South Africa
Version 5.6 Solution (Windows 10)
I had a problem with version 5.6 using Windows 10 64 bit with error message "DirectX/OpenGL". I installed dxwebsetup.exe, JavaSetup8u151.exe and SweetHome3D-5.6-windows.exe. The problem was solved. I am using HP Pro-book 650 G1, I was running Windows 7 32 bit then upgraded to Windows 10 64 bit and the problem started but now it is solved.
Re: Version 5.6 Solution (Windows 10)
Great! Thanks for your feedback As Sweet Home 3D comes with its own copy of Java, I wonder if installing JavaSetup8u151.exe is really required. And what is dxwebsetup.exe?
