Total posts in this thread: 17
Posts: 17   Pages: 2   [ Previous Page | 1 2 ]
Previous Thread This topic has been viewed 12900 times and has 16 replies Next Thread
enkonyito
Re: Same image – like night & day - a miracle?
@Ceciliabr
I think I prefer dark level 2. The difference might seem minimal on these small pictures, but will probably be a lot more visible on a larger image.
By default, the dark value is 0.
You can test the minimum night brightness (dark value 1/255) with the beta version of the plug-in .
[If it's possible, I'll try to embed a dark level test instead of changing the value in the source code.]
On the two lower images I can see there is a blue hue that is more visible on dark level 1 than on dark level 2, but it seems to be the other way around on the two bathroom images. Does this have anything to do with sky texture or colour?
As the SimpleRoom.sh3d project has an outside opening, I used a black texture for the sky.
EnkoNyito
[Jan 10, 2018, 3:42:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I did, but I did not notice any difference from the default renderer.
cec
[Jan 11, 2018, 9:10:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
With your project, the difference between dark value = 0 (default renderer) and dark value = 1 is not obvious. That's why I added dark value = 2.
The PVR-1.4_betaTest version will allow you to choose the desired dark level (0, 1 or 2). smile
Enko
EnkoNyito
[Edit 1 times, last edit by enkonyito at Jan 11, 2018, 11:36:10 PM]
[Jan 11, 2018, 6:30:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Perfect!
With dark level 2 I can see the body of the bathtub.
This bathroom has no windows.
I will make a window and do another test after dinner :)
I think adjustable DARK LEVEL is a keeper.
cec
[Jan 12, 2018, 5:09:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Bathroom with window.
cec
[Jan 12, 2018, 8:45:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
The option can also be used for the exterior.
I think I will also choose dark level 2 for the final version of the plug-in.
EnkoNyito
[Jan 13, 2018, 4:50:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I like dark level 2 renderings! Thank you EnkoNyito.
[Jan 13, 2018, 7:40:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
