Holland
building a roof
I there,
I've checked the forum and I found a question regarding the roof and I downloaded the pdf file but when I create the roof it is positioned in the groundlevel and it must be placed on the top of the wall.
Re: building a roof
You could just lift the roof (e.g. Furniture, Elevate - or use the little blue arrow in one of the corners). But, as you do not want the roof in the way, it may be better to use a new level for the roof (Plan, Add level) at the right elevation and place the roof there. ok
Holland
Re: building a roof
Hi Hawk,
Thank you for the response but at point 6 and 7 in the tutorial it's written that you need to create a room but I can not lift the room to a certain level, you can only lift furniture...
Re: building a roof
Hi Hawk,
but thanks for the info.
I gave some help on how to do that in another topic you have.
this is the roof I'm looking for, did you managed to get the roof filled?
reg. Hans
Filled? What do you mean? Textured? Models don't always texture as well as walls or models textured in a 3D Modeling program.
---------------------------------------- Hawk
[Edit 2 times,
last edit by HawkDawg at Dec 9, 2015, 11:36:44 AM]
