Total posts in this thread: 29
Posts: 29   Pages: 3   [ Previous Page | 1 2 3 ]
Previous Thread This topic has been viewed 20369 times and has 28 replies Next Thread
alaX
Poland
Re: Search luminous neon objects!
Neon digits white
Neon digits yellow
Neon digits green
Neon digits cyan
Neon digits blue
Neon digits magenta
Neon digits red
[Jan 4, 2018, 6:13:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
alaX
Poland
Neon digits orange
[Jan 13, 2018, 6:02:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
rontant
Singapore
Oh man! I have been searching high and low for weeks to make a glowing material and only now I stumbled upon this thread. I think thhis should be made sticky or at least mentioned in the Tips section.
This is very useful. Not only for those who want to make neon signs. Below is the example how I made my spotlight housing rim to glow using tips found on this thread.
See the spotlight on the right?
[Jul 28, 2018, 3:09:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
With the YafaRay rendering engine, you can transform any object into light.
Based on the logos and neon signs created by Ceciliabr.
standby before shutdown
[Mar 10, 2020, 3:00:06 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hi, trying, unsuccessfully, to get a stair tread to glow
Is it only the illum line that has to change, or is there something in the .obj file as well.
Tried with Path instead of ambient occlusion, just took longer to get the same result.
Any help would be appreciated.
Thx
[Jan 27, 2021, 4:50:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Sorry Mike, it won't work with transparent materials.
[Jan 27, 2021, 6:27:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Ok mate, thx for the prompt reply, even if you are the bearer of bad news, you may keep your head. biggrin
[Jan 27, 2021, 6:37:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
So this is what i came up with to get a similar effect
created a rectangle of walls, 2 mm x 30 mm exported it and modified its MTL
[Feb 5, 2021, 8:18:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
DeonEva
Thanks everyone for the tips and helpful links! there are one in a million. All kinds of signs, letters, and so on! Hurrah!!
"Let the beauty of what you love be what you do."
https://www.worktime.com/employee-monitoring
[Mar 3, 2021, 4:59:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2022 eTeks - All rights reserved
