Singapore
Using Dimensions in Name of object
It would be nice if there are some short codes we can use to put in the dimensions of an object (furniture) in the name so it will appear in the plan when we tick the check box.
For example: - if the dimension of the object is Width: 100cm Depth: 50cm Height: 90cm.
In the name field, if i can key in Table: %d x %w x %h Teak SH3D automatically displays Table: 50 x 100 x 90 Teak as the name of the object on the plan
Some short codes can be %d - depth %w - width %h - height %x - location X %y - location Y %e - elevation %a - angle
