Spain
measurement between walls
Just found this amazing apps, installed and learning.
Not sure if I'm not doing it right or this feature is not there, what I want to do is to measure the distance between two walls, the trouble is whenever I moved a wall, the distance (in the menu bar, there's an icon for distance, that's the one I used). I tried to click the mouse when the blue line at the wall showed up, but if I moved the wall, the measurement remains in the same place, did not move with the wall.
Is it possible to make the distance move along the wall? If so how?
Thanks for your comment/suggestion Michael
Re: measurement between walls
Select both measurement and wall with SHIFT-Select before you move. Or delete first measurement, and double-click with measurement tool on the wall in its new location. ok
