Features
Total posts in this thread: 35
Posts: 35   Pages: 4   [ Previous Page | 1 2 3 4 ]
Previous Thread This topic has been viewed 3961 times and has 34 replies Next Thread
dorin
Romania
Re: Group furniture items in category
A quick test result in this:
1. The v-0.4 reduce the delay from 30" to 19"
2. In tree view the furniture completely disappear with plugin activated.
3. The perimeter are show like in image with no option to modify.
3.1 I suggest again to split in to different plugins and focus at this moment only on Grouper. After this one will be acceptable could concentrate to other one (perimeter or some more useful and complex).
4. I think is good to remove unnecessary dependencies and use as much You can from SweetHome (I don't know how, You're the programmer tongue ) .
5. Don't forget the principle: Keep'it simple, keep'it free.
[Apr 17, 2018 7:00:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
I propose some principles for testers. Could be improved.
1. Use the official installer version from Sweet home 3D site (Windows, Linux32, Linux64)
Note: It's necessarily to have the same version of java. In many distributions is the principal reason to don't work properly.
2. A clean install. No other furniture, languages, plugins and textures.
- To do this backup Your current installation:
Under Linux: -rename the folder ~/.eteks/sweethome3d to ~/.eteks/sweethome3d-1
or
-rename similar all the folders to keep the preferences file
-restart the SH3D program which will recreate the necessary folders
-if You have to test an plugin than make the plugins directory under ~/.eteks/sweethome3d and copy the sh3p file in it.
Under Windows: -rename C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D to C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D-1
Note: Windows testers know bather if it work or not or how to do this.
3. Make the tests:
3.1 First set of tests
- without drawing (if the tests could be made like this, e.g. "FurnGrouper" plugin)
- with fresh simple drawing which include most of parts of a plan (rooms, walls, door&windows, furniture etc.)
- with an existing more complex already made plan
3.2 Second set of tests
- reverse the folders name previously renamed to their originals to have again all personal furniture, languages, plugins and textures
- copy the plugin (furniture or texture) in corresponded folder to be available to test again
- repeat the tests from 3.1
4. Collect and share the resuls with specify:
- the operating sistem and version
- few hardware specifications like CPU and graphic card
Here I've made on completion of my previous post, this:
SH3D clean, no drawing -memory usage: 198.756k
SH3D clean, no drawing + SH3DFurnGrouper.sh3p activated -memory usage: 254.388k
SH3D clean, no drawing + SH3DFurnGrouper.sh3p deactivated -memory usage: 263.020k
SH3D clean, simple drawing + SH3DFurnGrouper.sh3p activated -memory usage: 275.728k
OS: Debian "buster"; Kernel 4.15.0-2-amd64; KDE Plasma 5.12.4
Hardware: CPU 2 x Intel Core 2 Duo
Video on board
RAM: 4G
Note: This is one of the desktop computers (from work)
[Apr 17, 2018 12:42:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Lizard2k1
Russia
Great plane of home - realy.
I try reduce them more (look next version)
Fixed
Sorry for this, but.. not.
Because i write this plugin only in my free time, and i have no time to observe many version with many build for separated plugins, and, in future, i believe - builds and versions will be some more..
It's too seriously way to test my small project. It's must not take so many payloads.
forget SH3D clean, simple drawing without my plugin smile
And at last: v.0.5
[Apr 18, 2018 11:34:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
I've tested the v-0.5.
It's work as You say.
1.In searchable mod all's well, it work correct.
2.In Category list remain previously symptoms and the most important is on popup preview over furniture are show only the first in row.
3.It appear the delay are drastically reduced as I can't mention to see.
4.
9. After enable group view can't return to standard view
Indeed but accessing the Settings button and change the view from one to another resolve this (at the moment).
While I must go to Settings to switch between mod of view I remain on opinion to be there a check box for enable the Grouper.
5.About perimeter now is OK with short info (only P=xxx.xx cm).
In this mod is really useful.
The full information are not necessarily to show but for future "Room Walls area" which will be show near or under P=... blushing
PS
I really appreciate this applause and sorry if some times I demand too much.
So, please keep working ONLY You have time and have a good disposition for this.
Thanks again for Your work!
[Apr 19, 2018 7:40:06 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Golia
Thank you for your work, tomorrow I will definitely try the new relase.Ciao thank you
[Apr 20, 2018 6:27:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2019 eTeks - All rights reserved
