Total posts in this thread: 5
Previous Thread This topic has been viewed 4131 times and has 4 replies Next Thread
rantsu
chile
Program goes black
When installing the new version (5.3 and 5.4) of sweet home to open the second after it goes to black, I use win vista and updated java, I do not know what I can do, I hope someone can help me ...
[Feb 2, 2017, 6:29:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Program goes black
Do you mean that the whole window is black, or only the 3D view (the part at the bottom right)?
There was a major change on the management of the 3D view between version 5.2 and 5.3. Does it work with version 5.2?
[Feb 3, 2017, 1:00:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
rantsu
chile
The program window if it opens, maybe 2 seconds pass and the notebook screen goes black and the program is closed
The version 5.2 works perfectly everything, is when I do the update I appeared the problem
[Feb 3, 2017, 3:56:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I had the same problem with a computer of 2010 (it had to stay in 4.6 !!!). biggrin
This was due to the opengl and directx drivers. angry
Try updating them if you have not already done so.
Verify java update.
What year is your notebook, your OS ?
Good luck.
[Feb 4, 2017, 5:33:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
rantsu
chile
Hello, bdfd
Good look for both drivers and only appears directx 11
Java version 8 update121
My notebook is from 2007 win vista home basic 32 bits
Always try to have everything updated the only guy who does not want to update is adobe
I do not know what else can I tell you a weird problem, right?
[Feb 4, 2017, 3:51:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
