Member(s) browsing this thread: MaryCher
Total posts in this thread: 225
Posts: 225   Pages: 23   [ Previous Page | 9 10 11 12 13 14 15 16 17 18 | Next Page ]
Previous Thread This topic has been viewed 595768 times and has 224 replies Next Thread
confused Re: Photo-video rendering plug-in
Try this :
Launch a rendering with version 1.9 by night (01:00 AM) with a night texture and the yarafay method... SH3D will crash quicky !!! biggrin
Good search.
wink
[Jun 30, 2020, 7:41:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Try this :
Good search.
wink
As you can see here, I have no rendering issues with the textures and sky lighting enabled at night.
From your other post, the problem seems to be with an object in your project that YafaRay is having a hard time rendering.
EnkoNyito
[Jul 26, 2020, 11:38:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
... the problem seems to be with an object in your project that YafaRay is having a hard time rendering.
Yes, I arrived at the same conclusion but which one ?
Strange, it's OK in day light and no in night time ???
Never see before this in 10 years of SH3D...
All other projects are OK. wink
[Jul 27, 2020, 6:56:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
PhotoVideoRendering-2.0a plug-in
- compatibility with version 1.3.2 of YafaRay plug-in
EnkoNyito
EnkoNyito
[Aug 2, 2020, 12:56:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
GhyslainB
Thanks enkonyito! Version 2.0a works like a charm! smile
[Aug 3, 2020, 11:01:30 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Perfect!
Thank You!
Cecilia
[Aug 3, 2020, 6:21:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Atefth
Germany
Hello All,
Is there any way to do rendering on GPU ?
Thank you.
[Aug 17, 2020, 7:29:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Hello All,
Thank you.
Hi Atefth,
The rendering engines currently available (SunFlow and YafaRay) do not allow GPU rendering.
Enko
EnkoNyito
[Aug 17, 2020, 10:57:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
udornbusch
This sounds silly, but after an hour of trying I cannot see any advanced photo or video rendering options.
I have downloaded and installed "PhotoVideoRendering2.0a.zip" and also tried "YafaryRendering 1.3.2" but in both cases the window that opens for photos shows just the space for the photo and the 'width' and 'quality' lines and the buttons to 'create' and 'close'. There is no options to enter the time etc.
For the photovideorendering plugin there are only 3 options in the plugin drop-down (Simple photo rendering (v2.0a),grayed out multiple.. and Video rendering (v2.0a))
I am using version 6.4.2
I am a bit at a loss as to what to do. Thanks!
[Oct 10, 2020, 9:21:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
@udornbusch
SunFlow or YafaRay rendering engines can only be used at quality level 3 and 4 (best) where the date, time and lens are visible.
The PhotoVideoRendering plug-in also adds to the simple photo panel: the selection of the rendering engine, its advanced settings and the activation of sky lighting.
This is where you have to make the settings that also take effect in the multiple photo panel (stored points of view) or the video panel.
Enko
EnkoNyito
[Oct 11, 2020, 9:41:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
