Total posts in this thread: 2
Previous Thread This topic has been viewed 2101 times and has 1 reply Next Thread
ZioLollo
Render light problem
I would like to make a rendering of the fairground pavilion I made, the measures are 50 meters x 50 meters, it is a very large area. If I use the sunlight the shadows are too sharp, if I use the ceiling light I have to put so many that the rendering is too slow to make. Is there a way to have a diffused and uniform brightness?
I did a thousand tests, but I could not get a good result, I need some advice
[May 21, 2018, 9:27:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Render light problem
You will have to add some lights. This tip might help you.
[May 22, 2018, 4:36:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
