Total posts in this thread: 19
Posts: 19   Pages: 2   [ Previous Page | 1 2 ]
Previous Thread This topic has been viewed 34364 times and has 18 replies Next Thread
Re: Sweet Home 3D 5.7
<string>-Xmx8g</string>
[Feb 19, 2018, 3:40:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
serinter
Brazil
Java Web Start works great !
the problem I mean, is in The installer version! Windows 8.1
When I mean "nothing happens", is because, i go to "save" window, write the name, and click in SAVE, the "save window" close, but the file didnt save,!
[Feb 19, 2018, 5:48:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
serinter
Brazil
How can I insert older library to the Java Web version ?
Because this version works normal for me ! but with limited library
[Feb 19, 2018, 5:51:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
@Xiste
Did you solve this? In that case, please tell me how.
Sorry.
I got the same error as you. But, as you say, this version is unimportant, so I didn't put a lot of effort into fixing it.
x
[Feb 19, 2018, 7:32:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
live
OS win10 64bits
After 5.4, every version incl 5.7 on launch:
"Sweet Home 3D doit quitter maintenant à cause d'une erreur fatale dans son système de rendu 3D. Mettez à jour les drivers DirectX/OpenGL de la carte video de votre ordinateur"
[Feb 24, 2018, 11:24:16 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Live, try the suggestion about dxwebsetup.exe in this subject,
and if it doesn't work, then try the parameters /j3d.version=1.5.2 /os.arch=x86 added to the installer and described here.
Xiste, Ceciliabr, maybe High Sierra does not accept to change Info.plist anymore. Strange that it worked on my side...
[Feb 24, 2018, 11:49:37 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Yes, that is indeed very strange. I have tried both ways of editing the info.plist on several machines, and I get the same error.
This obviously has nothing to do with OSX, since I still have no problems editing the info.plist in v 5.0 without getting any error message.
Maybe some security measures have been included in the newer versions of SH3D, something that's preventing any attempt to alter the original?
cec
[Feb 25, 2018, 2:16:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I found how to reproduce your issue: I downloaded Sweet Home 3D DMG, copied the application on my hard disk, changed the Info.plist file then launched the program. But if you launch the program at least once before updating the Info.plist file, the error won't happen.
Hope this will work for you smile
[Apr 3, 2018, 1:01:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
GREAT!
Thank you!
[Apr 12, 2018, 5:49:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2022 eTeks - All rights reserved
