Try this :
Launch a rendering with version 1.9 by night (01:00 AM) with a night texture and the yarafay method... SH3D will crash quicky !!! Good search.
As you can see here, I have no rendering issues with the textures and sky lighting enabled at night.
From your other post, the problem seems to be with an object in your project that YafaRay is having a hard time rendering.
EnkoNyito
... the problem seems to be with an object in your project that YafaRay is having a hard time rendering.
Yes, I arrived at the same conclusion but which one ?
Strange, it's OK in day light and no in night time ??? Never see before this in 10 years of SH3D...
All other projects are OK. .
This sounds silly, but after an hour of trying I cannot see any advanced photo or video rendering options. I have downloaded and installed "PhotoVideoRendering2.0a.zip" and also tried "YafaryRendering 1.3.2" but in both cases the window that opens for photos shows just the space for the photo and the 'width' and 'quality' lines and the buttons to 'create' and 'close'. There is no options to enter the time etc. For the photovideorendering plugin there are only 3 options in the plugin drop-down (Simple photo rendering (v2.0a),grayed out multiple.. and Video rendering (v2.0a)) I am using version 6.4.2 I am a bit at a loss as to what to do. Thanks!
@udornbusch
SunFlow or YafaRay rendering engines can only be used at quality level 3 and 4 (best) where the date, time and lens are visible.
The PhotoVideoRendering plug-in also adds to the simple photo panel: the selection of the rendering engine, its advanced settings and the activation of sky lighting. This is where you have to make the settings that also take effect in the multiple photo panel (stored points of view) or the video panel.
