Re: Sweet Home 3D 6.0
What makes you think it's because of the version 6.0? Under what system do you use Sweet Home 3D? What error do you get?
Hongarije
I was first using version 5.7 without any problems (Windows 10 system). After updating to version 6.0, the program crashes as I try to save my drawing. After going back to 5.7 everything works great again...
I will try to uninstall first and re-install 6.0. I hope it will be fixed then.
With this option the math formula in number box are not processed. Without this (original file) it work perfect.
---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law (Greer's Third Law) When all else fails, read the instructions.Murphy's Law
Rus
sorry guys if this is not the proper topic or these problems have been already discussed. After upgrading to v.6 'Catalog icons' option of 'Furniture icons in plan' in 'Preferences' is not available. So all the models at plan now are shown as top view icons. Also two lowest (fastest) qualities in 'Create photo' are not available too (the slider just cannot be moved to the corresponding positions).
Romania
Is not a big deal only look a little bit better The standard:
The nimbus:
Remember the Warning: with this look-and-feel setting some function DON'T work. I've discover at this moment only the math formula issue but could be more other.
Nederland
Hi Puybaret, I managed to open and close a door with Blender. In SweetHome I can now see the option (Modify opening) but the textures of the door and hinges are transparent after exporting them (OBJ) from Blender. (The door frame is not transparent). What should I do to make the textures solid ?
Nederland
Hi Puybaret, Found it and I'm a little embarrassed, I forgot to look at the "normals" in Blender, they weren't all facing out. Sloppy of me but maybe someone else can benefit from the "solution".
