Member(s) browsing this thread: MaryCher
Total posts in this thread: 225
Posts: 225   Pages: 23   [ Previous Page | 12 13 14 15 16 17 18 19 20 21 | Next Page ]
Previous Thread This topic has been viewed 595773 times and has 224 replies Next Thread
Enko,
Thank you, that was fast!!
I now get the same result as you.
PS - And it also works well under version 6.5 b2.
[Edit 1 times, last edit by hansmex at Feb 9, 2021, 3:09:09 PM]
[Feb 9, 2021, 3:02:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
PhotoVideoRendering-2.2 plug-in
  • compatibility with SH3D-6.5 and higher
  • compatibility with version 1.4.2 of YafaRay plug-in
  • transparent image background (photo panel, photos panel)
  • management of multiple selection of points of view (photos panel)
  • other minor bugs fixes and enhancements
EnkoNyito
[Mar 6, 2021, 3:24:15 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
PhotoVideoRendering-2.2a plug-in
  • fixed a bug for the JPEG format of images (multiple photo rendering)
EnkoNyito
[Edit 1 times, last edit by enkonyito at Mar 23, 2021, 4:57:33 PM]
[Mar 22, 2021, 10:49:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
PhotoVideoRendering-2.3 plug-in
EnkoNyito
[Jul 19, 2021, 3:02:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thank you, Enkonyito!
[Jul 19, 2021, 5:39:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
magnetic157
United States
Hello, hoping someone can help me. I'm running the newest app store version of the program on my mac with MacOS Monterey.
I installed the 2.3 version of the plugin plus the 1.4.4 version of YafaRay. After the image is completed rendering, the save menu doesn't allow me to save the new image. It's almost as if there is a permission issue - I can only see certain directories and when I try to save to them it doesn't save. I doubt this matters, but I tried with all 4 quality settings and get the same result.
The dialog box also does not look the same as if I were to use the native functionality.
v2.3 Save Box
Native SH3D Save Box
[Dec 14, 2021, 11:38:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The dialog box and the folders where you can save are different because of the security options imposed by Apple in recent macOS versions to sandboxed applications coming from the Mac App Store.
You must save the generated image in the Data folder or a sub folder proposed by the dialog box. It's the only way I found out to make it work when a user tries to save a file from a plug-in, but you can move the images afterwards if you want.
[Dec 15, 2021, 12:25:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Xlance
smile Re: Photo-video rendering plug-in
Hello
A magnificent Plugin by all means !
>> I use "CameraBagPlugin" to create hundreds of Cameras Exceeding the 50 Limit, however I must select them one by one in Multi Photo Renderer" select dialogue.
Any chance to add CTRL-A (SELECT ALL) function or
SHIFT-ARROW selection ?
Much appreciated
Vic
Maybe in a future version after studying the feasibility.
I was able to add the multiple selection option.
When opening the photos panel, do you prefer?
1- current behavior of the plug-in: 1st point of view selected
2- behavior identical to SH3D: all points of view selected
These will be highlighted.
Selection/deselection using the space key will not be available.
Works Perfectly using SHIFT-Arrows in v2.3 smile Many Thanks
BTW
Additional Sunflow Options v1.2 does not work with Simple Photo Rendering v2.3 in any of the Quality levels ?
Am I missing something ?
I'm running Windows 64bit, Sweet Home v6.6
Thank You for an awesome Plugin.
Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.2 + Plugins
[Feb 22, 2022, 6:12:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
As the YafaRay rendering engine has been added to the source code of the program and it will surely be integrated into the next version of Sweet Home 3D for photo or video rendering with a selector to choose between SunFlow and it, there will be no other public versions of this plugin to avoid confusion in the minds of users.
However, when I have more availability, a plug-in allowing to manage the properties of the 2 rendering engines would be possible.
EnkoNyito
[Jun 12, 2022, 11:07:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
PhotoVideoRendering-2.4 plug-in
As EnkoNyito is not available at the moment to update his Photo-video rendering plug-in, I made the necessary changes to this plug-in to ensure its compatibility with Sweet Home 3D 7.0 lights defined from a shape with lightSourceMaterialName# property.
Note that the YafaRay rendering engine included in this plug-in doesn't work with the Mac App Store version 7.0.1 and above for security reasons, but works with the free version.
[Jul 27, 2022, 6:03:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
