Re: 2035 : Towards Mars
6 months later, the second crew is arrived (vessel at left).
800x600 in Q4 without R1.3.1
The geodesic complex is finished, we see an astronaut in airlock, ready to go out.
The ground is clean, it shoud have more rocks...
No adventure without a grand plan of space exploration...
The mission : Mars One
SPECIAL FLASH
"allo houston, I think I have a problem".
I can no longer generate pictures because the file weighs more than 192 MB!?!
Even the display window does not appear...
A call for help is on !
[Edit 1 times,
last edit by bdfd at Aug 9, 2016, 7:55:22 PM]
Hi bdfd. I have the same problem sometimes. It happen to me when the project area is a bit too big or when the models are complicated for sh3D renderer. And your problem is in GEODESIC objects. I had the same. Glass GEODESIC objects are really complicated for rendering. And you use not only 1 but 10 in your project!!!!! Your graphic is going to be mad .... Try to hide every objects you can't see in your focus during rendering. It helped me. Or try to use lower AA setting if you use 1.3.1. renderer Martin...
@Martin : Indeed, large spirits meet.
I had assumed it was the Geodesic domes. Therefore I reworked them and have decreased their number by half.
We begin to approach the software limits.
Hooray the project must go on ! Thus was born Mars One bis.
800x600 in Q4 without R1.3.1 Look at the new habitation module (made by myself with sh3d & anim8or)
[Edit 1 times,
last edit by bdfd at Aug 10, 2016, 10:21:15 AM]
