Total posts in this thread: 109
Posts: 109   Pages: 11   [ Previous Page | 2 3 4 5 6 7 8 9 10 11 | Next Page ]
Previous Thread This topic has been viewed 220460 times and has 108 replies Next Thread
Re: 3d View suddenly impossibly slow
From a recent discussion with Java 3D maintainers, there seems to be a solution to run Sweet Home 3D under Windows 10 64 bit on old Intel processors with integrated graphics.
If you continue to get the driver error at Sweet Home 3D launch in 64 bit, you should simply download
https://communities.intel.com/servlet/JiveSer...80582/legacy-igpu-x64.zip
unzip it and execute the install.cmd it contains.
Please, try it and report how it worked for you.
[Mar 3, 2018, 2:48:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Chucky2910
Germany
have the same problem right now.
Using Windows 10 on a Laptop with Intel HD Graphic 4000.
The 3D view is laging as hell and i installed Java 3D after this it seem to befixed for around 15 Minutes. The 3D View worked nice but than lags again.
If i load a saved project i can see that the models on the 2D view take much more time to load as before...
I dont know what to do now. Have tried Puybaret tip with the legacy igpu thing but without any effect.
[Mar 6, 2018, 9:11:56 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
scanti81
Italy
My company is developing an app base on Java3D as well. We found out that disabling double buffering on the 3D Canvas helped to resolve this problem. Hope this helps.
[Mar 29, 2018, 3:25:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
EmAlvin
Italy
That worked for mee too. I just added a slight modification due to the version number and ran from comd line:
SweetHome3D-5.7-windows.exe /j3d.version=1.5.2 /os.arch=x86
in order to reinstall from scratch my new SH3D version. While my previous 5.7 plain installation did terribly slow down on 3D rendering, this installation mode competely fixed any issue.
I operate on a laptop with Windows 10 home 64 bit and a 3 years old Intel core i7 cpu.
I also noticed that after reintalling SH3D, it reserves just one third RAM than before.
So, tx a lot!
[Mar 31, 2018, 2:49:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
nschoot
Nederland
Maybe this helps others, but when I completely hide the Plan pane, the 3d view window suddenly is a LOT faster.
So, when I drag the divider between the 3d view and the plan view completely up, to hide the plan view, performance dramatically INCREASES... It's a bit counter-intuitive and it suggests that the 3d drawing is not the problem, but the 2d is...
[Apr 15, 2018, 9:06:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
picmau
what about the efficiency and quality of the results, using recording programs of what you see on the monitor as for example obs, camtasia studii , screencast-o-matic
[May 28, 2018, 11:10:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
picmau
...I have to do a projection of the video presentation of the project I made with Sw3d and the sweet home 3d video generation program at the best quality requires 420 hours !! I do not know how to do...
[May 28, 2018, 11:15:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
tootechnical
Wow! Usually 99% of the time when trying to find a fix for something, I'm never successful. When searching for and finding this feed while trying to fix the error of "Direct X" failing and needing updating in Windows 10, I gave this a shot and it worked. However, instead of the 5.5 installer I used the new download 5.7.
I did exactly what you spelled out:
For people not used to commands, this can be achieved this way:
- Press <Windows> + R keys
- Type cmd and press <enter> key
- Drag and drop the icon of the installer SweetHome3D-5.5-windows.exe in the command window (except I used the 5.7 downloaded installer)
- Type a space in the cmd window
- Copy /os.arch=x86 /j3d.version=1.5.2 and paste it in the cmd window
- Press <enter> key.
PERFECT!!
Thank you for all your help!
[Jun 10, 2018, 1:46:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
makkemoi
I'm Using sweet home on linux. Found that by increasing initial minimum memory allocation made screen (2d) to update faster.
I have high DPI display and for that used also suggested parameters.
The additional parameters used:
-Xms2048m -Xmx2048m -Dcom.eteks.sweethome3d.resolutionScale=2 -Dswing.plaf.metal.controlFont=Dialog-12 -Dswing.plaf.metal.userFont=SansSerif-12 -Dswing.plaf.metal.systemFont=SansSerif-12
Cheers biggrin
[Oct 1, 2018, 9:17:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
TheDecorium
United States
Opening a cmd prompt and reinstalling helped make the program 6.1.2 run properly but this should be the default of the installer to automatically apply these settings based on your machine specs. so my cmd line looked similar to
c:\downloads\utilitys\SweetHome3d\SweetHome3D-6.1.2-windows.exe /j3d.version=1.5.2 /os.arch=x86.
Just was a hassle to install this way, like i said it should have been click install, enjoy building
[Feb 15, 2019, 9:00:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
