- Added advanced settings for rendering properties - Enhancement option to external brightness (sky with or without texture) - Fixed a 3D view management bug in a separate window - Fixed a photo panel resizing bug for small screens - Other minor fixes and improvements
EnkoNyito
[Edit 2 times,
last edit by enkonyito at Jul 4, 2016, 5:07:07 PM]
Re: Progress and time of photo rendering (Create photo with renderer plug-in)
In case of problems with previous links (unavailability of sourceforge), use the one attached.
---------------------------------------- CreatePhotoWithRenderer-1.3.1.sh3p
(137525 bytes)
(Download count: 230)
I had a lot of issues with the default render engine, especially the quality of the image (yes I disable ceiling lights and add lights myself) ..
I got strange art-effects, white spots, dark spots -> know issues, never get fixed. I really couldn't found any solution. Exporting & importing to Blender is an alternative way, but way to complicated for now. . Until I found this plugin. Although I have still strange white spots with this plugin :(. It could because of my chandelier (lot of glass)...
Maybe I'm too harsh, I really like that you put effort into the rendering engine. Kudos for that! Don't get me wrong. But the future could be to switch to a better engine? Like from Blender perhaps.
I really like Sweet Home 3D actually, but the render engine should get replaced by a more modern engine using GPU.
Although I have still strange white spots with this plugin...
This plug-in also uses the default rendering engine.
Change rendering engine means respecting certain conditions for open source software like Sweet Home 3D.
EnkoNyito
Is jMonkeyEngine able to generate photorealistic images with ray tracing like Sunflow?
