Re: Sweet Home 3D 5.5
1. The progress bar into the box window didn't move. 2. Regressions a.The function 'Save as' breaks down sh3d. b. Save a rendering photo breaks down too... Perhaps by giving a beta6.jar would be OK ?
Do not anything !
I resolved ALL the problems in renaming INI file in initiale name !
[Edit 2 times,
last edit by bdfd at Jul 30, 2017, 8:03:42 AM]
bdfd, thanks for your tests. Apparently the file bug in Windows 10 Creator update wasn't fixed in beta 6 yet, but I have other ideas, better than obliging users to add a SweetHome3D.l4j.ini file. Here's the version 5.5 Beta 7 [link removed, see this message to test version 5.5 Beta 10] that might fix that bug. It would be nice if you and/or harhouse could report if showing file dialog boxes works better in this version.
This Beta version brings also auto translation of furniture names found in demos, and the first translations of the new features in Italian, Portuguese, Dutch, Czech, and Polish made by the nice Sweet Home 3D contributors. Finally, it fixes again an other small issue about furniture rotated around an horizontal axis (a really tough subject as I feared!!!).
Emmanuel Puybaret, Sweet Home 3D developer 2
[Edit 2 times,
last edit by Puybaret at Aug 4, 2017, 4:08:22 PM]
bdfd, thanks for your tests. Apparently the file bug in Windows 10 Creator update wasn't fixed in beta 6 yet, but I have other ideas, better than obliging users to add a SweetHome3D.l4j.ini file. Here's the version 5.5 Beta 7 (Java Web Start version and Windows installer) that might fix that bug. It would be nice if you and/or harhouse could report if showing file dialog boxes works better in this version.
Sorry, No change (dialog box & save as) ! beta7 crashes too (without ini file).
[Edit 1 times,
last edit by bdfd at Jul 30, 2017, 5:59:15 PM]
bdfd / harhouse, please try the Windows installer of the version 5.5 Beta 8 without the SweetHome3D.l4j.ini file. I found an issue about how Java 8u51 handles Windows 10 version number and it prevented the correction that I programmed for file dialog boxes to work! Thanks for your patience...
[Edit 1 times,
last edit by Puybaret at Aug 4, 2017, 4:07:33 PM]
It's better with beta8...
No crash (Save as or Save rendering photo)
No change for the dialog box
[Edit 1 times,
last edit by bdfd at Jul 31, 2017, 11:45:51 AM]
Thanks for your tests. Great that it works without any SweetHome3D.l4j.ini file this time
Do you mean the dialog box shown when you select Save & compress? Does it actually save the file?
Tonight, the version 5.5 Beta 9 brings translations of the new features in German, Swedish, Russian, Traditional and Simplified Chinese, and a few more improvements about horizontal rotations. I also updated some demos to ensure they use the new features of the version 5.5, particularly for sloping roofs and doors on thick walls. Finally, I decided that the child piece with the biggest model size will be used as a sort criterion for rows containing a furniture group.
[Edit 2 times,
last edit by Puybaret at Aug 4, 2017, 4:06:58 PM]
This is really a very small aesthetic bug that I can't reproduce on my Windows 10 computer. As long as the lengthy operation still works, I don't think I'll look for how to fix this issue. Probably a small problem in Java. Anyway thanks for reporting it.
