Half walls and bulkheads
Hello. I'm designing a room and I have a half wall that I can't figure out how to draw it. Is there a way to make a wall that is only a certain height not from floor to ceiling? Also is there a way to make it say drop down from the ceiling two feet? I need to make a bulkhead in my basement that holds all of the forced air trunks and some electrical and plumbing.
Re: Half walls and bulkheads
Create the wall with your desired height. Export the wall as .obj next import it to your furniture library. Once you click and drag the wall on to the floor plan,you can change the elevation.
