Previous Thread This topic has been viewed 11658 times and has 13 replies Next Thread
Allenov
No 3D view on Linux Mint
Hello,
I installed the last sweet home version (Java Web Start and local version with java embedded) on my Intel NUC i5 and Intel HD Graphics 6000.
I have only a black view, sometimes with blank dots or blank lines.
I use IcedTea java.
My graphic card has no problem on Linux Mint.
Any help ?
Thanks
[Apr 1, 2016, 1:56:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
Re: No 3D view on Linux Mint
Try this:
- uninstall IcedTea Java
- install Oracle Java version 6 or 7
Reason: the installed version of SH3D comes with and uses its own version of Oracle Java. I suspect there's a kind of conflict between that version and non-Oracle installed versions.
If that doesn't help, check if there are alternative drivers for your graphics card.
[Edit 1 times, last edit by hansmex at Apr 1, 2016, 3:08:01 PM]
[Apr 1, 2016, 3:06:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Allenov
I installed Oracle Java version 8.
Same problem : no 3D view.
Is there an option to disable graphics optimizations in SG3D ?
[Apr 2, 2016, 10:50:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Allenov
I opened my session in mode "software rendering" (so without any hardware acceleration) : same problem.
[Apr 3, 2016, 5:52:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sabot
Same issue for me with linux mint 17.3 on a laptop (with driver xserver-xorg-video-ati).
I had troubles attempting using other graphic drivers (crashing cinnamon) and I'll stay with theprevious, recommended one.
No problem however with 3D rendering in another linux mint 17.3 installation running in a virtual environment with Parallels virtualization software on a macsox iMac.
[Apr 30, 2016, 10:54:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
b_e_n_31
Same issue for me as well.
My conf: NUC i5-5250U with linux mint 17.2. (using intel HD graphics)
hw rendering looks to be ok:
~ $ glxinfo | grep "direct rendering"
direct rendering: Yes
[May 8, 2016, 11:29:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Allenov
HW rendering IS ok in OS. So I don't want to install another graphic driver. It seems to be a Sweet Home 3D issue.
[May 9, 2016, 6:43:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
b_e_n_31
I've looked into the bug database, and our issue might be related to "#585 problemes with 3D".
I've tried with Java Web Start, which is dependent on java version installed on the system, and also with Sweet Home 3D installer which brings private version of java to avoid compatibility issues (if I properly understood). Both lead to the same result (3d view windows is black). Let me know if I can bring more data for debug
[May 9, 2016, 2:31:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
b_e_n_31
additional test: same result launching java web start using /usr/bin/javaws (mint default version), and javaws from the bin directory of the sweet home directory.
@hansmex or other SH3D expert, help is welcome :-).
@Sabot, could you please detail your HW config ? (this might put definitively the graphic driver out of suspicion). Additionally, I am curious to know if anyone using mint distro 17.2 was able to run the 3D view ...
[May 9, 2016, 10:17:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
b_e_n_31
Hi, got it to work on my old mac in few clics, on also working on Ubuntu. For the moment I give up with mint.
[May 17, 2016, 9:29:58 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
