Total posts in this thread: 41
Posts: 41   Pages: 5   [ Previous Page | 1 2 3 4 5 | Next Page ]
Previous Thread This topic has been viewed 78722 times and has 40 replies Next Thread
UbuntuBirdy
Re: Doesn't launch anymore in Ubuntu 17.10
I cannot figure out where the performance loss of java3d 1.6 is coming from and so I had to switch back to java3d 1.5.2.
... very disappointing, but hey, that's life...
Pascal
[Feb 15, 2019, 1:19:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mrpraline
NL
Don't know if I should start a new thread, but I cannot run Sweethome3d in Ubuntu 18.10. Both of the scripts in the download directory fail to run.
With both scripts I get:
# A fatal error has been detected by the Java Runtime Environment:
# Internal Error (os_linux_x86.cpp:291), pid=17622, tid=0xf6bccb40
# fatal error: An irrecoverable SI_KERNEL SIGSEGV has occurred due to unstable signal handling in this distribution.
# JRE version: Java(TM) SE Runtime Environment (8.0_202-b08) (build 1.8.0_202-b08)
# Java VM: Java HotSpot(TM) Server VM (25.202-b08 mixed mode linux-x86 )
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /home/gjbaarda/Downloads/SweetHome3D-6.1.2/hs_err_pid17622.log
# If you would like to submit a bug report, please visit:
# http://bugreport.java.com/bugreport/crash.jsp
Afgebroken (geheugendump gemaakt)
If I run the webstart version the initial window opens but then I get a pop-up window saying '3D error" and after clicking OK SH3D exits.
[Mar 4, 2019, 9:45:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
UbuntuBirdy
In your personal folder in .local/share/applications create new file named SweetHome3D.desktop.
Copy the following content into it:
[Desktop Entry]
Version=1.0
Name=Sweet Home 3D
GenericName=Interior 2D design application with 3D preview
GenericName[de]=Innenraumplaner
Comment=Interior design Java application for quickly choosing and placing furniture on a house 2D plan drawn by the end-user with a 3D preview
Path=/path/to/SweetHome3D-6.1.2
Exec=sh -c "/path/to/SweetHome3D-6.1.2/SweetHome3D-Java3D-1_5_2" %U
Icon=/path/to/SweetHome3D-6.1.2/SweetHome3DIcon.png
StartupNotify=true
StartupWMClass=com-eteks-sweethome3d-SweetHome3D
Terminal=false
Type=Application
Categories=SweetHome3D;2DGraphics;3DGraphics;Graphics;
Keywords=interior;design;2D;3D;home;house;furniture;java;
MimeType=application/sweethome3d;
Edit "/path/to/SweetHome3D-6.1.2" to the location where your SH3D is.
At the "Exec"-section you can try the other start script too.
This will start SH3D via the terminal.
Pascal
[Mar 13, 2019, 3:03:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mrpraline
NL
Hi Pascal,
I tried your suggestion, but no success. I should have told you that the messages I got were from staring Sweethome3D from the command line.
So I typed both ./Sweethome3D and ./SweetHome3D-Java3D-1_5_2 in the directory where I extracted SweetHome3D-6.1.2-linux-x86.tgz.
[Mar 16, 2019, 2:16:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
UbuntuBirdy
It was only a try, you have not the same issue as I had. So, what type of video card have you installed? Have you the newest driver for this card? What's the reason for running Ubuntu 18.10 and not the 18.04 LTS?
Pascal
[Mar 16, 2019, 4:06:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mrpraline
NL
I'm beginning to think it is related to the graphics card. On my laptop, which is also running ubuntu 18.10, I can run the webstart SH3D if install the java3d and icedtea package. This has an intel graphics chipset.
On my desktop, I can't. It is a 12GB core i7 920, using an NVIDIA Geforce 660 Ti. Graphics driver is 390.116.
If I open the webstart version I get the program window, but then a window pops up saying 3D error. If I click that it will close the program.
[Mar 17, 2019, 11:09:34 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mrpraline
NL
smile Re: Doesn't launch anymore in Ubuntu 17.10
To reply on my own post:
I removed and reinstalled all Java stuff on my computer and now I get the same behavior from the command line as from the webstart link if I use the ./SweetHome3D shell command.
However if I use the ./SweetHome3D-Java3D-1_5_2 command SH3D starts!
SO, I have no idea what was the problem, but now it is gone.
[Mar 17, 2019, 11:22:15 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
lpalazzotto
Hey Pascal:
You seem to have learned quite a lot about this problem of Sweet Home 3D not launching in Ubuntu.
When I run it to terminal here is what I get:
Java 3D: implicit antialiasing enabled
Java 3D ERROR : GLX extension is not supported
GLX version 1.3 or higher is required
Gtk-Message: 23:46:53.643: Failed to load module "canberra-gtk-module"
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
etc.
I have Java Oracle 12 installed. What is this GLX 1.3 and how do I fix it? I cannot see it in my system.
[Jun 5, 2019, 1:19:18 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
lpalazzotto
P.S. I have Ubuntu 19.04
[Jun 5, 2019, 1:21:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Maybe out of topic
For those who use it under all kind of linux system:
Forget about any ppa, synaptic or whatever repository. Usually don't work or don't work correctly for a lot of reasons.
That's not the fault of SH3D developer BUT the distribution managers.
At this times the space is no more a problem for decent programs.
Use the installer version from this site and You will be more happy.
e.g.I have a <60G SSD for all system and programs (root, home & swap);
SH3D have 140MB + a lot of library and plans all at a half of an ancient movie.
[Jun 9, 2019, 5:49:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
