High priority FurnitureLibraryEditor-1.22.jar will not run
This topic has been viewed 58659 times and has 4 replies
Thread status: Active
Discuss anything here [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Post Reply New Topic
nuvolari
Country: United Kingdom
Post by nuvolari »
I am running XP SP3. I have been using SH3D for some time, and followed the prompt to update to 5.7 today.
I spotted the FurnitureLibraryEditor program while on the website.
After some fun and games I found the java program in C:\Program Files\Sweet Home 3D\jre8\bin.I copied the .jar file into the bin directory, and double clicked - nothing happened.
What am I not doing?
User avatar
Country: Paris, France
Contact:
Re: FurnitureLibraryEditor-1.22.jar will not run
Post by Puybaret »
It's not because you place the .jar file in the same directory as javaw.exe that it will be launched with a double click! If you don't want to separately install Java, you'll have to open a cmd window and run the following command:
Code: Select all
"C:\Program Files\Sweet Home 3D\jre8\bin\javaw.exe" -jar "C:\Program Files\Sweet Home 3D\jre8\bin\FurnitureLibraryEditor-1.22.jar"
ahari
Country: Deutschland
Post by ahari »
An old thread, I know, but is there an equivalent on Linux (Mint)?
In other words, can I use somehow call the java that is included in SweetHome 3D (I understood that it's there)? I would prefer not to install an extra Java runtime environment for the FurnitureLibraryEditor.
Or did I misunderstand this?
User avatar
Moderator
Country: Netherlands
Post by Keet »
Of course although it is possible that the FLE doesn't work correct with that same version. I use different versions for Sweet Home 3D and the FLE.
Bash script to use an installed java runtime:
Code: Select all
#!/bin/sh
exec java -jar [path]/FurnitureLibraryEditer-2.2.jar
Bash script to use the Sweet Home 3D runtime:
Code: Select all
#!/bin/sh
exec [/sweethome3d-install-directory]/runtime/bin/java -jar [path]/FurnitureLibraryEditer-2.2.jar
Make sure you make the script file executable.
ahari
Post by ahari »
Thank you very much!
Who is online
Users browsing this forum: Semrush [Bot]
