Re: Opaque window
By "opaque", do you mean the glass should let some light go through, but without being able to distinguish objects being the glass? Not sure it's really possible in Sweet Home 3D, but you can try with some glass textures on some transparent material, like in this video at 3'05".
Re: Opaque window
Yes, exactly !
Not sure it's really possible in Sweet Home 3D, but you can try with some glass...
I did many tries without success.
An idea : I read this morning a fetaure of enko on light about a vertical surface... but how make this object ?
Re: Opaque window
Hello, if I understand correctly you want to adjust the transparency of an object I'm going to change the mtl property of the obj file is this what you're interested in?
Re: Opaque window
Hello, if I understand correctly you want to adjust the transparency of an object I'm going to change the mtl property of the obj file is this what you're interested in? translated google
Hi Golia,
It was a good idea but no !
I explain : I did that you said with the mtl file (d 0.975).
Directly under sh3d, Yes with a outside screenshot !
Look at the left side... --------------------------- But in standard rendering...
Outside and without light, opaque propertie has disappeared. ---------------------------
Outside and With light, no difference. ---------------------------
Inside without light, no difference ! ---------------------------
Inside with light, same result !
Thank you for your idea but it's not positive...
