Total posts in this thread: 2
Previous Thread This topic has been viewed 660 times and has 1 reply Next Thread
trandel
South Africa
add furniture to home
Hi
Having a problem adding furniture. I drag and drop an armchair but the result is a tiny image. When I try to edit its size the result is still very small and the pic is of a cabinet? I am using centimetres and all seemed OK with the walls etc but the furniture seems about 10 times too small i.e. 90cm I change to 900cm to see it.
Am new to Sweet Home and assume I must be doing something wrong??
Regards
Tony Randell
[Jun 19, 2018, 11:16:09 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: add furniture to home
Hi Tony,
You could have imported a 3D model with small dimensions. If this is the case, did you check then fix the size proposed at the 3rd step of the furniture import wizard?
[Jun 19, 2018, 2:47:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
