they use. Note that currency symbols like $, €, £, ¥... are used only when it's the symbol used in your language and country, otherwise the three letters currency code is generally used. For example, USD will appear instead of the $ symbol if the application is used in Europe, and US$ will appear in Canada.
I hope you'll like how I managed prices and currencies in Sweet Home 3D, even if this beta may not have resolved some subjects, like the prices of services and other things different from furniture. Are there some cases when using dummy furniture could be an unacceptable workaround? I wondered also if negative prices should be accepted for rebates, and if printings should include totals, since furniture prices can already be exported to CSV or to the clipboard. Please, test these new features and post your suggestions.
Rontant, the Photo-Video Rendering and the default photo creation option in Sweet Home 3D can give different results. Sorry, it's not the right thread to discuss about that subject, as you can't compare the results of the two tools in Sweet Home 3D Beta.
Emmanuel,
Awesome work, once again!! Thank you very much!!
I did a few quick tests with prices and export to CSV, and came across a few problems. Dimensions are exported as values when whole numbers, but as text when there is a decimal involved. All prices are exported as text, which (when importing into a spreadsheet) means that you have to manually enter all prices again in order to be able to do any calculations.
My suggestions: - all dimensions should be exported as numerical values - all prices should be exported as numerical values, without the currency symbol, OR with the currency symbol separated with a delimiter, so that price and currency symbol end up in different columns.
Italia
I have a question for you Puybaret... Did you already tried/programmed/planned to support multi hinges on a single element? I mean, my windows and door windows can be opened in classi way (let's say rotate around vertical hinges) but can also be turned a bit rotating around horizontal hinges (on bottom) so a little fresh air can come in. Do you think I can put both vertical and horizontal hinges on a window and see it turn? I'm trying to do it but I'm not so good in blender and in understanding the prefixes (my old models where a single element, not separated into groups)
Thanks all for your feedback.
Hans, numbers use the same decimal separator as in Sweet Home 3D, so it depends on the selected language. Prices and % look very similar to how Excel exports to CSV too. Keep in mind that CSV is a very poor format: it doesn't store the character encoding in use, doesn't oblige to use a coma or a point, doesn't state how numbers like prices should be formatted... Just open a CSV file with a text editor and you'll see it's just some lines with data separated by tabs.
ndorigatti, multi hinges aren't supported and I don't plan to add support for that. It would require to organize 3D shapes very differently in the program.
Prices was what I was missing in former versions - Great work, thanks!
Though I agree with Hansmex, that it would be great if prices could be exported to CSV without currency, so numbers could be calculated in a spreadsheet.
After some additional tests, I noticed that prices followed by user's currency and percentages are correctly interpreted as numbers by Excel and OpenOffice when the CSV file is imported. So I don't think there's a need to change the current format, moreover in case the currency is needed during a CSV import. I'm more concerned by the encoding of the CSV file. At the moment, the encoding in use is the default one on the system where the the furniture list is exported. I propose to switch to the more versatile UTF-8 encoding to avoid problems between systems and if ever you need to choose another encoding, I'll add a system property for this purpose.
